gas light - Wrist Twisters
post #1 of 3 Old 09-16-2010, 06:23 AM Thread Starter
duc duc GOOSE!
gas light
so it might have got buried in my intial post, but i learned on my way home that my gas light does not illuminate, the bike just died...thankfully i was exiting to a rest stop with gas... any thoughts on what the prob. could be?
02 919-SOLD
HondaCrazy is offline
post #2 of 3 Old 09-16-2010, 06:26 AM
Burned out bulb or LED? It could also be the sensor in the tank. I don't think it's going to be super complicated so the fix should be relatively easy.
post #3 of 3 Old 09-16-2010, 07:49 AM
blur
drewvir's Avatar
from the service manual
RESERVE SENSOR INSPECTION
Turn the ignition switch is ON and make sure the fuel
reserve indicator come ON.
If the fuel reserve indicator does not indicate properly,
check for the following .
19-18
JUMPER WIRE
Disconnect the fuel reserve sensor 3P connector.
Short the wire harness side connector Red/black and
Green terminals with a jumper wire.
If the indicator comes ON, replace the fuel pump
assembly.
If the indicator still comes ON, check for an open or
short circuit in wire harness.
If the wire harness is OK, replace the combination
meter.
drewvir is offline
