H11 bulbs - Wrist Twisters
post #1 of 13 Old 04-21-2010, 03:33 PM Thread Starter
H11 bulbs
trying to wire up my H11 bulb sockets to the beaver company harness and i cant for the life of me figure out if it matters which wire of the H11 socket is positive or negative. can anyone help out?
post #2 of 13 Old 04-21-2010, 03:51 PM
hmm... so long as no part of the socket is metal or is a ground itself there should be no polarity issues. But make sure to check yourself.
post #3 of 13 Old 04-21-2010, 03:56 PM Thread Starter
hmm makes sense. housing is plastic from what i can tell. it'll be plugging into the 599 headlight assmbly using the eastern beaver company harness to plug into the stock 919 h4 plug. dont want to screw anything up here lol.
post #4 of 13 Old 04-21-2010, 04:09 PM
can you post a pic up of the socket / housing?
post #5 of 13 Old 04-21-2010, 04:22 PM Thread Starter
here you go. just got a response from the ebay seller i bought the plugs from and he stated that polarity doesnt matter. for the sake of the harness and everything inbetween, i just want to double check and be sure.
post #6 of 13 Old 04-21-2010, 05:15 PM
ya i cant forsee there being any problems with that setup, you should be just fine.
post #7 of 13 Old 04-21-2010, 05:53 PM
BrokeRecord
What happened to the green wire?
brokerecord is offline
post #8 of 13 Old 04-21-2010, 06:05 PM Thread Starter
green wire?
thanks nd4!
post #9 of 13 Old 04-21-2010, 07:25 PM
polarity won't matter at that point in the harness...further back though is a different story.
post #10 of 13 Old 04-22-2010, 10:34 AM
What is the advantage of using the Eastern Beaver harness over creating a custom harness? Is it just plug and play? $60 sounds kind of steep for something that can be made from about $20-$25 in components off eBay / Radioshack.
The reason I'm asking is because I'm also doing the 599 headlight conversion. I have a relay feeding power to the lowbeam directly from the battery and using the license plate light circuit to switch it on/off. For the highbeam, I'm keeping it simple and using the OEM harness. Both lights will stay on when I flip the highbeam switch on.
post #11 of 13 Old 04-22-2010, 10:42 AM Thread Starter
well, its a beautiful harness if that helps... yes, fully plug and play. easy to install/remove to retain the factory wiring. keep in mind, $60.00 included the diode, all labor, and shipping from japan. everything is clean, heat shrink wrapped, and very well done in my opinion. plus it's not limited to just the 919. you can pretty much connect any kind of bulb you want
post #12 of 13 Old 04-22-2010, 11:33 AM
Red Rider
Woody469's Avatar
Which one is it on their website that we need??? I cant seem to find a damn clue, there are a bunch of hem and I know the part nuber was listed on here but not on his web site????
My blood runs Honda Red......
2003 Honda 919
2004 Honda 599
1999 Honda XR650L
Woody469 is offline
post #13 of 13 Old 04-22-2010, 05:10 PM Thread Starter
H4 Conversion Relay Kit, Item#:H4CRK , Main Lead Termination: Fuseholder
Unit price:$46.95 USD
email the guy with the above is likely easier. and if you prefer, then mention u want the diode.
