Header torque specs - Wrist Twisters
post #1 of 9 Old 04-21-2012, 12:40 PM Thread Starter
Header torque specs
Hey guys, does anyone know the torque specs for nuts that hold the header in place? I've searched but couldn't come up with any.
Thanks
Mikey Reds is offline
post #2 of 9 Old 04-21-2012, 01:23 PM
NWTB Non Stinky 919
jeffie7's Avatar
Is this what you need?
jeffie7 is offline
post #3 of 9 Old 04-21-2012, 01:26 PM Thread Starter
Yes!!! Thanks jeffie7! Now i can get to finishing my 900rr conversion
post #4 of 9 Old 04-21-2012, 01:31 PM
NWTB Non Stinky 919
jeffie7's Avatar
Personally I would have just snugged it softly one handed and if the exhaust leaked I would have tightened it up a bit.
jeffie7 is offline
post #5 of 9 Old 04-21-2012, 03:06 PM
Love my BIG BOY Toys!
BBB2's Avatar
^ +1 and use anti-seize
1999 Honda Valkyrie Interstate
2011 Kawasaki Vulcan Vaquero*
2004 Honda 919 *
2002 Honda VTX 1800C*
* SOLD *
BBB2 is offline
post #6 of 9 Old 04-21-2012, 06:10 PM Thread Starter
After I had it together and running, I realized I didn't use anti-seize. The nuts came off no problem from the original header so I figured it should be ok. I don't plan on taking the new header off lol
post #7 of 9 Old 04-21-2012, 06:47 PM
Chief 10 Beers
wgrady's Avatar
It's also a good idea to check/tighten/retorque after a full heat cycle. The tend to loosen during that process.
There are bold motorcyclists and old motorcyclists, but (OK) there are few old bold motorcyclists
wgrady is offline
post #8 of 9 Old 04-21-2012, 07:57 PM Thread Starter
Thanks guys! Ill be sure to recheck the torque after im done with the heat cycle!
post #9 of 9 Old 04-22-2012, 10:50 PM
+1 to the heat cycle, plus, if you put new crush gaskets on (like you should) then those will also soften in the heat cycle and crush farther, so you'll need to re-torque to spec for that very reason as well.
Mine were way loose when I went back to check on them, but I got lucky. I went about 1000 miles before I checked them.
