Honda H.I.S.S Working or Not..!!! - Wrist Twisters
post #1 of 7 Old 07-10-2008, 04:12 PM Thread Starter
Al
I just noticed a few days back that the red LED for the H.I.S.S on my new Hornet 900 (919 US) is blinking like it's supposed to be. I've had the bike for a month now and all seems to be going OK and it always starts first time...
I know what HISS stands for but exactly what is it and how does it work?Does it have to be activated or turned on?
Thanks..
CeeBee919 is offline
post #2 of 7 Old 07-10-2008, 05:42 PM
We in the states are HISS challenged, but isn't it tied to the key? The key has to fit "down" into a ring that reads it and allows the bike to start. Without that certain key(s) the bike will not run.
post #3 of 7 Old 07-10-2008, 05:59 PM
Tom
Tom's Avatar
Tom is offline
post #4 of 7 Old 07-10-2008, 06:55 PM Thread Starter
Al
Sorry guys (thanks for replies anyway),, but I meant...
The red LED isn't flashing,, never has now that I think of it... Does this mean...
1. HISS has never beem switched on by factory or purchase shop..
2. HISS may be faulty, yet still enabling my key to operate the bike..
3. LED blown..
4. Don't even worry about it as HISS is still working anyway..
5. Some other unknown force in the galaxy at work here..
Cheers...
post #5 of 7 Old 07-10-2008, 10:44 PM
I like yellow bikes
Janet the jet's Avatar
3. LED blown..
Cheers...
Well, if it works the same way as the HISS on my 2002 model, it doesn't flash (other than to test the bulb when you first switch on) unless, before killing the ignition, you press down and hold the HISS button on the dash (the other one from the one you use to reset the trip meter) until you see a flash. Then, if you turn off the ignition it should flash about once every couple of seconds for 24 hours. Then it stops flashing to conserve the battery. The HISS should be working (it's a passive thing anyway) whenever your ignition is off, regardless of whether the light is flashing. Just to be clear, to make the light flash you need to do this every time you cut the ignition. Personally, when I had mine I only set it to flash when I was parking outside and didn't bother when it was in my garage.
Janet the jet
Janet the jet is offline
post #6 of 7 Old 07-11-2008, 05:35 AM
Thanks for chiming in Janet.
post #7 of 7 Old 07-11-2008, 08:23 PM Thread Starter
Al
Ah Cheers Janet,,, (just read this post right now)
I'll try that a little later when I am in the garage... My brothers one flashes as soon as the key is turned off, without have to push any buttons,, as did our VTR1000's before the Hornets,, but as long as I know nothing is wrong with it, I am not that worried, although it is nice to know it does actually function...
Thanks...
Edit - Couldn't wait,, raced out there.. It Worked. I turned it on and off.... Much thanks for that one...
