individual pod filters - Wrist Twisters
post #1 of 60 Old 01-13-2010, 05:00 PM Thread Starter
Ballaholic
hornet919's Avatar
anyone run a set up of 4 individual pod filters on the 919? just curioues if it has been done, or what kind of possible affects, positive or negative, it could have on the bike.
hornet919 is offline
post #2 of 60 Old 01-13-2010, 05:04 PM
Go for it then report back.
post #3 of 60 Old 01-13-2010, 05:40 PM
Don't do it.
This will not work effectively at all.
The fuel injection system relies on the airbox mounted IAT (Inlet Air Temperature) and MAP (Manifold Absolute Pressure) sensors to do never ending mass flow corrections for the ECU, which responds by modulating the fuel injector pulse widths in order to give you the correct amount of fuel injected. (Other inputs are ECT ((Engine Cooling Temperature sensor)), TPS (( Throttle Position Sensor)) and RPMs.
Not only that, some individual pods can actually reduce flow into the injector body, due to poor air flow / aerodynamic properties.
Be glad you asked ! You've been saved !!!!
post #4 of 60 Old 01-13-2010, 05:42 PM
I should have added<sarcasm> to my post
post #5 of 60 Old 01-13-2010, 05:48 PM
Have a nice evening MM, and yours was clearly a "gotcha".
post #6 of 60 Old 01-13-2010, 08:11 PM
drivit's Avatar
thanks for the laugh
drivit is offline
post #7 of 60 Old 01-14-2010, 12:51 AM
Speed Lover
XRCajun's Avatar
I think you'd also find you'd be sucking warmer air from behind the cylinders than you do from the side of the bike. Sounds like a bad idea for this FI bike for sure!
XRCajun is offline
post #8 of 60 Old 01-14-2010, 04:49 AM
UJM
Banned
Side mount velocity stack or ram air
Call it good
UJM is offline
post #9 of 60 Old 01-14-2010, 04:58 AM Thread Starter
Ballaholic
hornet919's Avatar
ok, scratch that idea lol
post #10 of 60 Old 01-14-2010, 11:20 AM
take the cover of the airbox off, bolt up a ram air type setup, then add a pod to that. then you keep everything MM talked about and you get a pod as well.
post #11 of 60 Old 10-13-2014, 10:28 PM
Hmm, this is funny. For the 919, MAP sensor is external to the airbox are they not? If I recall, they are connect directly to the throttle bodies. And IAT can easily be mounted to any one of the pod filters. I know this is an old thread. But I dislike how people discourage others from modding just because they don't like it or not capable of doing it.
cychotic is offline
post #12 of 60 Old 10-14-2014, 01:59 AM
Honda919Rider #1
You're oh so right.
Individual filters would work great, just remove the fool injection, add a set of carbs and call it good.
Just don't complain about the huge hole in the powerband, or any of the other reasons that no one runs them any longer - they don't work as well as a modern, well designed resonance chamber aka the airbox.
We're not complainers, we're modifiers! And that flat spot makes the engine feel like it has a real powerband, just like the good old daze!
You're right, no one should ever discourage anyone from doing anything that will have a totally negative effect on their motorcycle, just does not make sense, jeez, what are these people thinking!
Reminds me of when I tried to talk my sister out of voting for Obama. It was not happening, she was totally mesmerized by him.
She feels beyond stupid now, probably a similar feeling to how it would feel to putting individual air pods on a 919 and having to live with the results.
Steve is offline
post #13 of 60 Old 10-14-2014, 06:58 AM
Originally Posted by Steve View Post
You're oh so right.
