I think I'm comming down with something... - Wrist Twisters
post #1 of 11 Old 07-18-2007, 06:43 AM Thread Starter
Ordered the renthal lows, pazzo levers, and dominator dual headlights. Damn you guys. Next is mirrors.
Anyone have a set of stock headlight mounting brackets, I'd like to get a set powder coated, but don't want to decommission the bike to do it. Otherwise, I'll wait for the snow before I do it.
919rugger is offline
post #2 of 11 Old 07-18-2007, 06:55 AM
Warning!!! The 919 can be hazardous to your wallet.
post #3 of 11 Old 07-18-2007, 07:07 AM
Ken
Community Admin
Ken's Avatar
Welcome to the Local Modaholics Anonymous Chapter. Please stand up and introduce yourself
2009 Honda Goldwing
Ken is offline
post #4 of 11 Old 07-19-2007, 11:29 AM
You don't NEED to have this part powdercoated - a can of primer and a can of semi-flat black and your bike is only down for a couple hours. Mine was ridden daily all winter in the rain and held up just fine.
post #5 of 11 Old 07-19-2007, 09:24 PM Thread Starter
Well, I ended up with a spare set of mounting brackets, so I'll give the spray paint a shot. Thanks for the tip. Did you do anything before priming other than clean it?
post #6 of 11 Old 07-19-2007, 09:38 PM
Go'n So slow I'm stopped
xrmikey's Avatar
xrmikey is offline
post #7 of 11 Old 07-19-2007, 10:30 PM
Bikeless Rider
Patmicg's Avatar
i spray painted everything on my bike mostly including the engine block and tank and i store my bike outside 24/7. The paint has held up really well and shows no signs of ware. Spray paint is a good and cheap solution.
I sanded everything with at least 600 grit sometimes 800 grit befor primering and painting
-Pat McG
Patmicg is offline
post #8 of 11 Old 07-19-2007, 10:48 PM
Ben
HondaStreetfigh's Avatar
Now you need Galfers, some grab rail caps, and maybe an interceptor's single sided swing arm!
2 > 4
HondaStreetfigh is offline
post #9 of 11 Old 07-20-2007, 05:09 AM
Ken
Community Admin
Ken's Avatar
...and Sato Exhaust, Sato Rear Sets, Power Commander III, Galfer Wave Rotors, Galfer Front & Rear Brake Lines, Speed Bleeders, Clear Alternatives Tail Light LED Board, Slingshot Racing Gas Cap, Flapper Mod, Motovation Frame Sliders, Circuit 1 Left Side Cover, Sargent Seat, PAIR System Block Off Plates, Front Turn Signals. the fun has just begun 919rugger
2009 Honda Goldwing
Ken is offline
post #10 of 11 Old 07-20-2007, 08:19 AM
DaveCB919F4
Fastbackdlm's Avatar
I paint cars, bikes, whatever. Use good paint and prep well. Most of the paint jop is in the prep. Use a good wax and grease remover like PPG DX330. and a scotch brite scuff pad (gray is good red if its really tough). Make sure everything is as clean as you can get it. Most important thing is have fun.
Fastbackdlm is offline
post #11 of 11 Old 07-20-2007, 10:45 AM
I probably didn't do it 'correctly' but it worked. I didn't have any special cleaners so I cleaned them with a spray household cleaner and then rubbing alcohol. I gave them 2 coats of spray primer and 3 coats of paint. They held up all winter in the Seattle rain without an issue. However, if you can do it correctly, I'd recommend that.
