my 919 dies on me - Wrist Twisters
post #1 of 7 Old 08-17-2008, 06:54 AM Thread Starter
Question my 919 dies on me
I have a 07 919 with 3k on it. At an idle, when I apply the front brakes at times, the bike would die (only happens with the front bakes). There is also a ticking sound in middle relay underneath the seat when applying the front brakes. The dealership sevice department have no idea whats wrong. Any input is appreciated. Thanks.
mario is offline
post #2 of 7 Old 08-17-2008, 08:57 AM
Trackday Recognition Veteran
Where's Rob when you need him?
Sokali is offline
post #3 of 7 Old 08-17-2008, 10:03 AM
Probably won't help but are the two wires to the front master cylinder hooked up? I have not heard of them causing this but know first hand they can cause other electrical grimlins.
Bryce919er is online now
post #4 of 7 Old 08-17-2008, 04:01 PM Thread Starter
I think these wires are for the brake lights. Right?
mario is offline
post #5 of 7 Old 08-17-2008, 06:37 PM
Back in the day
Hondad's Avatar
My son had the same problem on his 06 919. Use the search feature using "front brake turns engine off". This should be what you are looking for.
Hondad is offline
post #6 of 7 Old 08-17-2008, 08:01 PM
Here is a thread concerning an intermittent fuel pump that will give you a starting point on your problem. Posts #8 and 12 have all the information necessary to get a good start on your problem.
https://www.wristtwisters.com/forum/s...ad.php?t=14216
In your case, concentrate on sections one and two of the troubleshooting tests, and add checking the common ground on the Right side of the frame near the rear of the fuel tank, the bank angle sensor connector under the intake snorkel on the opposite side of the frame from the ground, and the integrity of the connections to the battery. One of the most important functions of the battery while the engine is running is to act as a sort of filter for the somewhat electrically noisy charging system, and it "fills in" the output voltage when a sudden large load is applied until the voltage regulator catches up (perfectly normal), such as the sudden four amp load applied when the brake light comes on. Believe it or not, a battery connection may be slightly loose and still enable starting by the sudden load from the starter actually welding the loose connection together temporarily, but when normal vibration breaks these welds the connection isn't good enough to prevent noise from the alternator or load spikes from causing improper operation of the ECU.
From your description of the buzzing noise from the fuel pump relay it sounds like a bad ground or power connection to it.
Good luck, and don't hesitate to post any questions or requests for clarification: that's what we're here for!
post #7 of 7 Old 08-17-2008, 08:10 PM
Yes.
