help! asap !bike wont start! - Wrist Twisters
post #1 of 33 Old 11-14-2009, 08:08 AM Thread Starter
it is Saturday morning and we have a big ride planned and for the first time ever the 919 wont start. It turns over, but will not fire...it keeps making the noise after I run the starter for 4 or 5 seconds....the noise the bike makes when you cycle the kill switch off then on...the electric humming where everything goes through a test. Never seen this before. Help...the ride leaves in 45 mins.
greenkaz04 is offline
post #2 of 33 Old 11-14-2009, 08:50 AM
Fuel, air, spark. Obviously you need all three.
The pump is running so the kill switch is on (it wont crank or run the pump if the kill switch is off). Assuming there is fuel in the tank you can be pretty sure it's getting burnable stuff.
Unless a rat built a nest in the intake overnight you're getting air.
Which leaves spark.
In this case the most likely problem is fuel fouled plugs. Try starting it with the throttle wide open -- this is a feature called "dechoke", which cuts fuel during cranking. This gives the engine lots of air in order to clear the cylinders of excess fuel and light the fires. Once it fires up (the optimistic view) you will probably have to keep it running with a little throttle until all the plugs are cooperating.
This is all you can do in the time allotted. Past that you're pulling plugs and checking things with a voltmeter.
post #3 of 33 Old 11-14-2009, 09:55 AM
mantelhonda's Avatar
I think you may have weak battery or lose or corroded connections .
mantelhonda is offline
post #4 of 33 Old 11-14-2009, 09:55 AM
CG
catonsvilleguy's Avatar
Sounds like it might be a bad connection if you're getting that startup hum repeatedly. If you have a PCIII, I would check the tapped in connection and the other small connection. I assume the big connectors are probably O.K. but check them too.
catonsvilleguy is offline
post #5 of 33 Old 11-14-2009, 10:18 AM
Like said, if you've got a PCIII yank it out.
post #6 of 33 Old 11-14-2009, 10:43 AM
"Whose ABBA ZABBA?"
Open throttle wide and then crank it over. My zx10r will do the same thing on occasion,
General George S. Patton
post #7 of 33 Old 11-14-2009, 11:04 AM
Well, he either got it started, or is in such despair he can't type.
post #8 of 33 Old 11-14-2009, 11:08 AM
"Whose ABBA ZABBA?"
Let's hope he has a good ride.........
post #9 of 33 Old 11-14-2009, 11:35 AM
I killed Barton664
Basspiece919's Avatar
The almost never fail method is rolling it down a hill and bump starting it...
Basspiece919 is offline
post #10 of 33 Old 11-14-2009, 11:58 AM
tc919er's Avatar
Yeah, but it's a beotch if it doesn't!
"No freeman shall ever be debarred the use of arms."
---Thomas Jefferson 1776.
tc919er is offline
post #11 of 33 Old 11-14-2009, 12:08 PM
Only if you want to get it back up the hill.
post #12 of 33 Old 11-14-2009, 12:54 PM
what is this "hill" you humans speak of??
post #13 of 33 Old 11-14-2009, 01:22 PM
Tirone shoelaces
TexasTraffic's Avatar
Oh yea... In FL those would be called "overpasses".
Can you hear the fuel pump spin when you turn the key to the "On" position?
Check the position of the STOP ENGINE switch (stupid, I know. check it anyway)
Check the Fuel Pump fuse.
Check the Ignition fuse.
There's more, though I bet your problem is somewhere in the path above (bad fuse or associated relay).
TexasTraffic is offline
post #14 of 33 Old 11-14-2009, 02:02 PM
4 whls good 2 whls better
starman's Avatar
Try clicking through the gears a little to make sure the neutral switch is engaged. I assume it would be the same switch that turns on the neutral light, but I'm not sure.
If the neutral switch is busted or out of alignment, you can still start the bike by getting on it and raising the kickstand.
He says there's a hum when he turns the key, so the fuel pump is running, so the tilt sensor is probably fine.
starman is offline
post #15 of 33 Old 11-14-2009, 02:33 PM
maybe it forgot the words
post #16 of 33 Old 11-14-2009, 04:34 PM
UJM
Banned
kill switch?
UJM is offline
post #17 of 33 Old 11-14-2009, 04:55 PM
Self proclaimed idiot....
Border's Avatar
Strawberry Pop Tarts will do that to me.
Border is offline
post #18 of 33 Old 11-14-2009, 05:00 PM
Signifer
scgstuff's Avatar
Donation Extraordinary Ride
Maybe it was flooding the cylinders and he pulled a plug and wanted to look inside. When he flicked the bic to see what was in the cylinder......BOOM.......
