FRONT SPROCKET ONLY?? - Wrist Twisters
post #1 of 11 Old 09-11-2009, 11:53 AM Thread Starter
Honda Hore
mtjsr's Avatar
After just spending an hour reading older threads on sprockets I need clarity....
The stock front sprocket is a 16 tooth I suppose? What does a 17 tooth exactly do to the revs at 70mph and a 15 tooth revs at 70 mph?
Here is what I am trying to figure out. I bought a slightly used 07. The previous owner put on a sprocket with an extra tooth. When I go down the freeway, other bikes pass me with great ease and just hum by. It feels like I am at high rpms (exact # I can't remember) and going slower. What do I need to do to go 80mph and just hum down the road?
Thanks guys!!!!!
mtjsr is offline
post #2 of 11 Old 09-11-2009, 12:13 PM
919, CRF250X, LC4, CB400F
ndcent's Avatar
I think you'd want the 17t front for smooth freeway revs.
The 15t would be more buzzy on the freeway.
ndcent is offline
post #3 of 11 Old 09-11-2009, 12:45 PM
Church of the Holy Smoke
MotoCycho's Avatar
Thanks guys!!!!!
Down shift, whack the throttle. 919 will do freeway speeds with easy in 2nd gear with anything from 15/45 to 17/43 sprocket combos. If you want more pull without having to down shift you want smaller front larger rear or both. The opposite to get higher MPG and run lower RPMs in the given gear. It's all about sacrifice and balance. I live at a relatively high altitude, (4400 ft), and I am a huge fatty.. so I like the 15/45 for around town riding and short freeway runs. If I was doing the commute thing I would go 17/43 and save some gas by lowering those Rs. You really have to figure out what you want from your bike. If you live at a lower elevation and weigh less than say.. me, you might find the bike has plenty of power even with 17/43 gearing. It always baffles my mind when others offer up solutions for "everyone" based on what they are using without taking into consideration all the factors. Anyway.. you choose.
BTW: stock is 16/43. It's a great balance for most folks. I often wish I had a toggle switch.
- Rev. CYCHO -
MotoCycho is offline
post #4 of 11 Old 09-11-2009, 02:57 PM Thread Starter
Honda Hore
mtjsr's Avatar
I hear you, seems like good solid information. Maybe because I am sitting right over the engine it just seems like I am really working for the 80 mph. The guys who pass me have one hand on their hip the other on the bars going la la la and smoking me. I will try swapping the front and see what difference I get.
mtjsr is offline
post #5 of 11 Old 09-11-2009, 03:01 PM
MotoCycho's Avatar
Like I said.. dump a couple gears and whack the throttle. You'll catch up.
- Rev. CYCHO -
post #6 of 11 Old 09-11-2009, 03:59 PM
blur
drewvir's Avatar
also........... with the stock 16/43 combo, the speedo reads @ 8 mph fast(says 70 but your going62) the +1 17/43 makes the speedo almost perfect but the odo is off slightly.
i'm 5'8 180 and mine will still power wheelie in 1st w/ 17/43 but the 16 was better.
so if your lookin at the gages they won't change.
i can catch my dad(05 st1300) on the highway in a topgear rollon even if he gets a jump
drewvir is offline
post #7 of 11 Old 09-12-2009, 07:29 AM
Veteran Donation
Ok What bikes are pulling on you?
I love the 919,but some bikes you are just not going to keep up with.
On another note it sounds like what mine does.I run a 17frt with a 44 rear I still need to drop a gear to make her really move.It's not really noticable unless I'm following full on sportbikes.
tvetree is offline
post #8 of 11 Old 09-12-2009, 09:06 AM
go back to stock gearing....17 tooth bike revs lower at highway speed taking longer to get up to speed.. less pulling power in the low mid rpm range
secondchance is offline
post #9 of 11 Old 09-13-2009, 08:27 AM Thread Starter
Honda Hore
mtjsr's Avatar
I will put the stock front sprocket back on and go for a ride. I think I got wind plowing issues as well. The road I ride on is pretty windy and I don't have a windshield. My body gets bumped around pretty good. I sit more upright than stock as well. Perhaps the other guys seem faster because they are all laying on their tanks.
mtjsr is offline
post #10 of 11 Old 09-14-2009, 07:00 PM
San Ramon, CA? That's where I work, and I live in San Leandro. I have a 2002 919. I'm usually around 580 & 680, and also Crow Canyon & Norris Canyon. It's not too often that other motorcyclists pass me up!
Cheers!!
cheapsk8 is offline
post #11 of 11 Old 09-15-2009, 02:14 PM Thread Starter
Honda Hore
mtjsr's Avatar
Cheers!!
Obviously I live in San Ramon, work in Livermore by Lawrence Lab. I am always riding around here on my 9er. Surprised I have not ran into you. I ride with a group of local guys who do 200 mile trips fairly often. Always looking for more bikes to join....
mtjsr is offline
