Need a longer kickstand -.- Suggestions? - Wrist Twisters
post #1 of 21 Old 10-09-2010, 01:36 AM Thread Starter
So i've already done a search for this, but I just installed a F4i rear shock to balance out the front Racetech springs I put in my bike, and now the entire bike has been raised. The bike rides awesome now and is perfect for my weight, but now the kickstand is too short and when I lean the bike over, it's on the verge of tipping. Any suggestions on an aftermarket longer kickstand? or is extending it via welding the best bet? Thanks ahead of time for your help!
achu is offline
post #2 of 21 Old 10-09-2010, 01:48 AM
do you have to extend it, or could you bend it and make it work?
post #3 of 21 Old 10-09-2010, 02:08 AM
Pob
On supermotos (where you may change between road and dirt wheels - 18 " + 21" to 17") I used to drill the base of the kickstand and tap a thread in it and screw a large bolt into the bottom that would extend the stand. If I went dirt riding it was easy to remove the bolt. If you put the bike back to standard my method would be better than welding extra length to your stand.
After all you may only want to add an inch or so to the length? - said the actress to the bishop - sorry British joke
Pob is offline
post #4 of 21 Old 10-09-2010, 02:11 AM Thread Starter
I'm pretty sure bending the kickstand won't work lol. My front and rear were raised about 2".. i'm going to be lowering the front some more, but the rear is fully preloaded out.
achu is offline
post #5 of 21 Old 10-09-2010, 02:41 AM
dude you are nowhere near falling over. sometimes having that extra lean is a good thing. Have you ever had to lean your bike into a hill to park it? I'd rather have my bike sitting at 30 degrees than 2 degrees
have you sat on it and tried to lean it further left while on the side stand? I bet its a lot more difficult than you think.
post #6 of 21 Old 10-09-2010, 03:50 AM
Pob
Should read large bolt of course in my post!
Pob is offline
post #7 of 21 Old 10-09-2010, 08:39 AM
This is a really good suggestion. Test to see how much force is needed to lever the bike over off the lean stand foot. If the effort needed is high, no stand length adjustment is needed - regardless of how it looks.
post #8 of 21 Old 10-09-2010, 08:40 AM
2 inches front and back ?
post #9 of 21 Old 10-09-2010, 10:19 AM Thread Starter
Yea, 2" front and back.. and if I put a little pressure on the bike it'll just tip over. It's ridiculously easy to do a kickstand turn now though lol
achu is offline
post #10 of 21 Old 10-09-2010, 11:05 AM
Gesundheit
My apologies...I couldn't resist.
post #11 of 21 Old 10-09-2010, 11:24 AM
Too much angle can be a very bad thing if you happen to live in an area that gets hot. How many times have WT members had sidestands sink into hot asphalt, usually resulting in a tip over? Hell, I've had centerstands sink into the ground, but it always stops as soon as the tires touch.
The "stick a bolt in it" method will work, but be sure to put as big a foot on the end as you can -- otherwise it is considerably more likely to dig into whatever it's resting on and fall over.
post #12 of 21 Old 10-09-2010, 12:03 PM
My dad didn't like a few of his bikes to lean too much so he would make a little platform shoe for the bottom of the stand.
2526 is offline
post #13 of 21 Old 10-09-2010, 03:21 PM
Two Wheeled Warlord
Danke's Avatar
Don't modify your stock stand. Hit up a wrecker, eBay, etc. and get another one and change that one. Then if you ever take the bike back to stock to sell it you won't be on the hunt for a stand then.
Danke is offline
post #14 of 21 Old 10-09-2010, 04:27 PM
if the bike know 'rides perfectly for your weight', why is it 'fully preloaded out'.
The f4 shock is designed for a linkage system, where it is attached to the swingarm, did you modify the shock or spring?. Maybe with the right spring you could drop the preload and lower the rear, and solve that problem
If it is 2 inches higher how much will you drop the front by, will this make it very twitchy and prone to tankslapping in hard acceleration when the front lightens up.
It sounds like you have altered the dynamics of the bike quite a bit,why is the front now 2inches higher. i am interested in the perfect ride you now have, thus the questions.
dave
davehirt is offline
post #15 of 21 Old 10-09-2010, 07:46 PM
dave
You raise a very good point.
RaceTech's site shows the standard spring for a F4 as being 14.2 kg/mm = 795 # /inch which is woefully inadequate for a 919. I sure hope the spring has been changed, otherwise it would have to be heavily preloaded to be of any use - and even then, would never be "right".
Past that, I have a hazy recollection of someone else investigating F3 or 4 shocks and my memory is that not only are they severely undersprung, they are have a longer eye to eye length.
post #16 of 21 Old 10-09-2010, 07:48 PM Thread Starter
dave
Don't have an answer for you. All I can tell you is I went through angeles forest today and was way more comfortable doing banks and switch backs. The suspension dynamics have been altered. The front was raised an inch and the rear was raised about 1.5" to be specific. I'm 6'0" 280lbs with gear so at this point it handles perfectly. It's a great balance between comfort and the aggressive riding I do in canyons and track. There's no tank slap or twitchiness upon hard acceleration and it's a very very civilized and proper ride.
All I was asking for was input on a kickstand lol. I didn't ask for your opinion on how my suspension is set up. You may not like how I set my suspension up but at this point i'm absolutely in love with my 919. Thanks for everybody elses input. I'm no moto gp or ama rider. I just love my bike and riding it and it's finally at a point where it's set up perfectly. Just need to take care of the loose ends now.
achu is offline
post #17 of 21 Old 10-09-2010, 09:27 PM
thats great that the bike works for you, I was just coming from another angle.. you mention that you have fully preloaded the rear, this would raise the rear a bit.
Perhaps with a different spring you could set the preload in the middle of the shocks stroke and the rear would come down.... solving the sidestand issue.
No biggie from my end, enjoy. ;-)
davehirt is offline
post #18 of 21 Old 10-09-2010, 11:39 PM
Considering you have just spend hundreds on suspenders etc, drop another $35 on a new stock stand. www.cyclepartswarehouse.com
Then cut off the foot and grap a piece of pipe that is a tight fit over the end of the stand - needs to slide up a inch or more over the stand - you may need to file the stand a small amount. Weld this to pipe to the stand - experiment with the length and when happy weld on a nice flat foot from a piect of scrap steel. Add paint. Job done.
post #19 of 21 Old 10-10-2010, 04:15 AM Thread Starter
Thanks guys! My friend actually came up with the same solution. Going to get welding. Actually may be selling my bike soon to buy an FZ1 as well haha.
achu is offline
post #20 of 21 Old 10-10-2010, 08:08 AM
I need to do the same thing as well.
I always thought the 919 had a higher lean angle on the stand than desired.
I've raised my bike up some, and now the bike leans over too much for my liking.
It doesn't take much effort to pull the bike over and two point it on the front tire and lean stand. I also keep a small 4x3 piece of plywood in the tailsection for any gravel parking I get stuck with the odd time. I might just get a hockey puck and dremel it out for the lean stand foot and kill two birds with one stone. The bike is always on a race stand at home and doesn't get parked very often once it's out of the garage.
post #21 of 21 Old 10-10-2010, 09:13 AM
Total Awards: 17
lets see some pics. I'm curious about that suspension setup
zaq123 is offline
