Is this thing working! (Temp gauge) - Wrist Twisters
post #1 of 17 Old 08-19-2010, 08:04 PM Thread Starter
Whiterabbit1980's Avatar
So first let me say this could be a very stupid question.
Now with that out of the way. I just finished putting on a new rear tire and chain. Fired her up and took her for a little test ride. No problems, but when I got back home I smelled something burning. This was not a big concern since I had been cleaning while I was installing the new parts. But when I reached my hand down near the engine, it seemed really hot. I checked the temp gauge and it was running a little above the break in the line. Again this could be dumb but I don't remember the engine being so hot that you couldn't at least touch it for a short amount of time. After all when I ride during January here in Colorado I place my hands on the engine to warm them up.
Does anyone know how to diagnose a faulty temp gauge
Some tech notes: The coolant level is where it should be. No resent fiddling with the cooling. The bike is completely stock in the engine and drive train. Except the new chain is a DID 530VA 114 links (which is almost to long for the bike, adjusted it out almost to the mark for the service limit). New rear tire is a Dunlap Roadsmart 180-55.
Thanks
Whiterabbit1980 is offline
post #2 of 17 Old 08-19-2010, 08:07 PM
Sixty-9er
edgecrusher4444's Avatar
Should be about there on the gauge while running, fan kicks on at around halfway up. Sounds normal. Not really something that goes bad.
"Grip it and Rip it!"
edgecrusher4444 is offline
post #3 of 17 Old 08-19-2010, 08:16 PM
Speed Lover
XRCajun's Avatar
If you run the engine more than a couple of minutes you should not be able to just leave your hand on the head! The head probably gets up to about 180/90 degrees.
XRCajun is offline
post #4 of 17 Old 08-20-2010, 08:45 AM
Seems like mine gets way too hot to touch.
2526 is offline
post #5 of 17 Old 08-20-2010, 09:36 AM
how many miles does your 9'er have? When did you last do a coolant change? I agree with you most days I can have my hand on the head to warm them up and it doesn't burn. Just when the temp is above 85 that touching the head becomes a high risk factor.
07919Dave is offline
post #6 of 17 Old 08-20-2010, 09:53 AM Thread Starter
Bike is an '02 with 32k on the clock. Coolant was last changed in the fall of '08 when I first got it with 14k. I was planing to change it this fall before the weather changes.
Rode to work this morning and everything seems to be fine (except I may have to take a link out of the chain - that's what I get for just looking at the manual with out check here first ). Like I said probably a stupid question, but I thought I'd check.
Thanks for the help guys!
post #7 of 17 Old 08-20-2010, 11:22 AM
Yeah I would say just change the coolant to be safe. I thnk the OM says every 24K but look at what it says for you chain..... Unless I get stuck in traffic on I25 my fan never kicks on and I stay just above the tick in the line.
post #8 of 17 Old 08-20-2010, 11:29 AM
mambomonster's Avatar
It's around 90 degrees in south FL and I just finished a grocery run. If I touch then engine it will definitely leave a mark. This picture shows my temp range - never gets past the halfway point. Sitting for a few minutes at that temp allows me to steam vegetables in my pants legs.
mambomonster is offline
post #9 of 17 Old 08-20-2010, 12:42 PM
You have vegetables in your pants? .....hmmm......
post #10 of 17 Old 08-20-2010, 01:30 PM
Well, he said he made a grocery run.
post #11 of 17 Old 08-20-2010, 01:39 PM
Total Awards: 17
those were Idaho potatoes
zaq123 is offline
post #12 of 17 Old 08-20-2010, 01:57 PM
I haven't actually tried it yet, but there is so much heat coming up from below when I'm stopped I know that I could at least thaw a bag of frozen veggies.
Luckily I live very close to the supermarket because otherwise I'd have to insulate the inside of my top box so that nothing would melt. Hmm, a Givi cooler doesn't sound like a bad idea anyway.
post #13 of 17 Old 08-20-2010, 02:05 PM
Total Awards: 17
Just get this grocery getter
zaq123 is offline
post #14 of 17 Old 08-20-2010, 02:30 PM
Hey! I resemble that comment!
*I am from Idaho and have a potato field yards from my house*
post #15 of 17 Old 08-20-2010, 02:36 PM
I worked at Albertsons as a teenager and we stopped shoplifters all the time. I guess my first mental image of you as you walked out would be a clerk saying "Sir, can I see what those bulges in your pants are?" and "Do you plan on cooking them before you get home?".
post #16 of 17 Old 08-20-2010, 03:18 PM
+1, I thought about adding a drain valve to my top case so I cold fill it with ice and, umm, soda & water...
post #17 of 17 Old 08-23-2010, 05:48 AM
blur
drewvir's Avatar
just make sure you put them in the front of your pants..........not the back
drewvir is offline
