Need Help - lacquered Injectors - Wrist Twisters
post #1 of 4 Old 05-17-2006, 08:24 PM
JoelE
Guest
Posts: n/a
I strongly suspect my injectors are clogged as a result of the bike sitting up for a long time with fuel in the tank, and I didn't know about stabilizer. What is the best way to get the injectors cleaned so I can get the bike to turn over?
post #2 of 4 Old 05-17-2006, 09:59 PM
Well, Could you describe your problems more exactly, I am sure someone on here can help. That said, if it wont even turn over you probably have battery problems. How long did it sit, Does it just klick or anything when you try to start it, does the Headlight come on when you turn on the key?
post #3 of 4 Old 05-17-2006, 10:31 PM
Removed User 1
Guest
Posts: n/a
I could be wrong but here I go any way... If they are completly clogged then you will have to get them rebuilt, I do not know of anyway of cleaning them.
post #4 of 4 Old 05-18-2006, 04:40 AM
A well described list of symptoms would help.
Welcome aboard...
