My turn signal switch broke. - Wrist Twisters
post #1 of 8 Old 04-24-2010, 06:53 PM Thread Starter
curiousmike's Avatar
Thumbs down My turn signal switch broke.
Out on a ride today, and the damn turn signal switch just "went loose."
I'll pry it open later to see if it's fixable, but just in case:
Are there other Honda left-side-switchgear that is a perfect match for the 919?
curiousmike is offline
post #2 of 8 Old 04-24-2010, 09:31 PM
Mine did the same last week. Bought touring919's switch from the bike he's parting out. Harness was pretty simple. For a match other than the 919, I guess you'd be looking for something with a single lamp headlight and 7/8th bars.
jay313 is offline
post #3 of 8 Old 04-25-2010, 01:39 AM
I was going to go to Ron Ayers site and do the "Where is this part used?" option but the site is down. If it comes back up you can go find the part number for the 919 switch and put it into that section. It will tell you if any other bikes use that switch.
post #4 of 8 Old 04-25-2010, 03:31 AM
woodyeee's Avatar
Mine did that when i first bought my bike years ago.....i got a new one on warranty....but while i was waiting for it to be ordered, i took it apart and all it was, was a screw had come loose inside...i fixed it but i still got a new one fitted under warranty!!
woodyeee is offline
post #5 of 8 Old 04-25-2010, 10:17 AM Thread Starter
thanks woodye.. i'll pull it apart and see if i can save myself the $65 from cheapcycleparts.com
post #6 of 8 Old 04-25-2010, 10:52 AM
unfortunately you have to replace it with the right kind of turn signal... not only does that switch the turn signal duties, it also handles cutting the power to the front turn signal running lights on the proper side.
Its probably something pretty simple inside that broke / came loose. I have always found that if a little plastic part breaks, some 5 minute epoxy and 1 layer of fiberglass does the trick.
post #7 of 8 Old 04-25-2010, 11:08 AM Thread Starter
ok, it was the screw. Phew !
The screw (highlighted here in green) was completely out, upside down and trying to escape.
post #8 of 8 Old 04-25-2010, 12:03 PM
lol @ trying to escape.... its a honda its usually the simplest fix.
