My Stebel install on a 919 - Wrist Twisters
post #1 of 28 Old 10-07-2008, 10:04 PM Thread Starter
Shoot to stop
beardking's Avatar
I had a Stebel Nautilus installed on my Honda Nighthawk when I wrecked it this summer. Instead of letting the insurance benefit from my hard work, I took it off the bike before I let them run off with it to the boneyard. Since I got my 919, I've wanted to get it on there. That pathetic excuse for a horn that came with it was just plain dangerous. So, this past weekend, I went about getting it installed.
Typically what you see with a Stebel install is the compressor and horn unit all mounted together in one tidy package. Tidy as in all together, but that doesn't mean it necessarily LOOKS tidy. In fact, they look rather obnoxious to me. So it was my intent on my 919 to go against the grain and make it less visible. What I did was take the horn off of the compressor. Once I did this, I cut off most of the "ears" of the horn that wrap around the compressor. I left enough (by accident, actually) to drill holes in and run zipties through. I then bought about 5 feet of 5/16" ID fuel line from Lowes. I bought fuel line because 1) it was black and would blend, 2) because I knew it was going to be in close proximity to the engine, and therefore would end up a little warm. Below is what I started with:
I took the horn itself and mounted it to the tube that goes in front of the engine and behind the exhaust that you are supposed to mount your frame sliders to (my next project, hopefully). The hose attaches to the horn via a brass 5/16" plumbing barb that was press fitted into the original port that the compressor blows air into. I wasn't to sure how well the horn would hold up to the heat, but so far I haven't had any problems after about 60 miles and a few 100+ mph streaks. If you look really close, you can see where the horn is behind the exhaust here:
As you can tell, the horn is MUCH less obtrusive than the standard install on a naked bike. Or at least it is to me. Since this picture was taken, I have removed the stock horn. Originally I wanted to have both horns function at the same time, but I decided not to mess with the wiring of it. If you look closely at that picture, you should be able to see the fuel line running from the horn. I routed that up over the engine, under the tank and into a space on the left side of the bike under the seat. This picture might clear it up for you where it goes:
As you can see, the fuel line runs into this area and connects to the compressor that was originally attached to the horn. I have zip tied the exhaust port extension back onto the compressor just because I had read where someone else did this and it seemed like a good idea. I installed the compressor in this empty space using a rubber band like thing that I'm not sure what it's original OEM use was supposed to be. I'm assuming that it's actually there for a reason, but for me, it was there to hold down my compressor.
(NOTE: The manufacturer recommends that the compressor be mounted in a vertical position no more than 15 degrees off of vertical. Obviously I have not followed this recommendation. I don't know how this will affect the compressor and any damage that is caused is my own problem. If you choose to follow my lead, and damage that is caused by you mounting your compressor this way is YOUR problem. )
I mounted the relay with super strong double sided tape to an area just above the battery box. You can ALMOST make it out in this picture (sorry, decided to take this picture after everything was back together again).
In all, I think it turned out to be a fairly clean install. Unless you are looking for it, you'd never know I have this horn installed on my bike. I like to keep things hidden like that. Even more, I like to roll up on pedestrians walking down the sidewalk and blast the daylights out of them. I'm a mean guy.
Hope this helps someone else wanting to install this horn.
Beardking
beardking is offline
post #2 of 28 Old 10-07-2008, 10:27 PM
Tirone??
Gotsteam's Avatar
Great Job! I may borrow this great Idea from you in the future when I decide to upgrade my horn! Looks very nice.
2006 Honda 919
States visited on my 919
Gotsteam is offline
post #3 of 28 Old 10-08-2008, 02:08 AM
gosh damned good write up
where can i get one?
post #4 of 28 Old 10-08-2008, 07:31 AM Thread Starter
Shoot to stop
beardking's Avatar
Thanks guys. I hope this was helpful.
www.bikerhiway.com
www.twistedthrottle.com
If you have a Northern Tool or Harbor Freight nearby (or wanna order online) they have them, but they are called a Wolo BadBoy. I've been told that these are exactly the same as the Stebel, just branded different.
One thing to note to anyone that decides to take on this project. When it comes time to separate the horn from the compressor, it's going to seem like you are about to break it before it actually comes apart. Be careful as there are a couple of tabs at either end (if I remember correctly) that hold the horn onto the compressor. These need to be disengaged to get the horn loose.
post #5 of 28 Old 10-08-2008, 07:43 AM
Good wright up BK.
Professional
post #6 of 28 Old 10-08-2008, 07:56 AM
DaveCB919F4
Fastbackdlm's Avatar
One thing the reason they mount them vertical is for draining the condensation.
Fastbackdlm is offline
post #7 of 28 Old 10-08-2008, 08:08 AM
http://www.youtube.com/watch?v=lQqxhRQ1rPE found a clip to hear one ..damn that is loud................. +1
2003 MATTE BLACK 919,POWDER COATED MUFFLER SHEILDS,BAFFLES REMOVED,GIVI 755 WIND SCREEN
BOUGHT 9/9/2008 395 MILES ,2ND BIKE 1983 V65
ROCK HILL, SC
wicked919 is offline
post #8 of 28 Old 10-08-2008, 09:30 AM
we sell them at work... 139 decibels loud as flock!!
the general manager took the demo off of the parts counter and hid it in his office.. it is LOUD
post #9 of 28 Old 10-08-2008, 11:35 AM
STPDSQD's Avatar
Man that seems like a lot of extra effort. I just mounted mine in the stock location in once piece and it looks fine. I think the only thing I am going to change is the red wire that came with the wiring kit. Either that or just wrap both wires in black tape. Can we get some pictures of your install and I'll post a few of mine?
