Gear Indicator Install '02 919 - Wrist Twisters
 1Likes
  • 1 Post By tomsza
post #1 of 8 Old 06-21-2020, 08:50 AM Thread Starter
'02 919
Some pics of the gear indicator for the 919. I like it. Keeps me from counting in my head.
The purchase: GIpro X-type G2 and GPX-H01 Harness Kit
The Speedo sensor signal tap-in. Yes, mouse chewins.
Finding the tach signal wire from ECU (Yellow with Green stripe).
Tapping-in using supplied method.
Routing the indicator wire.
Taping and sealing up the harness incision. Used tubing as a wire wrap.
Indicator mounted.
tomsza is offline
post #2 of 8 Old 06-21-2020, 09:36 AM
Greg
thesickest's Avatar
Nice write up. I have the Idea brand, think it’s a knock off of yours. Mounted it to the tach itself after red line with double sided tape. Was the first mod I did to my 919 given the fact I don’t remember what I ate for breakfast everyday let alone what gear I’m in, I’m happy with it. Been on the bike for 3 years with no issues.
File Type: jpg 662B78DA-1FB5-4CBA-A7D8-8059551A5EC1_1592757344327.jpg (45.3 KB, 25 views)
thesickest is offline
post #3 of 8 Old 06-21-2020, 02:39 PM Thread Starter
'02 919
That is a pretty good spot to mount it.
tomsza is offline
post #4 of 8 Old 06-21-2020, 05:38 PM
Pokemon Master
So this just does a lookup based on wheel speed and rpm to determine what gear you're in? It doesn't actually sense the gear lever changing positions? What's the lag on the lookup after you shift?
Thanks for the pictures!
2007 919, 2013 CB500X, 2009 Buell XB12R, 20+ bicycles
Darth_Firebolt is offline
post #5 of 8 Old 06-21-2020, 08:06 PM Thread Starter
'02 919
Correct. It's using the math between the two sensor outputs. When you pull in the clutch between shifts (or in neutral, or at a complete stop), the readout shows a minus "-" symbol. It's pretty quick to respond when letting the clutch out.
Darth_Firebolt likes this.
tomsza is offline
post #6 of 8 Old 07-01-2020, 06:39 PM
Rock-N-Roll
If you shift not pulling in the clutch does it know what gear you are in?
Spike28659 is offline
post #7 of 8 Old 07-02-2020, 05:45 AM Thread Starter
'02 919
Never tried, but I would imagine it does since it's working off a formula of the engine and drive sprocket rpm. An interesting bit in the instructions says that if it shows a dash symbol while in gear under an acceleration, it could be a sign of the clutch slipping.
tomsza is offline
post #8 of 8 Old 07-02-2020, 05:23 PM
Andrew Puleo's Avatar
All my next mods are going to be quality of life electronics: STS smart brake light, the Trucklite7 headlight, and this gear indicator. I’m constantly reaching for my imaginary “7th gear” on the highway. Down the road, let us know how this install and brand hold up in the long term
Andrew Puleo is offline
