Ground wire - Wrist Twisters
post #1 of 7 Old 08-07-2008, 08:56 AM Thread Starter
Ground wire
noticed on my 919 the ground wire is hanging out from the tank where does this wire need to be grounded too
jeremyj is offline
post #2 of 7 Old 08-07-2008, 09:01 AM
Madmotor's Avatar
There is a grounding point on the left side of the frame under neath the tank. You can get to it by tilting the tank up and using a block of wood or foam ar something to hold it up.
Madmotor
'06 919
Madmotor is offline
post #3 of 7 Old 08-07-2008, 09:07 AM
What color is the wire, and where is it exactly? There is a multi wire ground on the right side of the frame near the back of the tank. The grounds are colored Green, Green / Pink, and Green / Black, so any other color has a different function and should not be arbitrarily grounded.
post #4 of 7 Old 08-07-2008, 09:07 AM Thread Starter
thanks madmotor
jeremyj is offline
post #5 of 7 Old 08-07-2008, 09:08 AM Thread Starter
It is silver got an eyelet on the end
jeremyj is offline
post #6 of 7 Old 08-07-2008, 09:36 AM
Silver?
There are no electrical wires color coded Silver -- tilt up the tank to see where it comes from. What you are probably seeing is the vinyl covered cable attached to the frame and fuel tank that limits how far the tank can be tilted up. In this case it may have come loose at one end, especially if the tank was removed for some reason. My '02 doesn't have this, but it had been repainted before I bought it used and the cable may have been left off. I've heard it mentioned on this forum. Anybody else have this?
post #7 of 7 Old 08-07-2008, 09:41 AM Thread Starter
cool thanks rob
jeremyj is offline
