My rear fender delete - Wrist Twisters
post #1 of 19 Old 06-15-2010, 08:36 PM Thread Starter
Naked bikes = Perma-grin
Asphalt 919's Avatar
Last year I did my own rear fender delete. Figured I'd post up and maybe give some of you food for thought on your own bikes.
First I pulled the entire rear cowl and fender off. I only cut slits in the fender to slip the factory turn signal wiring out. Otherwise the factory fender is undamaged.
Then I slipped on my new pipes for mock up. Cut a piece of alluminum angle braket. I drilled and tapped the bracket to use the factory rear fender fasteners.
I then took my license plate and trimmed around the pipes and drilled two mounting holes for the plate. I also found some Ebay specials for LED turn signals. Took some alluminum flat strap. Bent in vise. Cut, drilled, painted. Mounted them to the factory upper license plate holes. Also on Ebay, picked up two LED license plate light bolts. Mounted them in the lower factory plate holes directing light up at the plate. Tucked the wiring into the factory frame location.
I didn't know if the plate would flex over time, but after 1.5 years and over 6K miles, blasts to max 919 velocity, it looks just like the day I mounted it. I have aprox. $30 in Ebay lights into it. The alluminum bracket pieces were free scrap from work.
While I was at it I also built my own rear stand from Aluminum extrusion. Very rigid works well.
Asphalt 919 is offline
post #2 of 19 Old 06-17-2010, 09:33 AM
05superblackz's Avatar
That looks very nice. I especially like the distance between the blinkers. Is there a tag light?
05superblackz is offline
post #3 of 19 Old 06-17-2010, 10:06 AM
Excellent work and thanks for the photos!
post #4 of 19 Old 06-17-2010, 10:35 AM
Gets censored
I did something similar, seemed like a no brainer too me. I dig the stand! thats nice, it looks nicer/sturdier than the one I bought and you always have the cool "I made it" feeling.
nice work!
brian is offline
post #5 of 19 Old 06-17-2010, 11:34 AM
I like how you pointed the indicators up like that. Looks different. Where in MN are you? I'm down in Lakeville
By the way, why is it everyone blots out the license plate when they post?
2015 Ducati Monster 1200S
FlyCatcher is offline
post #6 of 19 Old 06-17-2010, 12:13 PM
Gets censored
^ cause you can find out someones name, address, and alot of other personall info that wouldnt be readily shared with the rest of the world. You cant control who sees what when you post something on the world wide web.... Unfourtunatley there are some unsavory people out there always wanting something for nothin, or just plain nut bags that'll burn your house down over a keyboard war. Its just a shitty side of people not everyone is a good person.
love your wheels BTW fly... looks, well, FLY!
brian is offline
post #7 of 19 Old 06-17-2010, 12:24 PM
road to success .. where?
melliston's Avatar
Looks great. I like the angle of the plate and the signals.
melliston is offline
post #8 of 19 Old 06-17-2010, 01:53 PM
Hastatus Posterior
Farab's Avatar
What mufflers are those? I like the construction of the DYI stand, thinking out of the square!
Farab is offline
post #9 of 19 Old 06-17-2010, 03:45 PM
Gets censored
Im guessing delvics anyone else wanna take a stab?
brian is offline
post #10 of 19 Old 06-17-2010, 04:04 PM
Topher919's Avatar
Nah.... I don't think it's the Delks, that's what's on my bike, (not pictured to the left)
I'm guessing those are Sato's....
Topher919 is offline
post #11 of 19 Old 06-17-2010, 04:15 PM
Gets censored
Now that you mention it they do look like satos.
brian is offline
post #12 of 19 Old 06-17-2010, 05:55 PM
Satos I'd say - huge outlet and I can just see the name plate on the last photo!
BARWARRRRRRRRRRRRRRRRRRRRRRR
post #13 of 19 Old 06-22-2010, 09:23 AM Thread Starter
Thanks guys!
My tag light are the LED's studs in the lower licence plate holes. They seem to light the plate pretty well.
Pipes are 1st gen Satos Ti. Found them last year on Ebay for $500 new in box from Chicago Cycle. Needless to say I snapped them up.
I've been thinking about making a front stand too. Just haven't got around to it yet.
post #14 of 19 Old 06-22-2010, 09:24 AM Thread Starter
Southwest, out by Waconia. I drive into Eden Prairie for work.
post #15 of 19 Old 06-22-2010, 12:28 PM
Do you ride Hiway 5 into EP? If so you you go right by may place near 5 and Bavaria Rd/Rolling Acres Rd. I haven't seen you yet but I may have heard you.
kcvoje is offline
post #16 of 19 Old 06-22-2010, 01:14 PM
bucky's Avatar
"^ cause you can find out someones name, address, and alot of other personall info that wouldnt be readily shared with the rest of the world."
but you know people can do that too when you ride around, right?
i know ! we should all put actual tape over our license plate numbers and tell the cops we're protecting ourselves against identity theft !~
my plate is RSW 9 and i live at 3131 brookridge. come and get it !
bucky is offline
post #17 of 19 Old 06-22-2010, 02:40 PM
bwoso's Avatar
You live in the culdesac? Good place to live if they ever decide to re-do sewer or water since the lots usually have smaller frontage.
bwoso is offline
post #18 of 19 Old 06-22-2010, 03:29 PM
Nice lookin place! What happened to the garage door on the right?
post #19 of 19 Old 06-22-2010, 08:23 PM Thread Starter
I try not to take 5 very often. Traffic usually sucks. Now that the 212 freeway is open I hit that. Do you live right on 5? My brother worked for Carpentry Contractors and built a couple of those house back on Rolling Acres.
