Idle issues - Wrist Twisters
post #1 of 14 Old 05-16-2006, 10:57 PM Thread Starter
Idle issues
Hey Guys,
At idle my bike doesn't seem to run very smooth. I would think that it should sound like a smooth hum, but it sounds like ba bum ba bum ba bum. Sorry, that's the best I can describe it. Right now I have Sato exhausts and a power commander, which I believe has the proper map since I bought it from Dan Kyle, (I really don't know anything about the Power Commander) and I did the flapper mod. I bought the bike about two weeks ago and it was completely stock and hadn't been ridden since 2003. (1600km) Even though the idle doesn't sound like I think it should, the bike runs very good. Is there problem with the bike, or is this normal?
pags is offline
post #2 of 14 Old 05-16-2006, 11:34 PM
Church of the Holy Smoke
MotoCycho's Avatar
Originally Posted by pags
Hey Guys,
What kind of motorcycle is this? I assume you have a 9er? Does it smooth out a bit once it's fully warmed and has been ridden? Mine runs exactly the same til its fully warmed.. and I mean warmed and ridden a few miles.
- Rev. CYCHO -
MotoCycho is offline
post #3 of 14 Old 05-17-2006, 12:50 PM Thread Starter
Idle issues
Yes it is a CB 900/919. When the bike is cold, the sound definitely is more pronounced, but at stop lights it still isn't a nice smooth hum.
pags is offline
post #4 of 14 Old 05-17-2006, 12:53 PM
The niner always had a slightly lumpy idle, I wouldn't be concerned about it.
dadogs is offline
post #5 of 14 Old 05-17-2006, 01:02 PM
just for s&g's... throw in a new set of plugs???
...maybe ya got a plug w/ wrong gap or high resistance.
h ryder is offline
post #6 of 14 Old 05-17-2006, 01:30 PM
MidTN9er
Guest
Posts: n/a
Mine hovers up and down at idle around 900 - 1100rpm. It's always done that, especially when it was cold. After a good warm up, it was less noticeable by ear, but you could still see the gauge bumping.
post #7 of 14 Old 05-17-2006, 02:27 PM
goodhorsey's Avatar
I've also noticed that my idle goes up and down according to electrical needs. If I'm sitting at a light, and the fan goes on, or a blinker is on, the idle will increase, sometimes as high as 1400 or 1500. I guess this happens so that the charging is accomodated.
goodhorsey is offline
post #8 of 14 Old 09-02-2010, 09:25 AM
I just replaced the plugs, correct gap, stock recomendation, and it still idles rough. Not crazy rough, just bouncy. I wish I had a brand new 919 to compare it to, but I'll just hope it's normal.
det5lonewolf is offline
post #9 of 14 Old 09-02-2010, 10:11 AM
I just walked to the parking lot and took a short video of my 919 idling. Is this what your bike is doing?
http://www.youtube.com/watch?v=jKfFxql_f5M
post #10 of 14 Old 09-02-2010, 10:52 AM
dang u guys idle your bikes high... i have my idle set down to like 800-900 rpms.... but like everyone else, its a little lumpy... just like in the vid above... typical idle sound.
post #11 of 14 Old 09-02-2010, 11:28 AM
I don't know the exact number, but I think it recommends between 1,200 and 1,300 RPM idle.
post #12 of 14 Old 09-03-2010, 09:02 AM
YouTube - 919 Idle
Yep. Your'se sounds more dramatic at the pipes, but the needle looks the same.
Page 1-5 of the service manual calls for 1200 +/- 100 rpm idle. Cold or warm? IMO my bike has too strong of engine braking when cold. I just put new plugs and still idles twitchy. Finally back to OEM brakes though.
post #13 of 14 Old 09-03-2010, 09:07 AM
I set idle when warm. In the video, the bike is still warm. I rode it to eat lunch, then filmed this about 15 minutes after getting back.
post #14 of 14 Old 09-03-2010, 11:25 AM
Originally Posted by pags View Post
Hey Guys,
I'm in Calgary too.
I have Yosh TRSs and a PCIII.
It has been custom mapped, and idles smooth.
When I ran LordDuckHunters v-4 Moriwaki based map it ran very well and idled nicely.
1
Have you synchronized your PCIII to your ECU ?
If not, that could be at least part of the problem.
2
Which Dan Kyle map ?
If it is his 2002 map that was based on the original large bore Satos, it is a max power mapping that is too rich for normal street riding.
Download the map to your laptop or PC.
Look at the notes.
If you see A/F comments about low/mid/high and full and numbers from 12.7 to 12.9, then you have the rich max power type map.
Worse yet, that dyno work was done at sea level. We are at 3500 ft. The ECU absolute air pressure corrections for air density are not perfect once you get too far away from the altitude the dyno work was done. (I think that intake flow inertia vs inlet friction losses is part of why this is.)LordDuckHunter has commented in the past, that 4000 ft altitude difference is the limit from dyno work to useage work, if you want sharp fueling.
2
You may have got a PCIII with nothing more than their standard PCIII map in it, which is not that good.
3
Do you have access to a laptop or PC?
Are you familiar with this stuff ?
If you want help, PM me, and you can come to my house and I can help you with it.
If you want LDH's very good map, I have it.
If you want a copy of the custom map that Ben Wheeler at Redline in Calgary did for me, just say so. It's free.
