need 1 link of chain - Wrist Twisters
post #1 of 14 Old 06-05-2008, 07:42 PM Thread Starter
daveb's Avatar
Got a problem and need some help. Last year I replaced my 114 link 530 chain with a 112 link 530VM Gold DID X Ring chain. Everything is fine, but I want to go up to a 17 tooth counter shaft sprocket, and the 112 wont fit. I have the 2 rivet master links but I need 1 inner link. I contacted Sprocket Center but they don't have any spare chain. They don't cut any of their chains, so if anyone has an inner link from a DID 530VM X Ring Gold please PM me.
daveb is offline
post #2 of 14 Old 06-05-2008, 09:05 PM
Trackday Recognition Veteran
I might have 6 links but it's 35 miles away.
I can find out for sure on Saturday and post up.
Sokali is offline
post #3 of 14 Old 06-06-2008, 02:36 AM
Dave, if you want to gear up, you can also go with a smaller rear sprocket. That way you wouldn't have to mess with your chain.
If you haven't gotten a PM yet, I may be able to help.
post #4 of 14 Old 06-06-2008, 05:14 AM
I Love Parallel Twins
Naked/SS's Avatar
What tooth count rear sprocket would give the same results as going to a 17 tooth countersprocket?
Naked/SS is offline
post #5 of 14 Old 06-06-2008, 07:11 AM Thread Starter
daveb's Avatar
Thanks Sokali, no rush I've been told that the inner link pin size is important, and you just cant use any 530 chain. I don't want change the rear sprocket as Sniper suggested. What I'm trying to accomplish is correcting the spedo error, and hopefully less vibes, as was stated in a previous post.
daveb is offline
post #6 of 14 Old 06-06-2008, 12:08 PM
The Guy passing you...
Evad101's Avatar
Donation Donation BOTM Donation
I think I may have the DID X ring chain in 530 you need. Let me know if you still need it and I will go double check.
-Dave
Evad101 is offline
post #7 of 14 Old 06-08-2008, 04:19 PM
BrokeRecord
I do believe 3 on the rear =s 1 on the front.
brokerecord is offline
post #8 of 14 Old 06-08-2008, 07:54 PM
Veteran Donation
More or less
16/43=2.69
17/43=2.53
16/40=2.5
And my Fav 17/44=2.59
tvetree is offline
post #9 of 14 Old 06-08-2008, 10:53 PM
Evad,
I looked around and couldn't find it, so can you check when you get a chance?
Thanks
Mike
Sokali is offline
post #10 of 14 Old 06-09-2008, 12:02 AM
Evad101's Avatar
Originally Posted by Sokali View Post
Evad,
Thanks
Mike
Got it and will send to him.
-Dave
Evad101 is offline
post #11 of 14 Old 05-30-2009, 11:44 AM
Guzzi Man
Those recommending a 40 or 41T rear are on the ball. I wouldn't run 2 masterlinks on anything that makes 100 hp and does a low 11 sec qtr mile. Engine cases damage or a chain wrapping itself around the rear wheel at speed is not something you want to experience!
Ride safe
Ride smart
mikestib1 is offline
post #12 of 14 Old 05-30-2009, 11:56 AM
Dave, I have a new did 530zvm chain that should be arriving today or tomorrow. I'm sure I'll have a few links left once I'm done swapping it out. if you want it, i'll send you some
post #13 of 14 Old 05-30-2009, 09:49 PM
Veteran Donation
Dave should have it covered it was almost a year ago.
I like Old threads,Got a memeber on another site that reopens threads almost a year to the day.Makes it hard to know what's going on sometimes.
tvetree is offline
post #14 of 14 Old 05-30-2009, 11:55 PM
Doh! I got suckered! sunofa!