I got no time for the jibba-jabba. - Mr. T
STPDSQD is offline
post #10 of 28 Old 10-08-2008, 01:11 PM Thread Starter
Shoot to stop
beardking's Avatar
Did the pictures in this thread not show up for you?
I originally thought about putting it in the stock location, however I didn't like how low to the ground it was and how it was pretty much in a direct path of anything being flung off the front tire. I knew that with my luck, it'd be a goner within the first week.
post #11 of 28 Old 10-08-2008, 01:18 PM
Nice clean install! I put mine as far forward (LOUD!) as possible... on the HL! YEAH YOU CAN HEAR ME!
dream is offline
post #12 of 28 Old 10-08-2008, 04:00 PM
Ken
Community Admin
Ken's Avatar
Nicely done! Thanks for sharing your project with the masses
2009 Honda Goldwing
Ken is offline
post #13 of 28 Old 10-08-2008, 08:49 PM
doing this mod immediately ..i want a car to think they are pulling in front of a semi
ROCK HILL, SC
post #14 of 28 Old 10-09-2008, 10:47 AM
STPDSQD's Avatar
If there are picutures I'm not seeing them.
When I refer to the stock location I mean I actually reused the flat black metal bracket that the stock horn is on instead of mounting to frame bolt. (This was too close to the header pipes.) I just road 1500 miles throught the mountains with it and no issues. I plan on washing the bike tonight and I'll get some pictures up.
STPDSQD is offline
post #15 of 28 Old 10-09-2008, 11:27 AM Thread Starter
Shoot to stop
beardking's Avatar
Try these:
Compressor location: http://farm4.static.flickr.com/3284/...b1f953ba_b.jpg
Horn location (look behind the exhaust): http://farm4.static.flickr.com/3270/...9be10a4d_b.jpg
What it looked like before I put it on the bike: http://farm4.static.flickr.com/3152/...e30e2e4f_b.jpg
I'm not including the pic of the relay because there really isn't enough visible for it to be useful, but if anyone needs a better pic of where it's at, I'd be happy to get some.
post #16 of 28 Old 10-09-2008, 12:01 PM
Is it just the light in my eyes or did you mount it near the melting headers? The Italian plastic isn't oven rated.
The LOUDEST location is mounted to the HL! Many errand cages have attempted to change lanes without looking, then heard the semi bearing down, and returned back TWO lanes to avoid being taken out by the ferocious 9er!
dream is offline
post #17 of 28 Old 10-09-2008, 01:05 PM Thread Starter
Shoot to stop
beardking's Avatar
Nope, your eyes are not deceiving you. I placed it right between the headers and the engine. I figured if I was going to screw it up, I'd screw it up right. So far it's been through quite a few heat cycles and as far as I can see, there hasn't been any damage caused to the plastic as of yet. When I decided to install it there I figured that the horn had survived a crash so far, maybe it'd be able to survive some heat too.
As for the effectiveness of the Stebel, I'm a BIG fan of them. This thing has save my bacon numerous times (and I have a lot of bacon to save) when it was mounted on my Nighthawk. It may be a little less loud where it's at, but so far it hasn't been subdued enough to become as ineffective as the stock horn was.
post #18 of 28 Old 10-09-2008, 02:08 PM
Ok then I don't need glasses.
As the plastic melts you will get your own custom sound (still LOUD!), flocks of geese will follow you home.
dream is offline
post #19 of 28 Old 10-10-2008, 06:41 AM
STPDSQD's Avatar
Try these:
Blocked at work.
STPDSQD is offline
post #20 of 28 Old 10-10-2008, 08:28 AM
goto proxy.org and you can go around websence.. we do it .... i mean i have heard of it being done at my work
post #21 of 28 Old 10-10-2008, 10:10 PM Thread Starter
Shoot to stop
beardking's Avatar
I musta skipped over this post earlier. Here is what this Stebel sounded like on my Nighthawk.
http://www.youtube.com/watch?v=FBp54sP5nmQ
post #22 of 28 Old 10-12-2008, 08:09 AM Thread Starter
Shoot to stop
beardking's Avatar
Well, after a full week of daily use and being located in what is probably one of the hottest spots on the 919, the plastic on the horn has seen no damage to it. I'm thinking that this location is a keeper.
post #23 of 28 Old 10-12-2008, 09:28 AM
boogerface
mikochu's Avatar
I mistakenly pressed the horn twice while out riding yesterday. Then again, another rider did the same when he went to acknowledge me... I have Hella Supertones on my car, but I think the stock horn is pretty loud. This is a tempting mod, though...
Michael Reyes
mikochu is offline
post #24 of 28 Old 10-12-2008, 09:44 AM Thread Starter
Shoot to stop
beardking's Avatar
If you think the stocker is loud, you'll flip over this one.
post #25 of 28 Old 10-12-2008, 10:29 AM
boogerface
mikochu's Avatar
I was looking at the Nautilus Compact... I saw this video, look at the headlight with the Nautilus installed:
http://www.youtube.com/watch?v=8jnNPUiE37I
Michael Reyes
mikochu is offline
post #26 of 28 Old 10-12-2008, 11:08 AM
bike wasnt running so it was not recharging the battery. Merely using juice and it took from the headlight.
post #27 of 28 Old 10-12-2008, 11:26 AM
boogerface
mikochu's Avatar
True, but I thought it was funny...
Michael Reyes
mikochu is offline
post #28 of 28 Old 04-04-2011, 06:12 AM
veEnom's Avatar
hey beardking, sorry to ressurrect an oil thread, but ive just got a nautilus as well and am preparing to wire it soon. I do like how u have disconnect the compressor from the horn itself. Since you first installed it, has this setup given you any drama, or are you more than happy with it?
Thanks in advance mate.
veEnom is offline
