IT'S ALIIIIIIVVE!!! - Wrist Twisters
post #1 of 9 Old 02-15-2012, 05:52 PM Thread Starter
Needs training wheels.
Brewcrew02's Avatar
IT'S ALIIIIIIVVE!!!
As of right now the bike is up and running! Could have even gone for a ride but had way more shit to do. Here's the fucked up thing...
EVERYTHING is back in tip top working order... except my left front turn signal. I've switched between 3 diff. lights but each time I plug in a new one, it stays lit! All others function properly. When I turn on the right side, the left goes out. When left on and when neither engaged, the front left just stays lit. WTF!!!!!!!!!!!!
Brewcrew02 is offline
post #2 of 9 Old 02-15-2012, 06:11 PM
blur
drewvir's Avatar
stock turns or 2 with after market?
drewvir is offline
post #3 of 9 Old 02-15-2012, 06:24 PM
check the wiring inside the bucket. use a multimeter to figure out which one is ground, constant positive (running lights) and the switched blinker. I belive your looking for the solid orange wire. \ If you know how to use a multimeter I would use it anyway. That way you know for sure what's going on. With that multimeter you should read the orange wire with the white stripe as a constant 12 volts.
post #4 of 9 Old 02-15-2012, 06:32 PM
ariannasdaddy's Avatar
pinched wire!!
Remove the cover to the signal light, check voltage from each wire with meter. If the are both "hot" they have been shorted together. One should pulsate at 1 pulse per second (given correct flash rate)
Arte et Marte
ariannasdaddy is offline
post #5 of 9 Old 02-17-2012, 01:12 PM Thread Starter
Brewcrew02's Avatar
Ok, so for the ever lovin' life of me I can't find the pinch or cross or god knows what. Prev owner had both blinkers running off the blue wires. Don't know how but it worked. I found the orange harness and plugged it back in. Right side solid blue and ground=good blink. Left side ground and striped blue=constant on. When the right is switched on, left side goes out. Same on the orange side. So I know it's somewhere before the split. I wanna say the problem is inside the switch on the bars, but I have no way to tell. I know how to use a multimeter but I don't think it'll help in this situation. Any ideas appreciated!
post #6 of 9 Old 02-17-2012, 04:34 PM
blur
drewvir's Avatar
right side is green=ground
light blue
lt. blue with white
left side=
green = grnd
orange/white tracer
white tracers are running lights
drewvir is offline
post #7 of 9 Old 02-17-2012, 06:53 PM
lusting over something...
james_kraska's Avatar
IIRC: I did the same thing when I soldered new contacts for aftermarket turnsignals. Front and back DO NOT use the same color coding for polarity. Reverse polarity and problem solved.
james_kraska is offline
post #8 of 9 Old 02-17-2012, 10:22 PM
blur
drewvir's Avatar
no rear is same
green=gnd
orange=left
lt. blue=right
according to the diagram in the service manual
drewvir is offline
post #9 of 9 Old 02-18-2012, 02:16 PM Thread Starter
Brewcrew02's Avatar
Wired back to stock and everything is back to normal! Thanks guys
