Goofy countershaft sprocket question - Wrist Twisters
post #1 of 4 Old 07-05-2008, 01:25 PM Thread Starter
Honda Addict
razorbike's Avatar
So I'm past due on a good chain and sprocket cleaning. Go to loosen the front sprocket bolt so I can get all the gook out from behind it. It's very much stuck! Before I go screwing up the threads using a breaker bar I have to ask this basic question:
The countershaft bolt isn't threaded backwards is it? It's been quite a while since I had it apart. Going lefty doesn't seem to be getting loosey. Don't remember where I experienced it but either my old Honda 3 wheeler or the 919 has a backwards threaded countershaft bolt.
Anyone?
razorbike is offline
post #2 of 4 Old 07-05-2008, 02:30 PM
I had a H-D
west467's Avatar
The manual does not mention anything special about the "drive sprocket"
bolt except for the punch mark (on sprocket) facing out, torque to 40 lbf.ft.
Well.. it does call it a "special bolt".. I have not had mine off, I use spray chain cleaner and kerosene. I am sure someone who has, will speak up here soon.
west467 is offline
post #3 of 4 Old 07-05-2008, 02:44 PM
919 City Pilot
Pegjumpflyer's Avatar
right is tight left is loose......mine was a bitch last week.
Pegjumpflyer is offline
post #4 of 4 Old 07-05-2008, 03:18 PM Thread Starter
Honda Addict
razorbike's Avatar
OK, more umph to the left it is - Thanks Peg.
And, West, I use kerosene also along with medium and small size nylon brushes. Right along the same method as Bigdaa but I don't actually submerge the chain in kerosene. Use a metal mesh basket turned upside down in the drain pan and give it the ole rinse, brush, rinse.