You know steve, there are times when your contributions are less than helpful... and then there are posts like this where you really redeem yourself and I'm glad you're around to say something so I don't have to...
post #14 of 60 Old 10-14-2014, 07:43 AM
Right, because all pro racer use OEM airbox... All motogp bikes use oem airbox as welll... And no one can do any better... That's not even the point. The whole point of doing it is modifying it to your own taste, whatever that is... Again, don't judge it just because YOU don't like it.
cychotic is offline
post #15 of 60 Old 10-14-2014, 10:11 AM
The point is, if you want to make your bike worse for... I guess I don't know why you'd want pod filters? Looks? becuase you have nothing better to do? That's your prerogative... it's our prerogative to tell you you're stupid... becuase it would be... Next thing you're going to tell us is that we should lower our bikes and our cars cuz hellaflush is super cool
post #16 of 60 Old 10-14-2014, 11:43 AM
Just add LED lights on EVERYTHING. Then everything will be OK.
post #17 of 60 Old 10-14-2014, 12:15 PM
But then the air filter pods will blind other drivers....
post #18 of 60 Old 10-14-2014, 01:54 PM
Total Awards: 17
the best part..... you probably don't even realize that this isn't the first post Steve made in this thread
zaq123 is offline
post #19 of 60 Old 10-14-2014, 02:09 PM
Haha! That's awesome & ridiculous all at the same time.
post #20 of 60 Old 10-15-2014, 02:14 AM
Total Awards: 17
good old days........
zaq123 is offline
post #21 of 60 Old 10-15-2014, 06:16 AM
So that's what he was called before he got banned....
post #22 of 60 Old 10-15-2014, 07:01 AM
He got banned? Again? I guess we should expect to see a new member named NotSteve soon. :P
post #23 of 60 Old 10-15-2014, 07:52 AM
Total Awards: 17
You guys are toug crowd. I think Steve is still here??
zaq123 is offline
post #24 of 60 Old 10-15-2014, 11:20 AM
He's a registered thread offender.
post #25 of 60 Old 10-16-2014, 12:32 PM
People think motorcycle is stupid. Why would you remove two wheels when four gives you better traction, safety and control? Did that stop you? Should I call you stupid too? Because its hella cool being on 2 instead of 4? Yea...Maybe you just need to understand what perspective means.
cychotic is offline
post #26 of 60 Old 10-16-2014, 12:58 PM
I'm not sure that that is really the same thing... also, I have much better traction and control on my bike than in any of my four wheeled vehicles. and you could call me stupid, but then you'd be a hipocrite becuase you ride as well... when people that do the same things think something is stupid they have a little more validity than someone who knows nothing about something saying it's stupid
post #27 of 60 Old 10-16-2014, 01:48 PM
No not really. The best 4 wheeler will always be better than the best 2 wheeler in terms of handling and performance. The physics is clear.
cychotic is offline
post #28 of 60 Old 10-16-2014, 01:59 PM
I was unaware that I own lamborghini... And even then I find it hard to believe that a car will beat a bike... regardless, I said nothing about the best vs the best.. I said my bike vs my vehicles.
post #29 of 60 Old 10-16-2014, 02:01 PM
Well I think its stupid that you got a 919 instead of the 900rr. Same displacement but you lost so much top end. Yea, honda is so stupid for making the 919. Why would they sacrifice so much? They should have known better to only allow the best to be on the market.
The point is that people will think anything they don't like as stupid. Nothing wrong with pod filters of its done right. Not being optimal is not wrong either. Its just not the best.
Again, different perference doesn't make you stupid.
cychotic is offline
post #30 of 60 Old 10-16-2014, 08:18 PM
Honda919Rider #1
It sounds like you are the one doing the judging.
All I did was state a few facts.
Do whatever you want, Lord knows I have - and will continue to do so.
To each their own
And if I want to state a few facts, then be accused of being judgmental, so what - It's the internet, I have no idea who you are. I know that it appears you have some great skills in making some really cool parts.
Like many bolt on parts - it's not going to make better power, and in fact, it might hurt overall performance.
That's never stopped anyone before, sure isn't going to in the future. Some worship style, some power, others -
MOTORCYCLES
I remember working as a service manager and having to install those really cool fake supercharger air filters, with the vacuum operated throttle plates, in the front -
They killed power, but they sure looked cool.
Ramble mode off -
And badmoon692008, thanks for the kind words, much appreciated.
