How to swap out a,b throttle cable?? - Wrist Twisters
post #1 of 18 Old 10-23-2007, 04:20 AM Thread Starter
Not Banned
Tk919's Avatar
Has any of you swaped out the A and B trottle cable on the 919? If so tips to make it easyer would be helpful..
Tk919 is offline
post #2 of 18 Old 10-23-2007, 09:14 AM Thread Starter
Not Banned
Tk919's Avatar
so no one has changed a throttle cables on a 919 ........??? or its such a easy thing no one will answer ...??
Tk919 is offline
post #3 of 18 Old 10-23-2007, 11:25 AM
It's a Honda! Seriously, I hear they are a PITA to replace.
post #4 of 18 Old 10-23-2007, 11:40 AM Thread Starter
Not Banned
Tk919's Avatar
yea.. from looking at it I can see it will be...a pain in the A$$ Cant deside witch side is easyer to get into the radiator hose side with would involve removing 3 or so hoses or the vacuum line side , i dont wana mess with the vac-line side.. water hose side looks easyer.. tanks allready off so that's not a issue.. I guess its something i just gota figure out... gots lots of time to work on it. 1800$ in parts to put back on and thses throttle lines have to be first.......
Tk919 is offline
post #5 of 18 Old 10-24-2007, 03:35 PM Thread Starter
Not Banned
Tk919's Avatar
well, I managed to get it done.. only took 8 hrs ... .. what a nightmare...
Tk919 is offline
post #6 of 18 Old 10-25-2007, 01:09 PM
bucky's Avatar
one wonders why you had to replace it.
well, this ONE does.
bucky is offline
post #7 of 18 Old 10-25-2007, 01:11 PM
bucky's Avatar
and dude, ask us more than 24 hours before you plan to begin ! i made a special tool out of a box end 10mm wrench for this job and could have guided you. but i don't look here every day.
bucky is offline
post #8 of 18 Old 10-25-2007, 08:36 PM
...maybe they were ripped off in an accident....but what do I know...
motorwerks919 is offline
post #9 of 18 Old 02-08-2008, 11:28 AM
bucky's Avatar
i worked from the left side mostly. "when in doubt, remove it and make room", says Mr. Fat-hands. i took a 10 mm box wrench with "fine graduation", perhaps a 16 point? i ground probably 130 degrees out of the circle of the box wrench. a standard open end wrench didn't get me the ability to chip away at loosening the locknuts on the t/body end of the cables. with my special tool, i was able to take little 25 degree swings of the wrench, remove it , grab the next "purchase" and take another 25 degrees.
i didn't actually replace my cables, but i've removed the throttle body several times in the course of modding it for nitrous plumbing clearance
bucky is offline
post #10 of 18 Old 02-08-2008, 11:55 AM
Rich Jura's Avatar
That is a rule I wish that I understood much sooner in my wrenching life.
The other one an old timer ( I'm older now than he was ) when I was 16.
" If you're sweating you are doing something wrong"
Think I was close to 30 when I finally grasped that one.
Later
Rich
Rich Jura is offline
post #11 of 18 Old 02-08-2008, 12:00 PM
Trackday Recognition
Later
Rich
damn then i'm changing tires by hand all wrong...
blueblur is offline
post #12 of 18 Old 02-08-2008, 12:04 PM
Rich Jura's Avatar
Good One.........I also do them by hand.......lots of swearing along with the
sweating.I do find tire irons very helpful, saves my fingernails.
Thanks
Rich
post #13 of 18 Old 02-08-2008, 01:16 PM
i want some of the bead buddies that No-Mar makes...
but then again i do work for a bike shop and can use the changer any time i want. i'm just too much of a procrastinator and end up doing it the night before a track day
blueblur is offline
post #14 of 18 Old 02-08-2008, 05:11 PM
just had to show you all the add that popped up under this thread for me... is that you, bucky?
i'd like to replace the throttle cable myself, only because the fittings where the cable attaches to the throttle tube are corroded and look like crap. from the honda schematics, it looks like these fittings are part of the cable and can't be replaced seperately.
...j919
j919 is offline
post #15 of 18 Old 02-11-2008, 11:50 AM
bucky's Avatar
thanks for the spontaneous vomiting.
no.
that ain't me.
http://en.wikipedia.org/wiki/Buckminster_Fuller
bucky is offline
post #16 of 18 Old 08-09-2011, 06:27 PM
Bring this one back from the dead. Yup it is a PITA job. Bring lots of patience and beer as well as very long needle nose pliers. Took ma about 5 hours in total. Lube them while they still work guys.
post #17 of 18 Old 08-09-2011, 07:23 PM
Point taken, lube throttle cables added to list of rainy day maint.
post #18 of 18 Old 02-25-2019, 03:48 PM
I remembered this one and just pulled it up for the present inquirer.
