Left Passenger Peg Set Screw Fell Out - Wrist Twisters
post #1 of 23 Old 10-13-2008, 07:27 AM Thread Starter
Tirone is the Cool Dude
Timmy S's Avatar
The screw that keeps a little "flange" on the pin that goes through the hole in the peg on the left hand side passenger foot peg has gone awol. I was wondering if anyone knew what size screw this was? Is this screw something I have to get at Honda or can I get it at the local hardware store? Note, the right side peg does not have this style pin with set screw arrangement for some reason so I cannot remove that one to check. Many thanks.
Tim
Timmy S is offline
post #2 of 23 Old 10-13-2008, 08:25 AM
you can check ronayers.com on their fiche and see if you can find it. At least then you will know what it is. You will probably be able to order from them as well
2015 Ducati Monster 1200S
FlyCatcher is offline
post #3 of 23 Old 10-13-2008, 08:37 AM
mine was the same way when I bought the bike, I went to the local honda and he just gave me a screw that fit it, all I had to do was chop it down to the right height, all for $0 .
So I'd think that it's just a universal screw, according to bikebandit.com it's a 4X8 screw
Epicsoldier is offline
post #4 of 23 Old 10-13-2008, 08:38 AM
I Love Parallel Twins
Naked/SS's Avatar
Mine had fallen out also, funny you should say that. Anyone else missing theirs?
JDubya
Harleyville, South Carolina
USA
Naked/SS is offline
post #5 of 23 Old 10-13-2008, 08:38 AM
Asymmeterical foot peg arrangement?
The first time I saw that on my bike, I thought what the h.......
That little feature is one of the nearly unnoticed cost cutting measures on this bike.
post #6 of 23 Old 10-13-2008, 08:44 AM
If you take apart the passenger pegs you'll notice the weights are different, I believe this was done for balance or vibration.
post #7 of 23 Old 10-13-2008, 08:48 AM
Mine is also missing
post #8 of 23 Old 10-13-2008, 08:53 AM Thread Starter
Timmy S's Avatar
Thanks All for your speedy answers. I did look the part up on Ronayers.com and the part number is 93500-04008-0A which indeed is a 4x8 pan head screw. It sells there for $0.39 plus shipping, I will try locally and you can be sure I will locktite the threads upon installation.
PS. I did locktite the RH bar weight and am keeping an eye on the LH side one and the shifter pivot "bolt" the usual suspects for vibrating loose. As usual wristtwisters comes through.
Timmy S is offline
post #9 of 23 Old 10-14-2008, 01:28 AM
I've had a weird vibration sound between 4k and 5k rpms. Just noticed the nut and bolt missing from the lower left (if sitting on bike) radiator support.
IIRC someone else had a radiator bolt loose, or missing.
nate is offline
post #10 of 23 Old 10-14-2008, 03:58 AM
NAKED & IN LUV
GLENN's Avatar
bolt is not missing it is held in by a rubber grommet .
GLENN is offline
post #11 of 23 Old 10-14-2008, 02:40 PM
mine is missing, but have had passengers and then never noticed so I haven't bothered fixing it.
post #12 of 23 Old 10-14-2008, 11:32 PM
I'm going riding.
scrat's Avatar
eh, my screw fell out also, maybe 4-5k miles ago...found one in the drawer that looked right, red loctite, still holding...
scrat is offline
post #13 of 23 Old 10-15-2008, 05:56 PM
yep, mine is missing, found one that fit and red loctite as well so far so good.
hutcho is offline
post #14 of 23 Old 10-16-2008, 03:38 AM
:scratches head: The other side has a screw in it....
nate is offline
post #15 of 23 Old 10-16-2008, 08:09 AM
Ahhh man....now I gotta go look
dadogs is offline
post #16 of 23 Old 11-29-2008, 07:25 AM
CB900
rockdog32's Avatar
Mine is missing from new too!!
rockdog32 is offline
post #17 of 23 Old 11-29-2008, 07:38 AM
The solution:
post #18 of 23 Old 11-29-2008, 06:04 PM
Hey mister mike, What did it cost you to get those sets cut down and finished? Looking to do that to my wifes bike.
post #19 of 23 Old 11-29-2008, 06:34 PM
In all honesty, I have a close friend who is a machinist. I bought him a nice lunch. The parts should be milled to give them a professional look. Call around, a local machine shop should be able to hook you up.
post #20 of 23 Old 11-29-2008, 08:56 PM
I just had it done and the guy charged me an hour (which is $100 in my area). I was worth it to me, because he put a really nice angle/edge on it to it look "natural."
sike is offline
post #21 of 23 Old 12-01-2008, 11:27 AM
Tonight we ride
Nemo's Avatar
Verry interesting--I looked at my 919 last night, and sure enough, the same radiator bolt was missing. Must be a spot prone to vibration. Its replacement will be getting some blue Loctite!
Nemo is offline
post #22 of 23 Old 12-01-2008, 01:12 PM
+1 Glenn
post #23 of 23 Old 12-01-2008, 03:09 PM
Franklin McGillacutty
riquefied919's Avatar
There is no bolt.......there is no bolt.........there is no bolt.......do you guys get it now????
Oh by the way.......there is no bolt.
riquefied919 is offline
