Headlight? - Wrist Twisters
post #1 of 8 Old 03-04-2009, 06:47 PM Thread Starter
whazn919's Avatar
Headlight?
So today on my way home i went to turn on my hi-beams and noticed the light wouldn't come on. Upon arrival at home i noticed that i had no light. I checked the fuse and connection at the rear of the light, as well as the filament on the light. I don't have a voltmeter where i'm at tho i might possibly be able to borrow one until the weekend tonight. Any advice would be appreciated, i will most likely just start checking for voltage closer and closer to my power source starting at the plug for the light.
whazn919 is offline
post #2 of 8 Old 03-04-2009, 07:01 PM
Trackday Recognition Veteran
Print out a copy of the wiring diagram and get the voltmeter.
Post up when you're ready and we'll help you along...
Sokali is offline
post #3 of 8 Old 03-04-2009, 07:06 PM
Check the inside of the left pod and make sure the wiring isn't bad there.
post #4 of 8 Old 03-04-2009, 07:19 PM
if i remember right the highbeam light comes on when the headlight goes out? I think because my bike when i got it the bulb went bad 2 weeks later.
Personally i'd try a new bulb first. they might look fine but easy cannot. I say always start at the easiest.
barmatt80 is offline
post #5 of 8 Old 03-04-2009, 09:30 PM
if u have the $$, get a cooler looking headlight...i got mine off ebay for about 65 shipped. acerbis cyclops. not hard to wire up either, and all the lights work
rtman70 is offline
post #6 of 8 Old 03-04-2009, 10:29 PM
cbf900's Avatar
i had this problem last year, my head light had no power goin to it. the reason was because there is a blue/white wire from the headlight circuit going up to the starter button- the light goes out while starter button is pressed so it wont over work the battery- this wire had come lose. we soldered it back on and the headlight worked again.
also you might be interested to know that i use a 130w/100w lightglobe
cbf900 is offline
post #7 of 8 Old 03-04-2009, 11:23 PM Thread Starter
whazn919's Avatar
Thanks for the tip i will check it out tomorrow. the PO had installed a 100w bulb and it looked like it was frying the connector. It's not too toasty, i've seen more sensitive electronics work with worse, but still that seems to be the reason why the connector had obviously gotten warm.
whazn919 is offline
post #8 of 8 Old 03-05-2009, 07:36 AM
+1 That's the only problem I've had with the electrical system.
Sokali is offline
