Front Sprocket Cover - Wrist Twisters
post #1 of 5 Old 12-02-2009, 04:47 PM Thread Starter
I'm in the process of cleaning up and modifying my 03 919; I've had it only a few months and have been working on it but have a long ways to go because the previous owner wasn't into maintenance. So.............the biggest problem the bike has is the front sprocket cover - the top bolt hole is busted in the threaded area that the bolt threads into. I guess I could drill out the hole and re-tap it but was considering just running the bike without the cover. Does anyone else do this? What are the downsides? Is there a risk of getting your pant legs caught in it? Do I have any other options?
I also noticed the front sprocket has a very small about of side to side play; is this normal or should it be completely snug? I tried tightening it but can't get enough leverage behind it - I need a longer wrench. I'm going to replace the sprockets and chain ASAP.
boudreaux is offline
post #2 of 5 Old 12-02-2009, 04:53 PM
i am sure there is a chance of getting your pants caught... but i have seen them ridden without the guard in place... the front sprocket is supposed to have side to side play and you don't need to gorilla tighten it because if you break that bolt off in there you have "problems".. just torque it to the proper amount..
me i wouldnt worry bout the top hole.. just use the other 2 bolts to hold it in place and ride it... don't go crazy tightening them up either... maybe just a drop of loctite BLUE to make sure they stay snug....
hope this helped...
post #3 of 5 Old 12-02-2009, 05:45 PM
CG
catonsvilleguy's Avatar
Paco's idea is not bad but if you really want to fix it right, try this.
Center punch the screw that's there as close to the center as you can. Use a nail if you don't have a punch. Drill a small hole in the center. Then use a screw extractor to unscrew the broken off piece. If it was broken from overtightening, it might come out easy. Worst case, you break off the screw extractor and you're back to Paco's approach or your drill & tap deal.
Amazon.com: OEM 25467 Bolt Extractor Set, 10-Piece: Home Improvement
Sears, Home Depot sell them also, maybe smaller, cheaper sets.
catonsvilleguy is offline
post #4 of 5 Old 12-02-2009, 05:54 PM
3dcycle's Avatar
if you are going to drill it pick up a set of reverse drill bits you might be lucky and get it out with those
3dcycle is offline
post #5 of 5 Old 12-02-2009, 06:18 PM
yep......... but be very careful drilling it out and do as catonville said and center punch the broken bolt otherwise the drill bit will walk and then problems... especially if the drill bit breaks..........
take your time.... don't force anything...
