Is this sound normal upon acceleration? - Wrist Twisters
post #1 of 13 Old 05-22-2020, 03:52 PM Thread Starter
Recently acquire a 919 with very low mileage and I noticed when I accelerate in 1st and 2nd it would make a tapping or ticking sound around the 2k-4K rpm range.
I don’t think the sound is normal but I wouldn’t know since the bike is still new to me.
Not my video but you can hear it at the 2:02 mArk when he accelerates. Seems like a few people hears the same sound too. Should it be something to worry about?
Here’s the link
https://youtu.be/d0mdjaAzgr0
Deegaw1126 is offline
post #2 of 13 Old 05-22-2020, 04:11 PM
I donít think the sound is normal but I wouldnít know since the bike is still new to me.
Hereís the link
I just listened to most of the vid' and early on heard a reedy sound that seemed to be from forward on the bike.
It made me wonder if perhaps you have the infamous vibrating headlight mounting assembly gremlin.
Check the following link out, keeping in mind to look for the pure vibration posts as compared to the vibration induced electrical connection failures. There's posts including the RPM range of the buzz, as well as a few different fixes, should that be your problem
https://www.wristtwisters.com/forums...ons-28152.html
post #3 of 13 Old 05-24-2020, 11:09 PM Thread Starter
It’s definitely not a vibration sound. I’m starting to wonder if it’s a cam chain tensioner noise. I read a lot of post about the noise but nobody ever mention anything about the ccts. Do these bikes have cct issues?? I had a f4i in the past and they had issues with their cct.
The noise is only present around 2.5k-4K rpm range whether you accelerate or idle. I do notice the noise almost goes away tho when it warms up but still slightly audible. My bike is an 07 and only has about 3600 miles.
post #4 of 13 Old 05-24-2020, 11:13 PM Thread Starter
In the video when he takes off from 1st to 2nd you can hear the sound. It sounds like something’s rattling.
post #5 of 13 Old 05-25-2020, 06:51 PM
Pokemon Master
I hear the noise, and mine makes a similar noise, but I'm not sure what it could be. Mine has 52,xxx miles, runs great and uses no oil between changes, so the noise is probably not terminal. I do know these bikes have loud fuel injectors.
2007 919, 2013 CB500X, 2009 Buell XB12R, 20+ bicycles
Darth_Firebolt is offline
post #6 of 13 Old 05-25-2020, 07:15 PM
In the video when he takes off from 1st to 2nd you can hear the sound. It sounds like somethingís rattling.
I went back and listened to pre through post 2.02 minutes time frame and can't hear anything abnormal.
post #7 of 13 Old 05-25-2020, 07:18 PM
Iím starting to wonder if itís a cam chain tensioner noise. I read a lot of post about the noise but nobody ever mention anything about the ccts. Do these bikes have cct issues??
919s as a classification don't have cam chain tensioner issues, including those that have be mercilessly flogged forever.
post #8 of 13 Old 05-25-2020, 09:58 PM
If you lug these engines you can get valve train rattle.
post #9 of 13 Old 05-26-2020, 06:29 AM
nathanktm's Avatar
There's a particular noise that seemingly every 919 makes. It's the injector noise, it's pretty loud, and you hear it good in the lower rpms. I wondered what it was as well, the bike always did it and has done it for the last 50k miles of abuse. Oil analysis says everything is golden, despite the track days and what not. I'm gonna go out on a limb here and say your bike is fine.
Also, watching that guy ride makes me cringe with his clutch work
nathanktm is offline
post #10 of 13 Old 05-26-2020, 12:07 PM
Originally Posted by nathanktm View Post
... watching that guy ride makes me cringe with his clutch work...
OMG +1!!
It's all I can see when I'm watching - who on earth told him to pull the clutch in every time you shut the throttle?
K1w1Boy is offline
post #11 of 13 Old 05-26-2020, 05:14 PM
EVERY forum EVER has numerous threads re My engine ticks.
My MO is: Let that son of a bitch blow up, so I can buy a new one. But I've yet to blow s anything up. Ok, at least not in the last 40 years. There was that CR125 back in 1980.
I have a John Deere lawn tractor that I'd swear is going to put a rod thru the block at any minute. But it's sounded like that for years.
Sniper-x is offline
post #12 of 13 Old 05-26-2020, 10:51 PM Thread Starter
Yes I read numerous threads of people saying it’s the injectors or piston slap. I had a few Honda bikes in the past but none of them ever made that noise in any rpm range and I don’t ever lug the engine at all.
I’ve only had the bike for a week so it’s still pretty new to me. I guess I feel better hearing it from you guys that clocked so many miles on it and owning it way longer than I have.
post #13 of 13 Old 05-26-2020, 10:56 PM Thread Starter
If you don’t hear the noise then most likely yours don’t make that sound. As soon as I heard it in the video I recognized the sound and mine makes the same sound around 2.5k-4K rpm in 1st and 2nd gear.
