New Digital Gauges for the 919? - Wrist Twisters
post #1 of 42 Old 10-02-2010, 09:31 AM Thread Starter
arctic954's Avatar
...... Thought I'd get a thread going on Digital gauges that can be used on the 919.
- It would be nice to have something digital, maybe w/ a gear indicator
- Light-weight would be an added benefit
The first one would my favorite for track-days.... dump the stockers....mount it slightly left of center.
(Speigler) Motogadget - ChronoClassic Multi
Motogadget - MotoScope Light
Here's another cheap alternative....... the Veypor in black.... for $159
mounted on an SV650...
Here's another one....from Trailtech --- ALSO called they 'VAPOR', normally for off-road use, this one has been adapted to an SV650.
arctic954 is offline
post #2 of 42 Old 10-02-2010, 10:32 AM
I've looked at putting on an automotive tach, found a nice Stewart Warner electrical analog display type. White face, not black. Black is problematic for me in flat light conditions in the fall season.
post #3 of 42 Old 10-02-2010, 10:34 AM
woodyeee's Avatar
Ok heres a secret, seems ive been meaning to do a gauge swop for years and have just not got round to it. I want to put an rc51 speedo on my 919 but ive never found one for the right price or ive had other things to do instead. It looks to me that it will be a fairly easy mod and it has the right redline for our bikes and its still a nice gauge after all these years
woodyeee is offline
post #4 of 42 Old 10-02-2010, 12:40 PM Thread Starter
arctic954's Avatar
......wiring wise....do you think it will require a hack job or plug n' play?
post #5 of 42 Old 10-02-2010, 02:23 PM
woodyeee's Avatar
I'm no electrician, but i once compared the two wiring diagrams and most of the colours of the wires were the same if i remember rightly
If someone would care to send me one with the rc51 loom i will put it on
woodyeee is offline
post #6 of 42 Old 10-02-2010, 02:57 PM
Total Awards: 17
f4i gauges almost plug n' play. You just need to reuse 1 connector from 919 gauges as on 919 setup 1 is male 1 female and on f4i there are both female
zaq123 is offline
post #7 of 42 Old 10-02-2010, 03:32 PM
If only our redline started at 14k
post #8 of 42 Old 10-02-2010, 03:45 PM
Total Awards: 17
yea, we can only wish.
As far as gauges go: who gives a crap, I never look at the thing anyway when I need to shift.
and as far as f4i functionality goes, I like the following, something that my '03 didn't have:
1. Clock
2.temp. gauge that actually shows the temp
3. fuel reserve meter, it has a count down on how much reserve you have as you using it.
3. 2 trip odometers, A & B
4. Bright turn signal led, keeps me from forgetting to switch that blinker
zaq123 is offline
post #9 of 42 Old 10-02-2010, 05:39 PM
Originally Posted by zaq123 View Post
1. Clock Got it.
3. 2 trip odometers, A & B Got it
4. Bright turn signal led, keeps me from forgetting to switch that blinker OK on mine
Must have been a change on later 919's.
I've never found any form of motorcycle fuel gauge or warning system to be accurate - the best was the old reserve tap petlock - you soon knew when you ran out of fuel on the main tap - change to reserve and find a station.
post #10 of 42 Old 10-02-2010, 06:04 PM
Total Awards: 17
yeap, there was a change in post '04 gauge setup.
zaq123 is offline
post #11 of 42 Old 10-03-2010, 02:09 PM
Wasn't there some glitchyou discovered re this change, or at least came up with the work around ? Temp Gauge accuracy related is my recollection.
post #12 of 42 Old 10-03-2010, 03:47 PM
Total Awards: 17
the glitch was that nobody could figure out how to get fuel reserve gauge working.
After reviewing 919 and f4i diagrams, I figured out the fix, it was pretty simple.
Kick stand switch had to be wired into the gauges as a part of fuel light reset.
On 919 the stand wire can be picked up at the clutch lever switch, no need to go all the way down to the kick stand switch.
zaq123 is offline
post #13 of 42 Old 10-03-2010, 03:54 PM
Hastatus Posterior
Farab's Avatar
1. Clock
Does it have a gear indica... sorry, silly question, Honda don't believe in such witchery.
