Front Sprocket Question - Wrist Twisters
post #1 of 4 Old 11-29-2008, 06:20 PM Thread Starter
I put the 9er back together today and since it was nearly 60 degrees I decided to go take her out for a test ride. Spring fever is at bay for at least another couple of days.
So here is my question. While cleaning all the old-school gear oil chain lube off the bike I noticed that the front sprocket feels a little loose. I can move it around a little on the shaft. I'm going to check the torque, but is this normal for it to come loose if that is the issue?
post #2 of 4 Old 11-30-2008, 01:36 AM
nallac's Avatar
mines the same,its got a bit of sideways movement.
it should be ok..
nallac is offline
post #3 of 4 Old 11-30-2008, 10:11 AM
they all do that
Honestly, Murf, thay are designed to slide just a bit. Go back to the thread started by "Mylifeon2wheels. His issue went away when the dealer greased the countershaft.
It's kind of a learning process when you take these things apart and put them back together.
post #4 of 4 Old 12-01-2008, 05:45 AM Thread Starter
Rod,
I really wasn't too worried about it as it just moved a little. There is no knock on mine either. I had helped Larry with his ZRX and didn't notice the front sprocket moving so I thought I would ask. I should have taken the front sprocket off for better cleaning and suspect that I would have found a the sprocket just slid over a splined shaft.
Keep that "they all do that" theme going! It's pretty funny in a smartelic way.