Steve is offline
post #31 of 60 Old 10-16-2014, 08:21 PM
Honda919Rider #1
Posts like that might make you look stupid though
Get over it and move on. Show us the filters on your bike, tell us how it works, suck it up and get back to contributing more cool stuff.
Steve is offline
post #32 of 60 Old 10-16-2014, 08:30 PM
Honda919Rider #1
I've been in Detroit all week for a conference, man, that town is a mess. It made East St. Louis and Camden NJ look good, really good.
Anyway, the presentation by Boston Dynamics that was incredible.
Check this out - Boston Dynamics: Dedicated to the Science and Art of How Things Move.
And this AM, Boeing, blew me away. Then one of the planes I came home on was one of the one's discussed - the 737-800. I've always loved the 737 series, and the 800 is awesome.
The other presenters, well, I've got several pages of note to go through tomorrow. And I'm looking forward to it!
Anyway, you want to talk about be being banned, get the names right.
UJM, H9R, Honda919Rider, I forget them all.
And banned from multiple forums over the years, been in some of the bloodiest forum wars there ever was, witness true evil, there are some truly evil people in this world.
Shit happens.
Any of you want to stir up any crap with me, bring it on.
You want to let bygones be bygones, fine by me.
One fact I'll toss out -
I have no control over you.
Doh!
Steve is offline
post #33 of 60 Old 10-16-2014, 09:20 PM
If my mockery sounded stupid, then I made my point.
cychotic is offline
post #34 of 60 Old 10-17-2014, 03:40 AM
Honda919Rider #1
You did made yourself sound stupid.
If that was your point, you made it, "for sure for sure"
Steve is offline
post #35 of 60 Old 10-17-2014, 10:11 AM
No it is stupid.
The airbox on the 919 does have a specific tuned resonance to compliment the size of the throttle bodies, tract lengths and cam phasing. Altering that resonance will move your power curves around in a fashion that is not beneficial to the mid-range response the engine was designed for.
You are correct MotoGP bikes do not use OEM airboxes, because MotoGP bikes are prototypes purposely and by the rulebook not built on OEM platforms. Their airboxes are designed to work with the specific engine requirements for each bike. WSBK machines use altered airboxes also to conform to the needs of the engines which are derived from production bikes, but vastly altered. There are however several Superstock & Supersport classes that do indeed use the OEM airboxes.
Here is an article I wrote after years of testing different air filters on various bikes.
ROGUE RC51 Airfilter questions page
This is a test of a larger volume aftermarket airbox on an otherwise stock engine that actually loses horsepower compared to the OEM airbox.
ROGUE RC51 Large Displacement Airbox
post #36 of 60 Old 10-17-2014, 10:56 AM
Indeed, different preference does not make you stupid... being stupid sure does though...
post #37 of 60 Old 10-17-2014, 01:03 PM
I want ram air for my 9'er. Free horsepower right there.
post #38 of 60 Old 10-17-2014, 06:59 PM
Honda919Rider #1
If you route the under seat exhaust just right -
Add a secondary fuel injection system for some Mystery Oil -
You could truly blow smoke up your own arse!
Combine that with the rickard919 ram air, you'll have a 250mph 919!
Steve is offline
post #39 of 60 Old 10-18-2014, 05:14 AM
LDH, excellent info. Thanks for that. But was it stupid for you to try that out? Why did you do it anyways?
What the other two clowns don't understand is that I am fully aware of how OEM airbox is tuned for a specific powerband. Not all OEM airbox are optimal either, it doesnt make these manufacturers stupid for not having the best. All I am saying is let people try what they want. Downgrading isnt exactly stupid. Now they are still trying to convince me that I don't understand that pods will change the performance and that they are somehow less stupid than I am.
Stupid is if you sheepishly follow what people on forums says and not fully understand what's at stake.
cychotic is offline
post #40 of 60 Old 10-18-2014, 11:13 AM
Honda919Rider #1
Name calling is always a sign of brilliance
cychotical
Steve is offline
