Thread Tools | Display Modes |
Help installing brake light strobe
I bought the LSC-100A brake light flasher from superbrightleds to install on my 2002 Honda 919. https://www.superbrightleds.com/more...odule/195/845/
Its a simple install but i have a couple questions. First i wanted to make sure i have the wires right for the brake lights. Green= Ground, Green/Yellow= Brake lights, Brown= Tail lights. Is that correct? I know i splice the positive into the brake light wire but should i splice the units ground into the wiring too or should i run it to a chassis ground?
Sponsored Links | |||
Moto77,
Just checked the wiring diagram and your wire color descriptions at the socket location are correct. When I did an LED flasher I used a ground from the same location but it really doesn't make any difference (whichever is most convenient.)
Good Luck
Good Luck
Thanks Mark.
I like it! Good job.
When I did mine I put a flashing LED light bar on the bottom edge of the license plate. Your's looks better than what I did.
Thread Tools | |
Display Modes | |
Posting Rules | |
