LED Turnsignals and Brakelights - Wrist Twisters
post #1 of 12 Old 12-29-2009, 08:17 PM Thread Starter
swimdog's Avatar
Running electric gear and heated grips, what do you all recommend for LED turnsignals and brakelights for stock 919. Interested in high visibility and lower power draw.
swimdog is offline
post #2 of 12 Old 12-30-2009, 09:08 AM
Hippie Tinkerer
mntnceguy's Avatar
Surprisingly enough...your not the only one...or the first one for that matter...so whatever you do...don't search the site...there is absolutely no info here regarding modifications or technical know how at all...
Seriously tho, search the site...
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #3 of 12 Old 12-30-2009, 09:30 AM
Ballaholic
hornet919's Avatar
if EVERYONE searched, there would be no new threads and site would be dead
hornet919 is offline
post #4 of 12 Old 12-30-2009, 09:41 AM
What type heated grips are you using? I'm lookin' into them now trying to decide which kind and so far the Oxford's are in the lead... I'm also looking into brake light modulators and a kit from Electrical Connection to turn the rear turn signals into running and brake lights when the signals aren't being used. The kit uses LED rings and shows red even through the amber lenses.
post #5 of 12 Old 12-30-2009, 04:48 PM
check out my thread.
https://wristtwisters.com/naked-bikes...liminator.html
got em off ebay for like 17 bucks a pair... have worked out great.
OH and bought a led blinker relay from china off ebay for 4 bucks so my blinkers wernt on steroids
post #6 of 12 Old 12-30-2009, 09:55 PM Thread Starter
swimdog's Avatar
Been using these. May not put out the heat of the Oxford. but go under your exsisting grips Very satisified. Ride year 'round and use "hippo hands" in real cold weather and don't have to use bulky gloves.
Heated grips is the question and our Dual Star Heated Grip Kit is the answer!
If you ride in wet or cold conditions you know that safety and control of the motorcycle can be severely compromised by cold aching hands.
Keeping those paws warm increases endurance and riding enjoyment (many riders claim that heated grips help to reduce forearm pump which can result in numb hands and wrists). No need to wear big bulky gloves, now you will have no problem keeping your hands warm! This kit is on our top ten GOTTA-HAVE-IT list!!
Mylar tape-style dual stage heating element (4" x 2 3/4") wraps around and adheres permanently to the handlebar beneath handgrips to provide toasty comfort at high or low temperature settings. Extra long 32" insulated wires are then routed along existing cables/looms. These tricky little items allow you to use the handgrip of your choice! 12-volt system draws only 36 watts on the high position.
High quality 3-way toggle switch and connectors included
We use only 3M (VHB) Very High Bond adhesive
Design specific element wattage for each side
Hi-Low resistor has been eliminated! Yes!
Does not require a battery in the system
Compatible with our excellent Grip Cement
Extra long 32" insulated wires!
swimdog is offline
post #7 of 12 Old 01-01-2010, 01:50 PM Thread Starter
swimdog's Avatar
Alright Mr. Search Police-searched with negative results for LED turnsignals and brakelights that simply replace stock bulbs that arer high visibility. Not interested in integrated solution. Looking for lower power draw and safety. Any recommendations?
swimdog is offline
post #8 of 12 Old 01-01-2010, 04:21 PM
i have these in the rear: 2 SUPER AMBER 24 LED TURN/PARKING LIGHT BULBS 1156
and these in the front: 2 AMBER 24 LED PARKING/TURN SIGNAL LIGHT BULBS 1157 2057
videos of comparison. crappy video as it was a cell phone at the time. when i get the bike back together i can do a better comparison.
front: front.3gp - Windows Live
rear: rear.3gp - Windows Live
with leds i always try to get the most leds possible. I have never had anyone complain of never seeing my turn signals and never have had close calls with it. I just make sure i use them every time.
you have a lot of room for bigger bulbs in the turn signals also with the tail lights (tail lights and headlight are the only lights on the bike regular bulbs) i am getting ready to put leds in the rear as i have a blown bulb in it.
i am thinking of these for the turns in the future: 2 AMBER SMT 27 LED TURN SIGNAL LIGHT BULBS 1156 1073
however i got stuff i'd rather do on the bike.
barmatt80 is offline
post #9 of 12 Old 01-05-2010, 05:58 AM
blur
drewvir's Avatar
i bought these
LED TURN SIGNAL ASSEMBLY HONDA CBR600 CBR900 VTR1000:eBay Motors (item 250377643836 end time Jan-17-10 13:06:18 PST)
got them with the running light option. made of billet alum. not crappy plastic.
bright enough to see in daylight
drewvir is offline
post #10 of 12 Old 01-05-2010, 06:22 AM
Clear alternatives TS lens and bright yellow bulbs. Plus Electrical Connections LED rings for running lights. CA for LED Brake and RL too. There are visible!
dream is offline
post #11 of 12 Old 01-05-2010, 03:55 PM
How doy like the Electrical Connection rings? I saw one of your previous posts about them, could I bother you for mre details and pics?
post #12 of 12 Old 01-05-2010, 08:16 PM
They work fine. Be careful installing the rings, not to break the bulb, plus have to run extra lines to the bulbs and splice in the diode circuit. You got to be a little handy to splice and tape insulate it or you could short out your lights. It's lasted a couple years no problem. Could I have spent a lot more for a twin bulb solution...sure. Hope that helps.
dream is offline
