lowering the 919 - Wrist Twisters
post #1 of 3 Old 01-16-2010, 08:58 PM Thread Starter
lowering the 919
hi i just wanted to see if anyone has lowered there 919 , and if so where did you get the kit to do this?my bike was perfect when i got it ,but after i put my corbin on it is a little tall for me me to flat foot at stops im 5'10.any help is appreciated thanks....charles
TROYAIK88 is offline
post #2 of 3 Old 01-16-2010, 10:02 PM
Hi Charles,
If you let the air out of the tires, it will lower the bike a bit...
Only kidding. This question has come up a time or two before, if you're an avid reader you can find it using the search function... but I will try to sum up....
You can safely raise the fork legs in the triples by 10mm without compromising handling...in fact, many riders prefer the quicker turn-in this provides...
Due to how the rear shock attaches to the swingarm, there is no way to attach a dogleg linkage or anything similar...and there really is no good way to reduce the shock length to achieve a lower overall height. Penske and Ohlins both offer excellent aftermarket shocks for the 919, but the length is the same as OEM.
As long as you can touch toes on both sides, I don't see a real issue, but your results may vary. The Corbin seat does raise the seat height by an inch or so, and I'm sure it's comfy...There are other companies that offer seat improvements, including lowering the seat height by removing foam and or reshaping the seat. Sargent Seats is one such company. if it really bothers you not being able to "flat-foot" on both sides, and a seat mod by a different company doesnt' suit, go back to the stock seat!
Best of luck to you, and while you probably won't be satisfied by my reply, I hope you enjoy your 919...they are great bikes!
post #3 of 3 Old 01-17-2010, 12:32 AM
Tonight we ride
Nemo's Avatar
My bike came with a Corbin seat that had me on my tiptoes, too. Sold it.
I bought a spare stock seat from EBay and had Sargent re-do it--lowered the seat by 3/4", and added gel to the rider and passenger's seat area, moved the rise of the seat forward a touch, and re-covered it with grippy vinyl. I'm quite happy with the result, and Sargent's turnaround time was a touch less than they said, under 2 weeks.
Nemo is offline
