help need pc3 map for 919 - Wrist Twisters
post #1 of 30 Old 09-19-2008, 02:22 PM Thread Starter
ok pc3 just came in and i have a tech installing it.. i need a good map for a 07 919 full vance and hines single exhaust... where can i find something like that?
post #2 of 30 Old 09-19-2008, 05:56 PM Thread Starter
post #3 of 30 Old 09-19-2008, 06:02 PM
Don't leave us hangin', what did you find?
Professional
post #4 of 30 Old 09-19-2008, 08:11 PM Thread Starter
used the stock bike with full race exhaust map from pc3 headquarters.. we will report back after more mile...
post #5 of 30 Old 09-24-2008, 08:48 PM Thread Starter
changed map to the one for stock airfilter with 2bros slip on .... runs better and has crisper acceleration.. anyone got a custom map for a single exhaust???
post #6 of 30 Old 09-25-2008, 03:44 AM
Ripper is offline
post #7 of 30 Old 09-25-2008, 07:34 AM
Hornet Grandpa!
This is the one I have used for almost four years and it works well for me. I got higher gas mileage and "seemingly" more power. I run a stock CBR900RR header and a Wileyco carbon fiber can.
support_six is offline
post #8 of 30 Old 09-25-2008, 07:46 AM Thread Starter
you may have to email it to me.. pm me and i'll give you my email addy
post #9 of 30 Old 09-30-2008, 12:52 PM
Hornet Grandpa!
The one I sent you is M112-004. I got it from the Dynojet site and it looks like the same one you already use from your post above. It works well for me. The other one I sent is from the 919.org site and I used it for a while but like the M112-004 better.
Hope it works for you.
post #10 of 30 Old 09-30-2008, 01:00 PM Thread Starter
not too bad... i am trying more i change the map run a couple days and see how it feels by the seat of pants dyno... right now i am playing with the accel pump ...
post #11 of 30 Old 09-30-2008, 01:43 PM
oldguard60's Avatar
Will the pcIII usb work on a MAC laptop? How hard to down load new mappings? Does the cost out weigh the performance?
oldguard60 is offline
post #12 of 30 Old 09-30-2008, 03:33 PM Thread Starter
i don't know about the mac..... and it's worth the money....
post #13 of 30 Old 10-01-2008, 05:58 AM
DaveCB919F4
Fastbackdlm's Avatar
Have you activated the accerator pump function. It's not in the map and you need to play with the settings to get what you like. I can hook my bike up and check my settings if you would like.
Fastbackdlm is offline
post #14 of 30 Old 10-01-2008, 08:13 AM Thread Starter
please do... i have mine set at 70% 40rpms and 50 fuel....
post #15 of 30 Old 10-01-2008, 04:08 PM Thread Starter
post #16 of 30 Old 10-01-2008, 04:11 PM Thread Starter
okay.. changed map to the "european model with full exhaust and aftermarket airfilter set fuel pump to 80% 50 and 50 and put the 16t front back on.... still can't decide.. must do more testing.. need custom map... the one for the sato on 919.org i cant figgure out how to convert it to work with the pc3 usb model.. and yes it has to be converted to .djm
post #17 of 30 Old 10-01-2008, 07:13 PM
Hippie Tinkerer
mntnceguy's Avatar
No it doesn't, well not really. Just go to "file" at the top of the PowerCommander Program, then click on "import .map file" or whatever its called, and go from there.....you'll figure it out
Build List in Spoiler
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
GiPro gear indicator
Givi Crash bars
Seargent seat w/ gel insert
Dyna Beads for tire balancing
Piaa horns 400 & 500 hertz
Tech-Spec custom tank Pads
Napoleon bar end mirrors
SW-Motech center stand
Shorai Battery
Hydraulic rear brake switch
Powdercoated: 22+ parts
etc, etc,
mntnceguy is offline
post #18 of 30 Old 10-01-2008, 07:23 PM Thread Starter
ok.. i didnt try it like that.. BUT that euro map is badda$$.. got in a little stop light altercation with a gsxr750 and he's probley still scratchin his head... i pulled away in every gear.. i still wanna try that sato map ldh made cause i have heard it works well.. but it is gonna be hard to top the one in there right now... p.s. i put the 16t back in just to see what would happen.. its quick quick
post #19 of 30 Old 10-04-2008, 08:19 AM
boogerface
mikochu's Avatar
Any news, barton?
Michael Reyes
mikochu is offline
post #20 of 30 Old 10-04-2008, 08:25 AM
boogerface
mikochu's Avatar
Sadly, not in OSX. However, if you have Windows installed, you should be good-to-go.
