motovation frame slider installation - Wrist Twisters
post #1 of 11 Old 10-29-2007, 04:47 PM Thread Starter
yaoyichi's Avatar
Hello folks,
I just bought the motovation frame slider, but I don't have the tools to ream the frame...and I don't really want to buy those tools...
Does anyone of you recommend any place in LA that I can bring my bike and the frame slider and let them install it for me?
Thanks!
yaoyichi is offline
post #2 of 11 Old 10-29-2007, 04:53 PM
Toll Runner
str8ghtjacket's Avatar
Go buy the drill bit and save the cash theres atleast two write ups on here that will walk you through it .This is the one Motocycho did, should work the same for yours. easy breezy, str8
https://www.wristtwisters.com/forum/s...ead.php?t=1518
str8ghtjacket is offline
post #3 of 11 Old 10-29-2007, 04:56 PM
Speed Lover
XRCajun's Avatar
Where in LA are you?
XRCajun is offline
post #4 of 11 Old 10-29-2007, 06:01 PM
Similar except there is no need to tap & thread. Just drill a clearance hole for a #10 threaded rod.
post #5 of 11 Old 10-29-2007, 06:49 PM
Not Banned
Tk919's Avatar
yea I have those same sliders and they where cake.. 20min's tops ... all yea need is a drill and a 10mm bit.. and a 17mm deepwell socket and just ream it out a little.. you only have to go maybe 1/2 -3/4 inc in on both sides...
Tk919 is offline
post #6 of 11 Old 10-29-2007, 11:09 PM Thread Starter
yaoyichi's Avatar
I am near Culver City.
Thanks guys, I think I am going to get a drill if I cannot find a shop this weekend...
yaoyichi is offline
post #7 of 11 Old 11-12-2007, 10:39 PM Thread Starter
yaoyichi's Avatar
Finally I got a drill and follow the instructions to ream the frame. I can now insert the rod into the frame, and it is nicely penetrate to the other side of the frame.
It's not the end of the story...yet...
However, when I follow the instruction (http://www.motovationusa.com/Install_900Hornet.html) to "Clamp the threaded rod and thread one of the locknuts till approximately 5mm of thread is protruding.", the rod is nowhere protrude the locknut since there is a blue plastic thing on the locknut which block the rod (I attached the photo).
Do I need to do anything to remove the blue thing? As you can see in the photo, I try to remove it, but it seems attach to the locknut pretty well.
Thanks for any answer guys!
BTW, I got the drill and bit from local COSTCO (LA), a set of kawasaki powerdrill, quite handy.
yaoyichi is offline
post #8 of 11 Old 11-13-2007, 04:36 AM
Speed Lover
XRCajun's Avatar
Okay I'm going to recommend first that any time you need work done on your bike that you go seek out someone who knows mechanic work. Preferrably a bike shop.
That blue thing is what makes the lock nut a lock nut do not remove it!
Put it back on the all thread, take some pliers and grab the allthread in the middle and screw the nut on as per instructions. Then continue with intructions.
XRCajun is offline
post #9 of 11 Old 11-13-2007, 10:20 AM Thread Starter
yaoyichi's Avatar
Thanks, I really know nothing about the mechanic work
I'll try again and definitely go to a shop if I failed...
yaoyichi is offline
post #10 of 11 Old 11-14-2007, 02:05 AM Thread Starter
yaoyichi's Avatar
I did it!
I had a friend hold the use the 17mm socket on one side and use the power drill on the other side to screw the locknut.
Thanks XRCajun and folks!
yaoyichi is offline
post #11 of 11 Old 11-14-2007, 05:51 PM
BrokeRecord
Wrenching
You gotta start some where. I got my start when I dropped the set screw for the points down inside the distributor on my beat up 1955 210 sedan.
brokerecord is offline
