Leo Vince Cans, Plugs, 16000K service - Wrist Twisters
post #1 of 13 Old 08-06-2007, 09:51 AM Thread Starter
wisco919's Avatar
I am getting ready to dive into another winters worth of projects on my '02 919. I have some concerns with the Leo Vince slip ons I am planning to purchase. The Manufacturer states that the F.I. system does not need any modification with the slip on cans. Should I assume this is correct and go ahead with out or will a Dynojet unit, Quality map benifit my bikes performance?
Plugs.
Is there any real advantage to the NGK iridiums vs standard recommended NGKs?
16000k service.
I know there will be little need to concern myself with calibrating valves (I will check clearances) But is there anything else important I should be concerned with? Ie, Cam chain tensioner, Injector calibration.
I am already planning the PAIR block offs, drive sprocket, jetcoat header and Y-pipe, new clutch. Is there more I should do while the niner is tore down?
wisco919 is offline
post #2 of 13 Old 08-06-2007, 08:08 PM
Scott
Wraith53089's Avatar
I have the Leo Vince slip-ons and haven't installed a power commander yet there is some improvement in performance but still think the PCIII will make a big difference as my bike seems to run too rich.
I contacted the techs @ Leo Vince via e-mail and they told me that the PCIII maps for the Satos would work well with their exhaust. I will try it when I've saved enough money.
The Vince's come with the Y pipe and the pipes from the Y back to the cans.
I have been very happy with them.
You will have to remove the rear shock and spring to get the Y pipe in place. but the job is fairly easy I did it in the garage after work one night and rode to work the next day.
Good Luck. Oh and by the way I live in Sussex WI so if you need any help I'd be happy to lend a hand just send me a PM and we can go from there.
Scott
Wraith53089 is offline
post #3 of 13 Old 08-07-2007, 06:32 AM
Front fork maintenance.
Is it winter up there already?
post #4 of 13 Old 08-07-2007, 09:10 AM
Naked in Cheese Land
Anti-Shadows's Avatar
Wisco - maybe we should get a group discount from JetCoat - The only things left to black out on mine are the header and the swing arm
You Milwaukee area 919's going to brave the weather for TWT tonight?
Anti-Shadows is offline
post #5 of 13 Old 08-11-2007, 06:56 AM Thread Starter
wisco919's Avatar
Scott
Nice to meet you Scott,
Thanks for the info on the Leo Vince System. This is the reply I was interested in getting. I will plan on getting the power commander with the exhaust. Thanks
wisco919 is offline
post #6 of 13 Old 08-11-2007, 06:59 AM Thread Starter
wisco919's Avatar
HJ, I am just getting myself prepared. I travel quite often for work and will be gone for a good portion of fall. I had just done my fork spring upgrade changed fluid etc.
wisco919 is offline
post #7 of 13 Old 08-11-2007, 07:02 AM Thread Starter
wisco919's Avatar
I will be at TWT this week Anti-Shadows. I would be interested in a bulk rate if we can do it. Most likey be going to the TWT at Lulu's.
wisco919 is offline
post #8 of 13 Old 08-11-2007, 11:47 AM
i got a lot of popping under deceleration using the leo vince end cans without PC III . a tad too loud even with baffles on.
smokin is offline
post #9 of 13 Old 08-11-2007, 05:27 PM
I purchased the CF Leo's in 2003. They make a great product. In 2004 I installed the Power Commander (USB) and noticed a huge difference. I can't recall which map I used, but it was one that used after market pipes and air filter. I recommend buying the Power Commander.
rippinbyu is offline
post #10 of 13 Old 08-11-2007, 08:29 PM Thread Starter
wisco919's Avatar
Thank you for all of your input gentlemen.
wisco919 is offline
post #11 of 13 Old 08-12-2007, 01:41 AM
I am doing the same thing this winter on my 02 919. I am only at 11000 kms but they were quite rough(big guy lots of hard stops and gravel roads) so I am going to do the forks ,change the springs to heavier aftermarket ones (any suggestions?) service the brakes and install some better lines on the front.
One thing I have noticed is my clutch and front brake need to be adjusted I bet some of you guys are in the same boat. Because it happens so gradually it is hard to notice. It is also time for a new front tire.
Unsub is offline
post #12 of 13 Old 08-13-2007, 06:51 PM
For the front forks use Race Tech, you can calculate on their web site www.racetech.com what spring rate to buy. I also suggest you get the the valve kit makes a big difference...
wedge24 is offline
post #13 of 13 Old 08-13-2007, 10:17 PM
See you there!