Michael Reyes
mikochu is offline
post #21 of 30 Old 10-04-2008, 08:39 AM Thread Starter
Originally Posted by mikochu View Post
Any news, barton?
yes indeedie... the european map for aftermarket airfilter and race exhaust works pretty good ... i also put the 16t back in... also turned the accel pump feature on... set it to 80% 50 rpm and 50 fuel.. i like it.. i'm gonna try the famous sato map.. but right now that euro map is pretty fun.. accels like a beast and have'nt noticed my gas milage sucking any worse than normall.... 32-34 per gallon.. 125-130 before the light comes on.. 4-4.3 to fill it up.. had a little impromptue drag race the other night with a gixxer he lost, pulled up at the next light and asked "what the f#% is that thing".. i explained he could get me top end but i own him 0-110..lol
post #22 of 30 Old 10-05-2008, 02:38 PM
Hippie Tinkerer
mntnceguy's Avatar
I just went and test ran the European map....
At least for my pipes I gotta say it kind of a dog. I'll bet its better on your bike though, at least I hope so...
I've tried all of the maps I could find, and the Moriwaki map actually turned my pipes blue at the flange in under 3 minutes....might be a little lean, LOL
Anyway, with as easy as the maps are to change, ya might want to do a little experimenting.......just sayin
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
Givi Crash bars
Shorai Battery
etc, etc,
post #23 of 30 Old 10-05-2008, 03:50 PM Thread Starter
... which maps in your experience do you suggest?? and did you play with the accelerator pump feature cause i noticed a difference playing with those settings.. i have yet to try the famous sato map cause its raining its butt off here and my neighbor won't let me take his laptop outside in the rain... but hopefully tomorrow i will give that map a try and see.. if not i will talk one of my friends into doing a custom map for me
post #24 of 30 Old 10-05-2008, 04:03 PM
drivit's Avatar
so far i like the 004 best,
except i'm hitting the revlimiter,
cause it just keeps pulling.
drivit is offline
post #25 of 30 Old 10-05-2008, 04:49 PM
Hippie Tinkerer
mntnceguy's Avatar
The Dan Kyle 919satonew2 map has the best benefits for me, with the Accelerator pump on and at 70-80% sensitivity, 40rpm, and 50%fuel. I'm not some tuning expert or anything by any means, I'm just encoraging ya to use all your resources, who knows, ya may find something ya like. Now....about this friend that can make a map for ya.....wouldn't be coming to Colorado anytime soon would he???
SOLD SOLD SOLD
When Sold:
599 Headlight
Koso Gauges DB-02r
Givi Crash bars
Shorai Battery
etc, etc,
post #26 of 30 Old 10-05-2008, 04:51 PM
boogerface
mikochu's Avatar
I installed my PC III earlier this afternoon. I flashed it with the 004 map, too. The rain was headed my direction, so I only got to ride it around the block. Without the PC III installed, my low end RPMs were a bit weak due to the 900rr exhaust/header. However, with the PC III and 004 map, like drivit said, it just keeps pulling...
Michael Reyes
mikochu is offline
post #27 of 30 Old 10-05-2008, 05:40 PM Thread Starter
there are a couple of my customers (friends) that have dyno's in their shops.. i put the 16t back in so i think i will try the 004 with the accel pump set where it is.. the last time i tried the 004 i didnt have the pump turned on and i had the 17t.. i dont know i'm gonna keep playing with it till either i get it right.. or i "F" it up... which ever comes first..lol... rain stopped going to change the map.. will report back.. keep up the suggestions this is fun
post #28 of 30 Old 10-05-2008, 06:09 PM Thread Starter
she didnot!! like the sato2 map.. fell flat on her face at 4000r's ... i put the 004map in and it seemed pretty good (with the accel pump turned on) but i had to stop testing because the local law enforcement frowns on that stuff this late at night...lol.. (my son is the quickest gate opener in broward county...lol .. yee haw for bluetooth phones..lol
post #29 of 30 Old 10-18-2008, 06:08 AM
oldguard60's Avatar
I called dyno jet and confirmed that the pc commander will not work with a mac laptop, ONLY Window based PCs.
post #30 of 30 Old 10-18-2008, 06:53 AM
boogerface
mikochu's Avatar
Yes and no. I use a Mac Book Pro to transfer/modify my PCIII. You need an Intel Mac (Macbook, Mac Book Pro, Mac Pro, any Intel Mac). You also have to install Windows via Boot Camp (dual boot) or Parallels/VM Ware (virtualization).
Michael Reyes
mikochu is offline
