NEW Motovation Sliders - Wrist Twisters
post #1 of 20 Old 01-28-2010, 07:36 AM Thread Starter
jabberjoe87's Avatar
All the threads on sliders that I could find on here were from 07 and such. So I got a set and installed them this morning. For the Record, there is now, one lock nut, one locking washer, then a hat style nut and washer(it has that lil brim on it with the grooves to help it lock to a washer better). The lock nut is a 17mm and the "hat" style nut is a 15mm. The rod is a stainless steel rod with threaded ends, and is 10mm. Installation went smoothly, it took under a minute to drill each hole and I put the right side on first with loctite and slid it through to the left side. Then I put the left slider on with the washer held inside by me holding a socket extension up against it to get it onto the threads. It took me about 15 minutes then to realize that this nut is a 15 and not a 17. It is possible to put these on with one person I just layed infront of the header with a socket on each nut and tightened. I don't understand the point of torquing these nuts as they are just going through the frame and do not replace any engine mount so I just tightened them with a half inch rachet.
For some reason the attachements won't let me attach pictures, I might have to take pictures again with my camera set up for taking smaller files. blah. Hope this isn't something already up on here, I couldn't find anything.
jabberjoe87 is offline
post #2 of 20 Old 01-28-2010, 07:55 AM
Ballaholic
hornet919's Avatar
where did ya get them from?
hornet919 is offline
post #3 of 20 Old 01-28-2010, 09:41 AM
Tirone shoelaces
TexasTraffic's Avatar
Probably from Motovation Accessories, located in Austin, Texas.
Honda 919 Frame Sliders
TexasTraffic is offline
post #4 of 20 Old 01-28-2010, 05:46 PM Thread Starter
yup typed in motovation on the web browser
post #5 of 20 Old 01-28-2010, 06:45 PM
Actually, the "tie-bar" option has used that nut/washer combo for quite some time now. What you described is exactly what mine came with back in '06. It's a good system
Professional
post #6 of 20 Old 01-29-2010, 10:11 AM Thread Starter
yea thats what i was tryin to see if there was any clarification cause all the threads i saw on the frame sliders were from 06 and 07, didnt see any newer stuff on them.
post #7 of 20 Old 01-30-2010, 04:38 PM
Shoot to stop
beardking's Avatar
Man, I wish my drilling went as easily as yours did. I ended up buying 2 25/64 bits, breaking one 3/8" drill bit, and it took me multiple tries over a couple days. They look really nice though. Hopefully I'll never get to test them.
beardking is offline
post #8 of 20 Old 01-30-2010, 09:54 PM
Tirone shoelaces
One side was very quick & easy.
Drilling the other side was a stone bitch. I took me a couple hours and a couple drill bits.
post #9 of 20 Old 01-31-2010, 09:59 AM
Sixty-9er
edgecrusher4444's Avatar
Why?
"Grip it and Rip it!"
edgecrusher4444 is offline
post #10 of 20 Old 02-02-2010, 08:34 AM Thread Starter
wow i just grabbed a drill bit out of my pops gigantic snap on box and two minutes later i was putting the bit back in. I know that bit set wasn't cheap, as he was a machinist before he retired and brought his toolbox home.
post #11 of 20 Old 02-03-2010, 03:43 PM
Sixty-9er
Joe you got those pics? I need to see your nuts...err
post #12 of 20 Old 02-07-2010, 07:28 PM Thread Starter
ha, the pics i had didnt show teh nuts on the inside of the slider. Now my bike is under the cover and surrounded by snow, i'll work on it soon enough though
post #13 of 20 Old 02-07-2010, 07:39 PM
Sixty-9er
no worries. I got my sliders done.
post #14 of 20 Old 02-08-2010, 08:49 AM
Tirone shoelaces
Originally Posted by edgecrusher4444 View Post
Why?
The part the sliders bolt to is a casting that is welded to the square frame tubing. Sometimes the weld intrudes into the area that is drilled. This weld material id very hard and difficult to drill.
post #15 of 20 Old 02-08-2010, 02:18 PM
Sixty-9er
yeah I found that out. last little bit was tricky but good bits and lube helped.
post #16 of 20 Old 02-15-2010, 01:57 PM
Kingston's Avatar
I have a small machine shop and a set up for anodizing aluminum. On my '04 919 I want to put on frame sliders like these. They are two different lengths, right and left. Could someone tell me their lengths. Now all I have to do is pick a colour.
Kingston is offline
post #17 of 20 Old 02-15-2010, 03:15 PM
Will these help?
Professional
post #18 of 20 Old 02-15-2010, 03:22 PM
Aluminum sliders are the last thing you'ed want. To high a drag coefficient. In fact, you would have to change the name from "sliders" to "augers"!
Professional
post #19 of 20 Old 02-18-2010, 03:41 PM
Kingston's Avatar
I'm confused on the size of the nuts on the 10mm threaded rod. When you go to Honda 919 Frame Slider the instructions say to use a 12mm socket to tighten the nuts. You canít put a 12mm nut on a 10mm threaded rod. But then Joe said that there was a 17mm on one end and a 15mm on the other. I think I'm going with a 3/8' S.S. threaded rod and 9/16 nut on the ends. Also, why is there a shoulder shown on the inside of the slider, that would just make it weak at that point? Honda 919 Frame Sliders
Kingston is offline
post #20 of 20 Old 02-18-2010, 05:03 PM Thread Starter
Yea I didn't understand that shoulder either, still seems fine though i guess haha. The nuts that come with the kit are the two different sizes if thats what your asking? Like the is 10mm
