Help with a 919...... - Wrist Twisters
post #1 of 12 Old 08-11-2008, 02:13 PM Thread Starter
2002 Honda 919 with about 4k on the clock. Won't start/run. Loading up with gasoline. Found a puddle of gasoline in the airbox. What do I do? Anyone had this?
Hooligan is offline
post #2 of 12 Old 08-11-2008, 02:17 PM
Corner speed sets u free
streakin919's Avatar
If you've got a power commander on it unhook it and give it another try.
streakin919 is offline
post #3 of 12 Old 08-11-2008, 02:19 PM Thread Starter
Bone stock. No mods at all. Looking to do some but.......
Hooligan is offline
post #4 of 12 Old 08-11-2008, 02:23 PM
DaveCB919F4
Fastbackdlm's Avatar
What's it doing. Cranking, fuel pump running, is the ignition hitting at all?
Fastbackdlm is offline
post #5 of 12 Old 08-11-2008, 02:26 PM
I'm not sure but it sounds like this could be a faulty injector(s). Rob will probably chime in here in a min.
post #6 of 12 Old 08-11-2008, 02:32 PM Thread Starter
Holding the throttle wide open and it will start.....missing terribly. Let off throttle and it loads up and quits. Again, gas in the airbox.
Hooligan is offline
post #7 of 12 Old 08-11-2008, 02:50 PM
DaveCB919F4
What about that vacuum diaphram for fuel pressure?
post #8 of 12 Old 08-11-2008, 02:52 PM
wisco919's Avatar
Have you checked that your battery is sufficiently charged?
wisco919 is offline
post #9 of 12 Old 08-11-2008, 02:59 PM
post #10 of 12 Old 08-11-2008, 04:32 PM
Franklin McGillacutty
riquefied919's Avatar
Check the vacuum side of the fuel regulator there should be no fuel present.Just pull the small vac line if any fuel comes out its the problemo.
riquefied919 is offline
post #11 of 12 Old 08-12-2008, 02:00 PM Thread Starter
Can someone show me what the FPR looks like? I have the bike in storage right now and want to know what to look for when I get it out.
Hooligan is offline
post #12 of 12 Old 08-12-2008, 04:57 PM
Go here
  1. Select "Fuel & air" in the menu on the left side of the schematic window
  2. Then select "Throttle Body Assy" schematic
It’s number 12 in the schematic
