HELP ME!!! - Wrist Twisters
post #1 of 6 Old 10-07-2007, 11:10 AM Thread Starter
Ben
HondaStreetfigh's Avatar
HELP ME!!!
I saw someone on here had polished the heat shields on their OEM exhaust. I've been searching for it forever. Can someone gimme a link to it please?!
I wanna polish mine today, but need the directions. (Hey look Sporty, a man asking for directions!)
2 > 4
HondaStreetfigh is offline
post #2 of 6 Old 10-07-2007, 11:21 AM
wisco919's Avatar
They are made of stainless so start with an aluminum oxide wheel on a grinder (it is a soft abrasive wheel that sorta feels like rubber) then switch to 3M Scotch Brite pads and then onto a polishing compound. The wheels are kinda pricey but last a long time. You can find them for a number of grinder types from bench to 4 1/2" disc. I generally use the Red or Brown 3M pads, they are finer grit. Any semi abrasive polishing compound should be able to achieve a high shine.
wisco919 is offline
post #3 of 6 Old 10-07-2007, 12:49 PM
Heavy Metal
ratdog's Avatar
look for pics of dale's bike...st louis area, he had a lot of polished stuff...case covers and then some
h9r has posted them over on cw plenty...the way-back machine should be able to help
ratdog is offline
post #4 of 6 Old 10-07-2007, 12:56 PM
Rich Jura's Avatar
You could also do it with 3M wet or dry paper starting with 400 and progressing
on to finer grits.Use soapy water to wet it down and sand only in one direction.
If your not familiar with the process it's a lot harder to screw it up by hand,plus
it's a lot quieter and no need for for hearing or eye protection.
Later
Rich
Rich Jura is offline
post #5 of 6 Old 10-07-2007, 05:54 PM
That was Phobman's 919. Here ya go.
https://www.wristtwisters.com/forum/s...hlight=phobman
post #6 of 6 Old 10-07-2007, 07:31 PM Thread Starter
Ben
Thanks!
2 > 4