Farab is offline
post #14 of 42 Old 10-03-2010, 04:58 PM
That was it !
Good on you.
post #15 of 42 Old 10-03-2010, 04:58 PM
919 aka Hornet 900
Mr T81's Avatar
Seen this a long time ago YouTube - Honda Hornet 900 Yoshimura
Mr T81 is offline
post #16 of 42 Old 10-03-2010, 05:08 PM
Red Rider
Woody469's Avatar
Pretty nice setup, I wonder what it is and how the install was?
My blood runs Honda Red......
2003 Honda 919
2004 Honda 599
1999 Honda XR650L
Woody469 is offline
post #17 of 42 Old 10-03-2010, 06:18 PM Thread Starter
arctic954's Avatar
The unit shown above is made by Acewell..... They are fairly in-expensive (around $150) --- basically are set up for off-road bikes but also work on streetbikes. They come with their own speed sensor, temp sensor you put in-line into one of your radiator hoses..... then the indicator lights you have to figure out.
post #18 of 42 Old 10-03-2010, 06:19 PM Thread Starter
arctic954's Avatar
I found another company that is also making some cool stuff..... this company is expensive --- around $400. They make the model below in a 10,000 RPM version.
post #19 of 42 Old 10-03-2010, 06:34 PM
Red Rider
Woody469's Avatar
That Koso is pretty sweet!
2003 Honda 919
2004 Honda 599
1999 Honda XR650L
Woody469 is offline
post #20 of 42 Old 10-04-2010, 05:53 PM
Braaaap
TeamZ's Avatar
Really like those last few gauges. Am I being really picky or does someone else care if they loose there miles? Yes I know you can keep track of them after you get the aftermarket one on there and just add them to what you had, but still if you end up selling or whatever.........Just my thought
LIVE TO RIDE
TeamZ is offline
post #21 of 42 Old 10-04-2010, 05:58 PM
Total Awards: 17
there is a simple way to get your miles up to what you have now
zaq123 is offline
post #22 of 42 Old 10-04-2010, 08:44 PM Thread Starter
arctic954's Avatar
If you plan on reselling your bike....I wouldn't do it. Hopefully, the 9er will be in the stable for a while.
post #23 of 42 Old 10-06-2010, 01:30 PM
Braaaap
TeamZ's Avatar
There is?? Can you order them and tell them what miles you have or what?
LIVE TO RIDE
TeamZ is offline
post #24 of 42 Old 10-06-2010, 01:42 PM
Total Awards: 17
if you go with new gauges ~$600 from the dealer, he will do it for you or....
you can do it yourself if you get used gauges for $70 from ebay like I did.
All you need to do is to load a frequency simulator program on your laptop, get a set of old headphones, cut one ear piece off and connect them to your speedo. If you select the correct frequency (I have it written somewhere), it will make you gauges go 180 mph while you bike is sitting in your garage. So you gauges will turn 4320 miles in 24hr period.
There is no way to get it back down however and there shouldn't be any need to do that
zaq123 is offline
post #25 of 42 Old 10-06-2010, 01:54 PM
I looked at those Koso units for my streetfighter F3. I'd need different redline.
The other gauges are nice, but I just can't stand a digital tach.
post #26 of 42 Old 10-07-2010, 08:30 AM Thread Starter
arctic954's Avatar
......am interested in the RC51 gauge swap.... If anyone has had experience with this, post it up....
post #27 of 42 Old 10-07-2010, 11:44 AM
Bacon-powered
ekovach's Avatar
Amazon.com: koso: Automotive
Koso gauges on Amazon.com for less than MSRP.
Grade School - Honda CB 125
High School - Honda 400 Hawk
College - Honda VT500 Ascot
Real life - Honda 919
ekovach is offline
post #28 of 42 Old 10-07-2010, 12:04 PM Thread Starter
arctic954's Avatar
I've come to the same conclusion.
Figure....by the time you get an RC51 speedo, wireharness, and mounting bracket....you'd at least have $300 into it..... Why not get a pro gauge (Bimota and others use these) ready to go with all new stand alone sensors and a nice mounting bracket for the same price.
