McRomo44's 919 Tank Grip Pad Templates - Wrist Twisters
post #1 of 11 Old 03-05-2010, 07:19 AM Thread Starter
A number of people have asked for them over time.
I just discovered the pdf file somehow got screwed up and split the second page in two.
If anyone wants the repaired template pdf file, just say the word. Send a PM with an e mail address that will accept attachments.
post #2 of 11 Old 03-05-2010, 07:58 AM
you have a PM
omaha_919 is offline
post #3 of 11 Old 03-05-2010, 12:52 PM
sorry i'm not quite sure i understand. what is this?
post #4 of 11 Old 03-05-2010, 03:11 PM
Another PM, thanks
post #5 of 11 Old 03-05-2010, 06:02 PM Thread Starter
If you want to put tank grip pads on, I found no templates existed for the 919.
I bought do it yourself kits of Tech Spec "Snake Skin" and got out the drafting kit and went to work.
We're talking about grippy rubber pads on the sides of the tank that your legs won't slip and slide all over on, like they will on a painted tank at Track Days.
It also cuts down heat loss on cold days when your jeans are touching an ice cold tank.
post #6 of 11 Old 03-05-2010, 08:34 PM
hmmm, sounds interesting! how much?
post #7 of 11 Old 03-06-2010, 05:27 AM
Ballaholic
hornet919's Avatar
lol he isnt selling you the grip stuff, he is giving you a template to cut the grip stuff out
hornet919 is offline
post #8 of 11 Old 03-06-2010, 07:51 AM Thread Starter
Thanks hornet919, you answered for me !
post #9 of 11 Old 03-06-2010, 08:11 AM Thread Starter
Someone asked about tools and tricks.
1
Do the layout work on the back of the grip pad.
2
I did my long line cutting with Wiss MPC-3 general purpose shears.
3
I did my tight radius cutting with Wiss M7 left hand turn sheet metal shears.
If I was a left handed cutter, I would have used a M6.
4
I did my edge chamfering with a right angled grinder with a hard disc on it.
(the typical rigid fibre type that comes standard fitted with such grinders)
5
Clean the tank with Windex, and make sure all wax etc is gone so the grip pad can have max stick to the paint.
6
I used painters tape on the tank for the second side re the top grip.
Used the first side as a datum, then mirrored the forward most point and ran the tape edge to there. This is not really necessary, but it helps, especially if you find yourself moving the pad around to get the perfect spot. At least a bit of tape at one point or two will give you additional reference points to compare to as you do any slight relocations in an effort to find that perfect spot.
7
The upper grip pad is on the ragged edge of what can be made to fit and not lift off at the top edge due to tank curvature. Take your time aligning before touching, but the Snake Skin can easily be pulled off and re-contacted until you have it exactly where you want it.
8
I used a heat gun to set the adhesive.
(It was too cold when I did it)
Don't do this in your garage with the door closed !
The gasoline starts cooking off light ends and the tank vents and it smells and is a safety hazard.
Better is a hot day in the sun, but if you don't have that, a heat gun works, and much better than a hair drier.
(My heat gun is a red hot wire coil forced hot air type. It is ancient, but I assume they still exist)
post #10 of 11 Old 03-06-2010, 10:50 AM
Hippie Tinkerer
mntnceguy's Avatar
Which ones are we talking about here? I used the templates from sbeau1960's thread called "Tank Grip" and they were great
http://i196.photobucket.com/albums/a...Pattern919.jpg
https://wristtwisters.com/naked-bikes...tank-grip.html Thread link
Maybe if we've got more than one option now these threads should be combined and stickied...or added to Mr. Mikes helpful topics sticky? Just a thought....
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #11 of 11 Old 03-06-2010, 11:13 AM Thread Starter
The ones being discussed here are ones I cooked up on my own.
I have not seen the ones you referred to.
My guess is that mine go beyond, as there are 3 pieces for each side, not just one as is the norm. I have way more area gripped.
I would love to give the picture and templates to a guy like Mr. Mike so he could add to most excellent info, if he wants to. In any event, my intent is nothing more that to save someone the time I spent doing coming up with the design work. Ideal would be making them accessible on the web for anyone to access anytime they want. I do not know how to do that.
