HAND GRIPS ? - Wrist Twisters
post #1 of 26 Old 12-16-2009, 02:53 PM Thread Starter
78mikey810's Avatar
HAND GRIPS ?
Just got renthal ul bars, would like some trusted advice on what hand grips to install on the bars?
78mikey810 is offline
post #2 of 26 Old 12-16-2009, 02:56 PM
ProGrip dual compound
post #3 of 26 Old 12-16-2009, 03:01 PM
Anything heated!
post #4 of 26 Old 12-16-2009, 03:04 PM
the gel ones you get at cyclegear.......
post #5 of 26 Old 12-16-2009, 03:16 PM
Gets censored
I had some pillow top dual compound ones they were alright, then I just got some spider road grips and I'm very pleased with them. The other ones were thin and flimsy in comparison and I feel these dampen the vibration a bit more.
brian is offline
post #6 of 26 Old 12-16-2009, 03:18 PM
I have spider grips. Good grip. Must admit that I only got them because it pushed shipping on an order above the minimum for free shipping. No complaints, though.
jay313 is offline
post #7 of 26 Old 12-16-2009, 04:54 PM
Steve
Mayday's Avatar
Get any kind you like the looks of. Just make sure you get the right size for the bars you are running. They are cheap and easy to replace. I'm running dirt bike grips at the moment, they work great. And I've never used glue. They are plenty freakin tight without it. Just my
Steve
Mayday is offline
post #8 of 26 Old 12-16-2009, 05:16 PM
i use the cheapest pump type hairspray you can find to put the grips on... *(aquanet i think) just spray the chit out of the inside of the grip and shove it in place... after ~30 mins it will never move again....
i have not had a grip move since starting to use this stuff.... get the $1 a bottle crap.
post #9 of 26 Old 12-16-2009, 05:26 PM
^+1. The hairspray acts almost like a lube to help it slide on, then dries sticky. Perfect.
jay313 is offline
post #10 of 26 Old 12-16-2009, 05:40 PM
I use dish soap as glue. Same effect as hairspray.
post #11 of 26 Old 12-16-2009, 06:45 PM
+1 on the hairspray but I only use the real expensive stuff if thats what the G/F has cluttering up the shelves of my medicine cabinet, if not I use whatever she's got in there.
post #12 of 26 Old 12-16-2009, 06:49 PM
I put my stock ones back on. Same ones I took off the original bars.
Bryce919er is offline
post #13 of 26 Old 12-16-2009, 11:25 PM Thread Starter
78mikey810's Avatar
if u used the stock grips what did u do with the poen end of the bars ?
post #14 of 26 Old 12-17-2009, 12:15 AM
bar ends?
I went with a set of renthal bar ends when I switched out to renthal bars.
honda ng gingsa is offline
post #15 of 26 Old 12-17-2009, 12:19 AM
919>food>beer
Jeef's Avatar
I have a bar end in one side and a mirror on the other...
Jeef is offline
post #16 of 26 Old 12-17-2009, 04:28 AM
Banned
I use Grab-On grips on anything and everything I can.
Have for decades.
Motorcycle Grips, Hand Grips & Padded Grips | Grab On Grips
There are cheap imitations, always go with the best
Good company, good people who stand behind what they sell
Grab On Grips | Foam Tubing, Motorcycle Grips & Bicycle Handlebar Grips
Grab on Grips, LLC - 350 E. Beech Avenue - Walla Walla, Washington 99362
Phone: (509) 529-9800 - Toll-free (800) 847-2266 - Fax: (509) 525-9009
NotUJM is offline
post #17 of 26 Old 12-17-2009, 09:58 AM
Hairspray is all well and good until you loan your bike to a "Death Gripper" who got cought in a rainstorm. Hairspray is water soluable, dont cha know?
I took it off and silicone glued it. BTW that POS didn't even clean my bike when he returned it. Learned my lesson. No one is ever riding my stuff again. Don't even ask.
Grips: I like the Domino's that came on my SD. They are thicker in the center and thinner towards the edges. When you lay you hand on them, there is better support for the middle of your hand. (That's just one of the many little quality touches that are on a KTM)
post #18 of 26 Old 12-17-2009, 10:20 AM
(oYo)
2000TJ's Avatar
ODI Thug Plugs...for the minimalist look-since your vibes, if you ever had any, will be cured by the new bar.
2000TJ is offline
post #19 of 26 Old 12-17-2009, 10:31 AM
I'm using the G2 Ergo bar end protectors on mine, you have to tap the end of the bar for the nylon insert but they have a clean look.
post #20 of 26 Old 12-20-2009, 12:52 AM Thread Starter
78mikey810's Avatar
what bout using the stock bar ends?
post #21 of 26 Old 12-20-2009, 01:02 AM
As I discovered, the stock ends wont go into the renthals without some fiddling. Not worth the trouble when there's so many easier bolt-on options. I like the weight of the stockers and would choose something heavier than the renthal bar ends I ended up using if I had more options here.
post #22 of 26 Old 12-20-2009, 06:09 AM
Gets censored
I've used the scotts stick grip twice now, and twice now I've had my grips loosen up on me pisses me off.
brian is offline
post #23 of 26 Old 12-20-2009, 07:02 AM
CG
catonsvilleguy's Avatar
I really like the looks of these Rizoma grips but have not tried them:
PJs Parts
catonsvilleguy is offline
post #24 of 26 Old 12-20-2009, 07:08 AM
Curmudgeon
semi_gray's Avatar
I've always liked Galindo Superbike grips.
Inexpensive and long lasting.
semi_gray is offline
post #25 of 26 Old 12-21-2009, 10:41 AM
Hornet Grandpa!
WD40, the man's grip install lube! However, I did find the WD40 next to the hairspray on my wife's bathroom counter! I better go smell her hair!
O:\General Info\member1804.jpg
support_six is offline
post #26 of 26 Old 12-22-2009, 11:15 AM Thread Starter
78mikey810's Avatar
ha
