fuel reserve light acting up? - Wrist Twisters
post #1 of 8 Old 06-09-2007, 09:02 PM Thread Starter
cple of days ago my fuel reserve light started flashing intermittently and then it just stayed on to and from the commute to class (hr round trip). the troubling thing is that the day before i had already filled the tank up and everything was fine! i have a '02 cb900(919) hornet.
so, what gives?
zimi... is offline
post #2 of 8 Old 06-09-2007, 10:53 PM
so, what gives?
It sounds like the Brown/Black fuel sensor wire was rubbing on something grounded long enough to wear through the insulation, contact the conductor and light the low fuel light. A variation on this is the recommended test procedure in the service manual. The flashing would seem to confirm this. Tilt up the tank and inspect the wires from the bottom of the fuel pump mount plate -- there is a metal clamp on the base holding the harness which may have worn through the wire. If you don't find an obvious problem, make sure there is enough fuel to keep the light off and with the tank still up, turn off the kill switch, turn on the key, confirm the light is still on, and disconnect the fuel pump connector. If the light goes out the problem is in the fuel pump harness, the sensor is defective, or there is a short inside the tank. If it stays on, start inspecting the main harness forward for rubbing on anything grounded and do a "wiggle test" -- moving the harness while watching the light. Still on? Continue forward to the headlight shell. You get the idea. If you find no defects in the harness, the warning light panel may have developed an internal defect.
Good luck with this.
By the way: my factory '02 service manual wiring diagram says it's the Brown/Black wire, but the inspection procedure says it's Red/Black. This is the 38th inconsistency in the manual I've found so far. Come on, Honda! I expect better from you!
post #3 of 8 Old 06-09-2007, 11:30 PM
I'm beginning not too expect much. According the service manager at my dealer we muggles ought not have access to such privileged information as is contained in the holy manuals of service. Woe be unto he that approaches the divine perfection of the bike with a multi-meter in hand. Unto hell be he banished forever, the one who dares swap his handlebars to suit his needs.
sylas is offline
post #4 of 8 Old 06-20-2007, 04:55 AM Thread Starter
hey, thanks for taking the time.
since my initial post it is still acting up. flickering on/off and/or staying on. i'll take a closer look this wknd.
zimi... is offline
post #5 of 8 Old 06-20-2007, 05:34 AM
This might help.
post #6 of 8 Old 06-20-2007, 07:29 PM
3dcycle's Avatar
my geuss is fuel pump sending unit ( if i went by the manual thats what i would have replaced) it did that to my 07 919 with less than 500 miles. ending up being connection.
3dcycle is offline
post #7 of 8 Old 06-23-2007, 12:29 AM Thread Starter
ok, so i've had a closer inspection. although, i'm technically minded and whatnot i'm not that elecrical savvy, unfortunately.
anyhoo, i went for another ride today and the on/off flashing and staying on/off for a period of time is still occuring. great day for a ride, by the way
here are some pics. from my inspection there does not seem to be any "obvious" wear.
i pulled out the earth, as well as the 3 pin connector and firmly put them in place. (IMG_3126.jpg), (IMG_3129.jpg).
i wiggled this and that and nada. will i have to pull that black tape off that surrounds the electrical for further inspection? (IMG_3136.jpg)
here's a pic of the console with engine idling. the reserve full light did not show when i turned on the ignition.(IMG_3133.jpg)
oh, and yeah there is enough full in the tank prior to my ride and these photo's being taken.
so, um, will this be an expensive exercise if i let the mechanic have a go? if it involves replacing a part, i'd rather try it
cheers.
zimi... is offline
post #8 of 8 Old 06-23-2007, 03:32 AM
Church of the Holy Smoke
MotoCycho's Avatar
Had the same issue with my 2003 919. Took the fuel pump out which includes the sending unit sensor for the fuel.. cleaned a little with carb cleaner.. reinstalled been fine for over a year now. Try that.
- Rev. CYCHO -
MotoCycho is offline
