Nail in brand new tire and centerstand - Wrist Twisters
post #1 of 20 Old 08-12-2015, 05:00 PM Thread Starter
So part of this post is to ask if anyone has ever patched, pugged, or vulcanized a motorcycle tire. I picked up a nail in my new (about 500 miles on it) power pilot rear and all the tire shops around me said they couldn't help me out. I'll spend another 200$ If I absolutely have to, but I prefer not to.
Next is to praise phobmans center stand. This thing is built like a tank and really made it easy on me. Great price, fast shipping, thanks again!
tim281 is offline
post #2 of 20 Old 08-12-2015, 05:02 PM Thread Starter
Tire
tim281 is offline
post #3 of 20 Old 08-12-2015, 05:59 PM
Yes, I have run with a plugged and patched tyre for a considerable distance. A local repair shop was happy to get involved. The patch on the inside seems to me to be the most important part, to ensure there is no local, specific load on the plug - after that was done, I had zero issues with my Conti motion for another 8,000km [=5,000 mi.].
Others will tell you the only place they would ride a plugged/patched tyre would be down to the store to buy a new one....
Good luck.
K1w1Boy is online now
post #4 of 20 Old 08-12-2015, 10:01 PM
I rode a plugged tire for quite a while. Never had an issue.
Your puncture seems to be right down in the tread, too, in the center. Best place you could ask, lol...
post #5 of 20 Old 08-13-2015, 03:09 AM
I would plug it and go (TWSS)
post #6 of 20 Old 08-13-2015, 05:35 AM
Silent but Deadly
jtaylor's Avatar
I got a roofing nail one and the local shop plugged it and patched it on the inside. I road the tire to the end of it's life with no issues. Never lost any pressure.
jtaylor is offline
post #7 of 20 Old 08-13-2015, 07:10 AM
I'd replace it. $200 probably covers a new helmet if the plug lets loose and the bike goes down.
post #8 of 20 Old 08-13-2015, 08:12 AM
carotman's Avatar
Q: What would happen if the plug gets loose?
A: An airleak just like a nail would do...
Just get it patched at another shop. Or, you can get tire plugs and patch it yourself.
carotman is offline
post #9 of 20 Old 08-13-2015, 08:29 AM
Philanthropist
Dave W.'s Avatar
No way would I ever plug a sport bike tire and ride it any longer than what it takes to get to safety & have it replaced.
That tiny patch of rubber is all you have between you and the road.
Dave W. is offline
post #10 of 20 Old 08-13-2015, 08:36 AM
Nickr919's Avatar
I had had 150 miles on my dunlop roadsmart 2 when I needed to get a Plug-patch on the tire. The plug-patch is damn near the center too. 9,000 miles later, and plenty of flogging i might add, still works and i have zero trust issues with it.
Nickr919 is offline
post #11 of 20 Old 08-13-2015, 09:32 AM
deandeib's Avatar
I plugged my last two rear tires with no issues. Put several thousand miles on each after the plug and never had to do anything except just keep riding it. Inside surface inspection after tire replacement also showed zero evidence of problems. Gotta admit, my riding style is not what most would classify as aggressive but wouldn't hesitate to plug again if my current tire ever needed it.
deandeib is offline
post #12 of 20 Old 08-13-2015, 09:52 AM
PHOBMAN's Avatar
I've used plugs and had no problems. Thanks for the kind words, it is a great product even if I do say so myself!
PHOBMAN is offline
post #13 of 20 Old 08-13-2015, 11:56 AM
Good luck.
Agreed. If a repair is done properly and its not to close to the edge it will be good for the life of the tyre.
Has anybody heard of a tyre failure from a punture repair? I have had 2 done and one was on a front PR3 which I did another 11,000ks on.
Hey Kiwiboy, what did you think of the Conti Motions? Grip and last ok? Getting close to needing tyres on the big ole Bandit.
NZspokes is offline
post #14 of 20 Old 08-13-2015, 12:54 PM
Yes, good feel and good grip, quite a soft-feeling compound - got 10,000km out of the rear, don't know if that's good or not - some of these guys are talking about lots more out of Pilot Roads, so you'd have to factor in the life of the tyre vs initial cost.
I did have a bead seating issue with the front, which caused it to lose pressure - there was a recall somewhere for that, so it was obviously something they needed to improve on.
post #15 of 20 Old 08-13-2015, 12:59 PM
Cool, Bandit eats tyres. I got 18,000ks out of PR3s on the Hornet but thats a light weight compared to the Bandit. I got 8,000 out of PR2s on it but a lot of that was 2 up. Thats changing now my beloved has her own bike to ride.
I may give the Contis a shot.
BT016rs are doing well on the Hawk. but will be lucky to get 5,000ks out of them.
NZspokes is offline
post #16 of 20 Old 08-13-2015, 02:58 PM
No experience with bike tires but plugged car tires with poor results. If no one will patch it, have someone like Cycle Gear remove it and have a auto tire shop patch it.
Rode 30,000 miles, till it was worn slap out, on a patched truck tire with no issues. I think a plug effects the belt where a patch won't.
post #17 of 20 Old 08-13-2015, 04:02 PM
Veteran Donation
I've put many miles on a few tires that have been plugged from the inside, Most places are going to call it a Tee plug.
If you ride even a little bit aggressive I would replace it as soon as you can, If you are just commuting ride it to the wear bars.
That said I've also had good luck with Slime. Think of it as fix a flat , before the flat.
Once again I would not use this for fast pace riding .
tvetree is offline
post #18 of 20 Old 08-13-2015, 05:12 PM
Got a roofing nail in my tire 2 hours away from home on a Sunday night. After a two up trip to walmart on the back of my buddy's cb1100. I plugged it with a regular plug kit. Made it home, the following day it was flat.
I did buy motorcycle specific plugs after that which I have more confidence in but still.....I consider them a temporary fix.
nickmarz is offline
post #19 of 20 Old 08-14-2015, 02:58 PM Thread Starter
thanks for the suggestions fellas. me and my buddy are going to do at least one more track day this year, so i think ill bite the bullet and get a new one. but, im going to get my old one patched and keep it around for a spare. or just to mount it up and roast it someday.
tim281 is offline
post #20 of 20 Old 08-15-2015, 07:04 PM
I've plugged a Dakota tire, and 2 back tires on the 919. Never s bit of trouble from any of them.
I think if it holds air for the first few days, you're good to go.