Long story short....my local PartsUnlimited guy made a call and got me a killer price on the Koso RX2n 10,000rpm version.
Expect some pics and a full install report soon.
Btw - pm'd LDH on a price....he's also VERY competitive on price with the KOSO stuff. (just on the other side of the state)
post #29 of 42 Old 10-07-2010, 03:43 PM Thread Starter
arctic954's Avatar
post #30 of 42 Old 10-07-2010, 05:33 PM
Blue919Guy's Avatar
Too bad it does not show to 11,000RPM. My 919 gets pushed just past 10K quite often. Not much past, but still
I would really like some new gauges, how difficult do you think the install is going to be…
Blue919Guy is offline
post #31 of 42 Old 10-07-2010, 05:43 PM
I'm not in the gauge making business. Having said that, it doesn't seem like it would be too hard to offer something with different redlines with a shift light. Analog tach, digital speedo, and the other "normal" idiot lights.
Give me a tach that I can cutout the range I want to show and then program the redline.
post #32 of 42 Old 10-07-2010, 05:46 PM Thread Starter
arctic954's Avatar
They do have 2 versions.... one for 10,000 and one for 20,000..... figure I can set the 2 shifts lights for 9,500 and then again for 10,000... Power starts to drop after that anyway.
---- Doesn't seem to bad of an install..... It is a universal kit (with a bracket that will install just about anywhere - cool design)....so it can run self contained of the ECU.
there is a front wheel magnet and an active pickup that gets installed on the front fork.... the RPM will either get picked up at the coil under the tank or direct for the RPM wire going to the OEM speedo. There's also a coolant temp sensor that gets put in-line in a coolant hose.....(not sure yet if you can simply tap into the existing sensor...we'll find out)
Where most of the wiring is going to be......is getting all the colors for the indicator lights figured out.
post #33 of 42 Old 10-07-2010, 05:59 PM Thread Starter
arctic954's Avatar
The gauge you want.....is a KOSO and does exist..... its just custom made and on the Bimota Testi 3D.
post #34 of 42 Old 10-07-2010, 06:15 PM
The reviews I've read say the magnet pickup for speed, and the wire pickup for RPM can be iffy. It would be nice if they could take the stock gauge inputs for this stuff and get it dead on.
post #35 of 42 Old 10-07-2010, 06:21 PM Thread Starter
arctic954's Avatar
Good to know.
I've read the manual for the gauge already....and there is a bunch that can be programmed. Its my guess that the sensors might not be needed and 95% can be taken directly from the wiring harness. Pretty sure, I'll at least be able to grab the RPM straight from the harness.
post #36 of 42 Old 10-07-2010, 06:44 PM
Blue919Guy's Avatar
That is seriously baddazz! Not available though Im guessing? Im going to watch this thread and see how the install goes for you...
post #37 of 42 Old 10-07-2010, 06:45 PM
919 aka Hornet 900
Mr T81's Avatar
I have plans for this winter but I might want to install one of them Koso next winter. Very nice...
Mr T81 is offline
post #38 of 42 Old 09-17-2012, 01:59 AM
fordmanforever's Avatar
Not to tick anyone off drugging up an old thread does anyone know how hard a rc51 speedo is to get working if you have the cluster and wiring harness?
Toy Box:
2005 Ford F-150 SC 4x4 Lariat
1993 Ford Mustang COBRA
2005 Honda Aquatrax R-12x & F-12x Turbo's
1997 SeaRay 190RS MERC. S.S. prop./Hydrafoil
2006 Honda 400EX & 2007 250EX **FOR SALE**
2005 Honda CBR F4I **FOR SALE**
fordmanforever is offline
post #39 of 42 Old 09-17-2012, 06:15 AM
I believe the tach is the main issue since its designed for a v-twin instead of a inline four.
I have used a Dakota Digital tach signal converter on my rally-x car. It can switch the signal to read 4-6-8-12 cylinders on a 4 cylinder tach. Not sure if they make a product for 2 to 4, but the device i used worked great.
post #40 of 42 Old 09-18-2012, 09:48 AM
carteo76's Avatar
This is my digital dash!!!!!
Uploaded with ImageShack.us
carteo76 is offline
