is it normal... - Wrist Twisters
post #1 of 20 Old 09-06-2006, 12:17 PM Thread Starter
put your ad here
4manhilt's Avatar
is it normal...
with my bike on the rear stand it makes a slight clicking noise while spinning the rear wheel. honestly i can not remember it ever making this noise until today after i adjusted the chain. i took the bike for a quick spin and rechecked the adjustment. everthing seems a o.k. but, it is still making a clicking noise (sounds like nothing more than the chain making contact w/ the rear sproket). i just don't remember ever noticing this before. anyone?
Most problems in life can be fixed... Stupid isn't one of em'.
4manhilt is offline
post #2 of 20 Old 09-06-2006, 12:20 PM
The "Eagle" Has Landed
Aquila-RC51's Avatar
Mine - when I had it - has always done that.
Aquila-RC51 is offline
post #3 of 20 Old 09-06-2006, 12:21 PM
Chain possibly binding? When is the last time you cleaned and lubed it? Is it in the exact same spot on each revolution?
dadogs is offline
post #4 of 20 Old 09-06-2006, 12:22 PM
Wookie
ragdoll's Avatar
Mine does that same thing... my sprocket is in much need to be replaced. Check yours out.
'02 RC-51
'10 Unicycle
ragdoll is offline
post #5 of 20 Old 09-06-2006, 12:23 PM
Now you just run around and make that clicking sound with your mouth. Hey on the upside you should be able to pick up Zimbabwe chicks with ease!
Jebus......I just derailed a thread in 4 posts.......sorry
dadogs is offline
post #6 of 20 Old 09-06-2006, 12:34 PM
The RC?!
Mine doesn't "click".
...and you're gonna ride it to Jennings?!
h ryder is offline
post #7 of 20 Old 09-06-2006, 12:37 PM Thread Starter
put your ad here
4manhilt's Avatar
my first thought as well. but after double checking my marks and rechecking torque on my axle nut everything seems OK. i cleaned my chain two weeks ago. and the clicking seems to be every sprocket tooth, not once a revolution. i would be shocked if i needed a new sprocket. i only have K on the bike and everything has been maintained. like i said - everything looks o.k., i just had never noticed this noise before and wanted to hear your thoughts.
mark
4manhilt is offline
post #8 of 20 Old 09-06-2006, 12:47 PM
Originally Posted by h_ryder View Post
The RC?!
Yes, it did. It was like a whirring kinda noise with a low noise slight clicking.
post #9 of 20 Old 09-06-2006, 12:50 PM Thread Starter
put your ad here
4manhilt's Avatar
ahhhh... exactly... i think. i almost thought it was the bearings before i got down close.
4manhilt is offline
post #10 of 20 Old 09-06-2006, 12:50 PM
The RC?!
Since the RC was made in Japan ... it goes "CRICK".
RC51_CBRXX is offline
post #11 of 20 Old 09-06-2006, 12:53 PM
dadogs is offline
post #12 of 20 Old 09-06-2006, 12:58 PM
I'm on my 4th rear tire & of all the chain adjusts, never noticed a "CRICK".
Now I'm gonna have to go check...
h ryder is offline
post #13 of 20 Old 09-06-2006, 01:02 PM
You go check RC now. Makee sure it no go crick crick. Crick crick is no good.
One time, I lide by lee Led Dlagon Lestaulant, and RC go Crick. I checkee de tire and all da chain, butee see no leason why it go crick crick.
post #14 of 20 Old 09-06-2006, 01:07 PM
Uh huh an den?
dadogs is offline
post #15 of 20 Old 09-06-2006, 01:23 PM
Yeah, it's normal. More than likely what you are hearing is the chain contacting the countershaft (front) sprocket because that is louder than on the rear sprocket (this is because the chain has to travel around a tighter radius and that creates more noise). You will notice that the sound is almost non-existant right after lubing the chain, but is louder if it has been a while since lubing.
motorwerks919 is offline
post #16 of 20 Old 09-06-2006, 02:23 PM
Church of the Holy Smoke
MotoCycho's Avatar
mark
Did you adjust the chain while bike was on the center stand? If so, then it's too tight. That would account for the 'crick' 'crick' sound. The bike's chain should be adjusted with the weight of the bike on the rear suspension. It can be done on the side stand, but its lame. Best is to use a rear stand or get a helper to hold bike upright. If you used a rear stand, in theory, you could also get it too tight by lifting the bike from a point too far forward of the axle. Ideally, you want to lift the bike as close to the axle as possible but still be able to get to axle nut and adjusters with your tools. with the bike on the side stand, measure the free play. Find a spot in the middle of the lower chain section. Place your ruler next to the chain and pick a place you will measure, the top edge or bottom or middle of the link.. doesn't matter, just use the same spot for both ends of the measurement. Pull the chain down snug and set your ruler's zero mark on your chosen spot.. then push chain up and read the same spot. 25mm to 40mm is spec for the 919. I like the looser side of that.. 35 to 40mm. If you have less play.. then re-adjust.
Enjoy!
Crick crick!... He he!
- Rev. CYCHO -
MotoCycho is offline
post #17 of 20 Old 09-06-2006, 03:02 PM Thread Starter
put your ad here
4manhilt's Avatar
Enjoy!
used rear stand.
always place stand right at (in front of) welds on arms.
chain is adjusted properly.
still have clicking (cricking).
thanks for all the help. ill mess w/ it some more tomorrow.
1
4manhilt is offline
post #18 of 20 Old 09-06-2006, 03:08 PM
Is the bike Japanese ?!!? Maybe it's talking to you... "crick, crick..."
post #19 of 20 Old 09-09-2006, 08:09 PM
My ex has an R1 and her bike was making the same type of sound. We checked the chain and lubed it. No joy. She had to get a new back tire anyways, so she took it to the local dealer. When they took the tire off, they found a spacer missing from the rear tire. Didn't get to see exactly where it went, but they replaced and the crick crick was gone.
post #20 of 20 Old 09-09-2006, 10:17 PM
Lethal with Whiffle-Bats
Caleb_I's Avatar
This sounds very similar to the noises my friends 919 made,, but his was louder...
I went and checked mine, earlier, and it had the slight clicking noise...
after the dealership, and a mechanic that was very well trusted checked averything on my friends bike, his reccomendations were to go back with a stock chain, as some aftermarket chains might have thicker, or larger size links... which can make a slight noise,, ifnot that then he reccomended changing sprockets and chain next time,, of course this will be the third chain, so probably about time to change sprockets as well,
I guess if your not extremely anal about cleaning the sprockets and chain often, just the mere wear and tear of sand, dirt etc.. have its way...
please re-post if you get a solution...would like to know what else is happeneing...
Caleb_I is offline
