Neutral light flickering??? - Wrist Twisters
post #1 of 10 Old 04-02-2009, 09:00 PM Thread Starter
Naked bikes = Perma-grin
Asphalt 919's Avatar
My green neutral light either stays on or flickers in every gear.
I did a search, but didn't find anything about this.....so I thought you guys could help me narrow it down. I've heard about a neutral switch....Is it adjustable? Is it external or in the tranny???
Thanks,
Luke
Asphalt 919 is offline
post #2 of 10 Old 04-02-2009, 09:07 PM
Never heard of a flickering. I would say it was just at a connection point as a start. Does it flicker every time you shift or just between 1st and 2nd?
post #3 of 10 Old 04-02-2009, 09:10 PM Thread Starter
Flickers or stays lit in every gear, not just between gears. It's annoying when riding in the evening, since it's bright.
post #4 of 10 Old 04-03-2009, 03:48 AM
BlackRig's Avatar
I had this same trouble at a track day. There was a wire rubbing on the chain. Near the front sprocket cover. I'm at work right now but I can post a pic for you later if need be.
Hope it helps.
BlackRig is offline
post #5 of 10 Old 04-03-2009, 04:45 AM
Look at #8 here:
http://fiche.ronayers.com/Index.cfm/...roup/CRANKCASE
Sorry for the long link, I'm in a hurry. This shows where the switch is located. Start with the wiring and trace it out.
post #6 of 10 Old 04-03-2009, 04:53 AM
pull the bulb out.
neutral lights are lame anyways.
i've had bikes that the light would come on when i thought it was in neutral and it was in gear and wouldnt come on when it was in neutral...
Get to know your bike, and you'll realize the light is useless.
JiinKz is offline
post #7 of 10 Old 04-03-2009, 01:55 PM Thread Starter
Look at #8 here:
Thanks for the link! Looking at the fiche there apears to be a standard washer, and two optional thickness washers to set the depth of the switch...
14 90442-028-000 WASHER (8MM) 0
15 90443-MJ6-000 WASHER, NEUTRAL 0
16 90463-ML7-000 WASHER (6.5MM)
Now that I know this and where it is I should be able to get it adjusted!
Thanks
post #8 of 10 Old 04-03-2009, 01:58 PM Thread Starter
Originally Posted by JiinKz View Post
pull the bulb out.
Dude, simmer . I've ridden it like this for over 4,000 miles last summer. I guess I haven't needed it, but I am particular about my stuff. The little things are what drives a person crazy!
post #9 of 10 Old 04-03-2009, 02:04 PM
Tirone shoelaces
TexasTraffic's Avatar
Originally Posted by Asphalt 919 View Post
..... drives a person crazy!
Short drive.
TexasTraffic is offline
post #10 of 10 Old 04-03-2009, 02:08 PM
Originally Posted by TexasTraffic View Post
Short drive.
At least we won't have to stop and put gas.
