Horn stopped working? - Wrist Twisters
post #1 of 6 Old 05-27-2010, 12:50 PM Thread Starter
Question Horn stopped working?
My horn stopped working and I don't know why.
I have checked the horn itself and it is functional.
I have checked the fuse and it is fine.
I have checked the switch and it is working.
I checked the wiring and power is getting to the horn but no sound.
I don't know what else it could be.
Anyone got any ideas? Thanks!
garyb900 is offline
post #2 of 6 Old 05-27-2010, 01:15 PM
power might be getting to the wires at the horn... but a connection could be bad along the way so that you dont get enough amps to power then horn.
post #3 of 6 Old 05-27-2010, 01:33 PM
Just to clarify...if you put 12 volts directly to the horn, are you getting sound?
post #4 of 6 Old 05-27-2010, 02:16 PM
jclong74's Avatar
The contacts in the horn my be dirty. There is a bolt with a locknut on it. Loosen the lock nut and run the bolt in, this will put the contacts together and should help get rid of any dirt on the surface, of course the horn will sound once the contacts are clean
2006 919 (Sold)
2011 Cb1000r
jclong74 is offline
post #5 of 6 Old 05-27-2010, 03:24 PM Thread Starter
Thanks for all the help guys.
I figured it out. I was using my noodle properly.
I thought the horn was functional because I tired two other horns I had laying around and they didn't make any sound either so I figured it was not the horn.
Turns out all three horns I had were bad!
I went to my auto mechanic and he checked the voltage at the horn, it was good @11.56 volts. Then he hooked up a little test light he has that uses 6 amps and it lit when I pressed the horn button.
Then he took the horn off his Kawasaki and hooked it up and it worked!
So, I went next door to NAPA, bought a horn, hooked it up and BEEP!!! I have horn.
So, after all that BS I had 3 bad horns and now have a new one that works.
Thanks again for the help!
garyb900 is offline
post #6 of 6 Old 05-27-2010, 04:43 PM
LOL... what are the chances of your 2 extra horns not working... i guess they were taken off a bike / car for some reason ahha.
