Gas cap will not release - Wrist Twisters
post #1 of 13 Old 03-05-2009, 11:52 AM Thread Starter
oldguard60's Avatar
I can not release the gas cap. I tried all 4 keys that I have. two oem hondas, two copies. Yes, all will work in the ignition. It turns 1/4 turn , slightly pops up then I usually press it down and it releases. Any help would be appreicated.
oldguard60 is offline
post #2 of 13 Old 03-05-2009, 11:55 AM
slightly loosen the allen screws around the cap where you can wiggle it... then after it opens carefully align everything where it won't catch anymore..
post #3 of 13 Old 03-05-2009, 12:10 PM
Mine has done that before, a quick spray with some lubricant and it works fine.
Superduke
R1200GS
XR650L
post #4 of 13 Old 03-05-2009, 01:15 PM
919, CRF250X, LC4, CB400F
ndcent's Avatar
If the above two fixes don't work, just really take time to appreciate the 919 until she's out of gas, at which point it's forever doomed.
ndcent is offline
post #5 of 13 Old 03-05-2009, 01:17 PM Thread Starter
oldguard60's Avatar
I will try the lossening the allens. I has been lubed with graphite before.
Yes my light is on telling me I am low on fuel. It has not done this before.
post #6 of 13 Old 03-05-2009, 01:33 PM Thread Starter
oldguard60's Avatar
whew!!!!! that worked. Now I guess I will have to carry allen wrenches in my pocket when I go for a ride. I have been a little tired lately, death in the family and the stock market.
I was looking at the twist off caps and bases anyway.
Thanks Barton664
post #7 of 13 Old 03-05-2009, 01:59 PM
Mine has not given me any problems since I lubed it over a year ago.
Superduke
R1200GS
XR650L
post #8 of 13 Old 03-05-2009, 09:32 PM
when twisting the key push on the back part where the hinge is.
post #9 of 13 Old 03-05-2009, 09:49 PM
Duckin' for cover..
SoCal919's Avatar
You may already have the allen wrenches in the tool kit. Assuming yours came with the kit that is.
SoCal919 is offline
post #10 of 13 Old 03-06-2009, 05:27 AM Thread Starter
oldguard60's Avatar
Thanks for all of the helpful hints. I got it where I can open it now. I will have to make the time to make the finer adjustments or go to a votex base and cap. Anyone completed this change over at this time?
post #11 of 13 Old 03-06-2009, 06:03 AM
I'm going riding.
scrat's Avatar
i put one on a gixxer for my buddy, because the stock one wouldn't work when we dented his tank. it was, however, a terribly simple process. probably even easier than aligning the stock cap so it doesn't catch. The only downside we found was that it wasn't vented. which became a pain in the arse.
scrat is offline
post #12 of 13 Old 03-08-2009, 07:22 AM Thread Starter
oldguard60's Avatar
Thanks, I did not think about the venting issue.
post #13 of 13 Old 03-09-2009, 06:15 AM Thread Starter
oldguard60's Avatar
My final post on this one.
Lossening the allens allowed me to pop open the gas cap.
Then I removed the allens, funny 3 extended lentg allen that actually held in the cap at 12, 7,5 positions, the rest were dumbier allens, did not hold the cap to the tank.
I sprayed the locking part with jijaloo graphite. this did not help. The fix was to clean the lock with a cleaner, I used B12 Chem tool. After several sprays and shaking all of it out, then I relube with the graphite. Seems like the previous onwer used something that gummed up the works.
So now it evens pops up when the key is turned.
Thanks it looks like all suggestions were spot on....
