Galfer Lines for 919 - Wrist Twisters
post #1 of 10 Old 01-07-2007, 11:13 AM Thread Starter
I had a H-D
west467's Avatar
Anyone know the length of the Galfer lines (front) for the 919 in stock form?
When is the Group buy?
Thanks,
west467 is offline
post #2 of 10 Old 01-07-2007, 11:26 AM
wisco919's Avatar
MisterMike posted this link to galfer. It may answer the length question.
http://www.galferusa.com/MOTO.html
wisco919 is offline
post #3 of 10 Old 01-07-2007, 12:49 PM Thread Starter
I had a H-D
west467's Avatar
I sent Galfer an e-mail, maybe they can make me a set 2 inches longer..
Stay tuned.
Thanks,
west467 is offline
post #4 of 10 Old 01-28-2007, 06:41 AM
Hey guys.. Picked up my Galfer Line Kits and I found that in both the front (2Line) and rear kit, Galfer supplied extra brass washer . Did your kits come with extra washer, not that it is a bad thing..
One question I do have in with Galfer is noted below. Can I get your feedback also guys.. reasoning I am asking is that I found on Galfers site, their are references to use one washer and then also two (as described below)
email to Gafler
Hello Sandro.. I picked up the Front (2 line) and Rear like kits for my 2002 Honda 919… But I have a question about the install… It looks like Galfer provided a few extra brass washers for both kits.. So can you confirm the QTY of washers I am suppose to use for the front two line kit when I mount it to the Master Cylinder.
Please note, B=Banjo Connector, W =Washer, BB=Banjo Bolt
Do I use one or two washers between the two banjo bolts that mount to the master cylinder?
Example: One Washer
MasterCylinder/W/B/W/B/W/BB
Or Two Washers
MasterCylinder/W/B/W/W/B/BB
CB900F2 is offline
post #5 of 10 Old 01-28-2007, 06:51 AM
Example # 1 is correct. Most kits do supply extra washers.
This is a pic of LDH's setup.
post #6 of 10 Old 02-02-2007, 04:17 AM
Thanks Mike!...
Also, I haven’t made my way HomePot or a similar store (or bike shop) and was wondering what possible solution some of you guys have used for where the two lines go their separate ways at the lower fork clamp and if you have any suggestion on what you guys used as the line holder?
xrmikkey looks like he has a cool looking solution, xrmikey, hope you don’t mind me using your photo and adding a very nice looking red circle to it
Thanks guys!...
[QUOTE=MisterMike;73153]Example # 1 is correct. Most kits do supply extra washers.
CB900F2 is offline
post #7 of 10 Old 02-02-2007, 05:37 AM
& I was wondering what you do a little down stream of there at the fender. Take the collars off the old lines?
Bryce919er is offline
post #8 of 10 Old 02-02-2007, 07:20 AM
Tired of Tirone
jeffspeak's Avatar
Go to Home Depot and hit the electrical section. They sell a metal loop that is lined with gromet material for holding wires, about $2. You can run both brake lines through it and then through the stock holders on the frender. Looks clean and the lines are nicely controlled.
jeffspeak is offline
post #9 of 10 Old 02-02-2007, 12:46 PM
Love Machine
awarble's Avatar
Cool, thank for the idea, that looks nice....I'll have to do that with my F4I front end......
Awarble,
07 Honda CBR600RR
My Site
awarble is offline
post #10 of 10 Old 02-02-2007, 03:32 PM
Thanks a lot JEff!... Looks good...
CB900F2 is offline
