New Carbon, midpipe ID not matching... - Wrist Twisters
post #1 of 19 Old 02-13-2012, 08:40 PM Thread Starter
Needs training wheels.
Brewcrew02's Avatar
Got the new Danmotos. New mid-pipe doesn't really tighten down onto where the stockers came off of... Any ideas on an insert for the mid ID to tighten better on the stock OD? Thinking 2 pieces of galv. pipe strap cut with some give for tightening.... Thoughts? Please?!
Brewcrew02 is offline
post #2 of 19 Old 02-13-2012, 09:03 PM
Ginger-prick
EatDirtFartDust's Avatar
In this base.
2007 Honda 919.
EatDirtFartDust is offline
post #3 of 19 Old 02-13-2012, 09:05 PM Thread Starter
Brewcrew02's Avatar
Originally Posted by EatDirtFartDust View Post
In this base.
Que?
post #4 of 19 Old 02-13-2012, 09:20 PM
Ginger-prick
Originally Posted by Brewcrew02
Que?
"in the same boat"
Have the same problem.
2007 Honda 919.
post #5 of 19 Old 02-13-2012, 09:25 PM
return them, get your money back, and buy my satos....
ok seriously, man that's tough.... how much difference is there?
post #6 of 19 Old 02-13-2012, 09:28 PM
Can't you wrap the joint in some exhaust tape and clamp her down?
Cheap easy fix.
post #7 of 19 Old 02-13-2012, 09:53 PM
Is there a gasket? How about an OEM Exhaust Gasket? P/N 11
post #8 of 19 Old 02-13-2012, 09:55 PM
Have a read at the 1st comment on YT:
DANMOTO Twin Carbon Fiber on My Brow's CB 919 Hornet - YouTube
Not sure if MRHornet919 is a member here.. but he mentions that you'll need a 2-2.5" spacer. Also pause the video at :57 and see what you're missing.
post #9 of 19 Old 02-13-2012, 10:29 PM Thread Starter
Brewcrew02's Avatar
You, my friend, are a fucking genius!
post #10 of 19 Old 02-14-2012, 02:26 AM
How much is it out? I may be exactly the same as the stock gasket - try first. If it is only 1mm or 2 you could trim and wrap some sheet copper around the join as a gasket - this should clamp down nicely and use a squirt of high temp silicone as a sealer.
If you are lucky your neighbor will have copper spouting .....
Darn Chinese should have got it right the first time!
post #11 of 19 Old 02-14-2012, 05:41 AM
Even a blind squirrel finds a nut once in a while. Glad it was something easy. I know when I removed my stock cans, the gasket was stuck to the can. Were you able to re-use the old ones?
post #12 of 19 Old 02-14-2012, 05:51 AM Thread Starter
Brewcrew02's Avatar
I'll find out around 3:30 CST!
post #13 of 19 Old 02-14-2012, 01:15 PM
Ginger-prick
That gasket isn't coming out with damaging it.
Plus it's too thick to fit in between of it did come out.
2007 Honda 919.
post #14 of 19 Old 02-14-2012, 03:17 PM Thread Starter
Brewcrew02's Avatar
What he said... Lame. Back to square one. Ideas? This was one idea... use 2 pieces of pipe strap side by side with the open ends opposite each otherso no leaks when tightened
Or some header tape like g00g said...
post #15 of 19 Old 02-14-2012, 05:38 PM
just about any sheet metal will work, thin wall ducting works too in a pinch
post #16 of 19 Old 02-15-2012, 01:27 AM
If you take the mid pipe and 9er Y pipe to a muffler shop they may be able to reduce the mid pipe a bit on one of their fancy machines.
post #17 of 19 Old 02-15-2012, 04:37 PM
Ginger-prick
I'm going to look for some copper sheeting to put in between.
2007 Honda 919.
post #18 of 19 Old 02-15-2012, 05:46 PM Thread Starter
Brewcrew02's Avatar
Save your money. Buy a roll of the pipe strapping I posted a pic of. Installed the cans today. Galvanized strap cut to OD length worked perfectly. Sounds amazing!
post #19 of 19 Old 02-16-2012, 03:12 PM
That and throw some black gasket sealant in with it, that'll cover any little holes that need plugged.