He will post back after he gets outta the burn unit.
Shawn
2004 Triumph Speed Triple SE (Speedy - Street Bike)
2002 Suzuki GSX-R600 (Shamu - Track Bike)
scgstuff is offline
post #19 of 33 Old 11-14-2009, 05:17 PM
hawkeze's Avatar
I'll agree with Mantelhonda and say it's the battery. I had the same thing happen. It would turn the engine over very strong but would not fire. Replaced the battery (thanks to the suggestions of you fine folk!) and no problemo.
hawkeze is offline
post #20 of 33 Old 11-14-2009, 05:36 PM
919 City Pilot
Pegjumpflyer's Avatar
Hes kinda quite...bets the kick stand was down,,,,,,,,,,
Pegjumpflyer is offline
post #21 of 33 Old 11-14-2009, 06:45 PM
drivit's Avatar
thanks, i just ate all the strawberry pop tarts.
drivit is offline
post #22 of 33 Old 11-14-2009, 08:01 PM Thread Starter
heya guys....
I made it today. I actually took off about 15 mins late but I knew which direction the ride was headed and it wasnt hard to catch a group of 15 riders I ran the battery down trying to start. It is an 04 and I have Never had a problem w starting it. I got the jumper cables out about 15 min after my postthis morning and she started right up....I was weary of turning the bike of throughout hte day but she ran like a champ and I coverd 400 miles. My but hurts but I got some cool photos and we had a blast. Gorgeous day in south GA. Thanks for all the responses.....I do not know why it did not start this morning...but no problems the rest of the day.
post #23 of 33 Old 11-14-2009, 08:19 PM
heya guys....
well post up some pics.... glad you figured it out...
post #24 of 33 Old 11-14-2009, 08:21 PM
Signifer
scgstuff's Avatar
So, no burn unit? That is GREAT news!
Shawn
scgstuff is offline
post #25 of 33 Old 11-14-2009, 09:24 PM
Gets censored
For reference, I had this problem and it was a fuse
brian is offline
post #26 of 33 Old 11-15-2009, 07:58 AM
battery tender. essential
post #27 of 33 Old 11-15-2009, 08:30 AM
CG
+1
I picked up the 4 bank unit. Keeps the 919, scooter, lawn mower (off season, NA for Paco), kid's car waiting for his license, all fresh and ready to go. Amazon had the one I got cheaper than anybody else I found.
post #28 of 33 Old 11-15-2009, 09:26 AM Thread Starter
fuses have to be replaced when they are blown....I did nothing but walk away for 15 mins.....I think something was acting weird with the fuel injection....either way..I am going for another ride this afternoon. I gota get all i can before I deploy in december.
post #29 of 33 Old 11-15-2009, 11:48 AM
Fuel Injected bikes like a strong battery, just because you have enough juice to turn it over may not be enough to start it. You need enough juice to crank it, run the fuel pump, ignition system, ecm, etc. everything.
post #30 of 33 Old 11-15-2009, 01:39 PM
UJM
Banned
Absolutely
UJM is offline
post #31 of 33 Old 11-15-2009, 06:10 PM
BrokeRecord
I wasn't gonna say this but, a couple of months ago, I bumped my kill switch doing 70mph on the free way. The bike died. I looked it over and over again. No go, so, I call my bride. She hooks the trailer up, no gas in the truck, so she fills up. Then comes looking for me 15 miles out. We pull in the ditch off the shoulder and shove (hard) the bike up the ramp. Tie it down good. Use 4wd to get out of ditch. Get on hi way still in 4wd mode and get wheel wind up. Straighten that out and head home. We start to unload the bike and I'm eyeball to eyeball with the kill switch.
I tell bride, I can get it from here! So she goes inside. I piddle around a bit, I flip the switch and hit the starter and looky here bride, I fixed my bike!
And we lived happily ever after.
The word " Kill Switch" is not used in our home!
brokerecord is offline
post #32 of 33 Old 11-15-2009, 06:40 PM
I doubt that there is a single one of us here, those of us with multiple decades of riding, that hasn't done something fairly similar. However, only a small percentage would/will man up regarding it. I'm not telling my stories, oops, story....
sike is offline
post #33 of 33 Old 11-16-2009, 07:53 AM
Survivor/Broken&Busted
yostevo052's Avatar
Community Service Veteran
where ya deployin to man?? ...
only did it once (that's all it took) ... lmfao
yostevo052 is offline
