High RPM cut out - Wrist Twisters
post #1 of 5 Old 08-25-2006, 06:25 PM Thread Starter
ajcombs's Avatar
Helping a Member in Need
High RPM cut out
have an 04 919 with about 4500 miles i bought with 2200 on it 6 months ago. was on the throttle pretty hard wound up to about 8k rpm 2nd gear let off just go coast to stop using the engine to brake basically. while slowing the darned thing acted like you turned off and back on about 4 times. never done this before or since then either. any suggestions?
ajcombs is offline
post #2 of 5 Old 08-26-2006, 08:46 AM
BockHawk's Avatar
How much gas in the tank? Mine sometimes starts acting funny if I'm a little low on gas, even if there is at least half a gallon left.
2002 919 40,000 miles
BockHawk is offline
post #3 of 5 Old 08-26-2006, 09:16 AM
My '02 has done something like this twice a couple of weeks apart. On the gas out of a right hander, back off for a left hander and it felt like it either jumped a tooth on the sprocket or the ignition cut/relit as fast as you can snap your fingers. Both times I was up around 8K and backed off.
I checked wiring, chain and sprockets, etc. Never found anything. That was about 2 months ago and it has never happened since. I did find later that the clutch wiring at the control pod was loose; one came off and I had the "idle up" problem when in gear. Don't know if this could have anything to do with it or not.
I don't know how much gas I had, but I do know the fuel light wasn't flickering or on or else I would have thought that the problem.
post #4 of 5 Old 08-26-2006, 11:20 AM Thread Starter
ajcombs's Avatar
had over half a tank full of gas! will check the clutch connections. I'll check the chain tension again just put new tires on maybe tenison not right and it jumped a tooth???? any more suggestions are welcome thanks to all!!
ajcombs is offline
post #5 of 5 Old 08-26-2006, 06:10 PM Thread Starter
ajcombs's Avatar
chain was really loose!!!! thanks guys
ajcombs is offline
