front rotors - Wrist Twisters
post #1 of 6 Old 10-13-2008, 05:03 PM Thread Starter
jalm's Avatar
front rotors
anyone know if 03 f4I 600 rotors will match the 02 919 rotors?
jalm is offline
post #2 of 6 Old 10-13-2008, 05:24 PM
While the hub diameter and bolt circle look the same, the '03 rotor diameter is 310mm as opposed to the 919's 296mm. In order to make them work adapters must be made / purchased to space the calipers further out. I have no idea if the offset (dish of the carrier) is the same. It can be done, but will not just bolt on.
I just looked up a thread in which xrcajun did something similar:
https://www.wristtwisters.com/forum/s...ad.php?t=10545
He had adapters made and may have a source for them.
post #3 of 6 Old 10-13-2008, 07:09 PM Thread Starter
jalm's Avatar
thanks, really thinkin bout gettin some galfer wave rotors used. $280 shipped off a 03 f4i
jalm is offline
post #4 of 6 Old 10-13-2008, 07:32 PM
Go to Ron Ayers site:
http://www.ronayers.com/
Look up the part number for your rotor. Then on the home page, put that number into "Where does this part fit?" search. It will show you all the bikes that rotor is compatible with.
post #5 of 6 Old 10-13-2008, 07:35 PM
Curmudgeon
semi_gray's Avatar
Interesting.
I did the F4i fork swap four years ago using an '04 fork from a CBR600F4i and my original wheel. The forks came with the brake rotors and everything bolted right up. Now you've got me wondering about rotor-caliper interface.
semi_gray is offline
post #6 of 6 Old 10-14-2008, 12:39 AM
No worries as long as you used the rotors that came with the forks -- they're already matched up to the calipers. You would have known of any problems at the first pad change. Now, with the 919 rotors ... that's another kettle of fish.
