Front brake trouble - looking for help - Wrist Twisters
post #1 of 18 Old 08-20-2008, 02:59 PM Thread Starter
mk919's Avatar
Hello gang, I am looking for help on a front brake problem with my 919. I just replaced the tires so the front wheel was off and back on. I didn't do anything to the brakes other than dismount the calipers as needed to remove the front wheel. The caliper did fall once or twice from where I had them set, but nothing seemed damaged. When the caliper fell I mean it fell about 6 inches and was then suspended by the hydraulic line. There didn't seem to be any damage and no fluid leaked, but I thought it was worth mentioning, it may not even be related.
The actual issue is that I have to pump the front brake lever a couple of times to get the brakes to work. The lever goes right to the grip at first then builds pressure as I pump it. What is the problem and how do I fix it? I thought about trying to bleed the brakes but without opening the lines why would I have to do that??? Thanks in advance. Mike
mk919 is offline
post #2 of 18 Old 08-20-2008, 03:49 PM
BlackRig's Avatar
Sounds like air in the lines to me. Seems strange considering the lines wernt taken apart. You could have damaged them in one of the drops I guess.
Bleed new fluid. Who knows what happened? But leaving them the way they are is not an option.
BlackRig is offline
post #3 of 18 Old 08-20-2008, 03:54 PM
Curmudgeon
semi_gray's Avatar
Your description of the problem implies that there indeed is air in the line that needs to be bled out. At this point, the why of it all is somewhat moot.
The question I have is, why remove the calipers? I can use a front stand, or in a pinch, suspend the front-end from the rafters, and drop the front wheel out in the process sliding the rotors out from the calipers.
This way, no oopsies or dropsies!
I prefer a vacuum bleeder, but there are those who profess that pumping is better. Any way you choose, bleed those brakes and you might as well replace the fluid while you're there.
semi_gray is offline
post #4 of 18 Old 08-20-2008, 04:08 PM
You can?
post #5 of 18 Old 08-20-2008, 04:27 PM
You may now be able to justify new braided stainless lines.
post #6 of 18 Old 08-20-2008, 04:55 PM
Curmudgeon
semi_gray's Avatar
You can?
Taking the front fender off simplifies things but yes, once the axle is out, the front wheel assembly can be dropped out.
post #7 of 18 Old 08-20-2008, 05:35 PM
bucky's Avatar
yup, rear too !
bucky is offline
post #8 of 18 Old 08-20-2008, 06:17 PM
Corner speed sets u free
streakin919's Avatar
I'm a little slow in the head sometimes, can you give more detail on how you get the wheel assembly past the calipers without removing them?
streakin919 is offline
post #9 of 18 Old 08-20-2008, 06:28 PM
I'm thinking it has to do with how high the front is suspended. I dont think I could using the front stand I use.
post #10 of 18 Old 08-20-2008, 06:30 PM
Remove the front fender. Turn the lower fork legs so the calipers face out once the axle is removed.
I think I'd rather remove the calipers.
post #11 of 18 Old 08-20-2008, 06:36 PM
C'est la vie
CMulford's Avatar
Check that one or both of your discs aren't bent. Perhaps someone bent one disc while changing the tire. It should be obvious if this is the issue when you lift the front wheel and spin it. If it grabs hard at one point and stops or nearly does you might have an issue there. When my disc was warped a bunch it would push the pads away from the disc while I was moving so the first grab of the lever nearly brought it to the grip.
CMulford is offline
post #12 of 18 Old 08-20-2008, 08:27 PM
Finally! If the lever ever feels normal the problem is not air. As CMulford said, a bent rotor will cause the symptom you describe. Unfortunately the only real cure is to replace it -- while it is possible to straighten it, it's definitely not a job for the inexperienced.
Galfer rotors? What the heck.
post #13 of 18 Old 08-20-2008, 08:39 PM
I scratched the $#it out of both my front & rear wheels when I tried to remove the wheels with the calipers on. I'm not used to these new fangled fat 17" rims; I hail from dirt bikes.
Bryce919er is offline
post #14 of 18 Old 08-21-2008, 12:17 PM Thread Starter
mk919's Avatar
Thanks for the help. I'm still having a problem but Cmulford and Rob seem to have a good point. I have bled the lines a couple of times and that seems OK. At this point if the bike stays in one place the brake seems fine, but if I roll it and try again the handle goes to the grip on the first pull but restores to normal after that. Sounds like a bent rotor????
I did the tires myself and never dropped the wheel such that the rotor could have bent, but my tire changing station is in the basement where the boys play sometimes. I guess it is possible the wheel got knocked around w/o me knowing. I'll remove the rotors and check them.
Any other ideas?
Mike
mk919 is offline
post #15 of 18 Old 08-21-2008, 12:46 PM Thread Starter
mk919's Avatar
A quick look at the rotors and I believe one of them is bent. Now, who has a good source for replacement rotors? I see the Gafler set is well over $500. That's not for me. I will do some shopping around and call the dealer, but is there a good source on the net? I don't want the cheapest out there but $500 isn't where I want to be either. Thanks again.
mk919 is offline
post #16 of 18 Old 08-21-2008, 02:09 PM
C'est la vie
CMulford's Avatar
I ended up buying the Galfers from RC90 (Motolube) and am happy with them on my 600RR. The stock ones are cheaper through Motolube or Ron Ayers, but not by much. Don't forget you'll be needing new pads to go with new rotors so that's gonna' bump up the cost even more.
CMulford is offline
post #17 of 18 Old 08-22-2008, 10:41 AM
bucky's Avatar
other (readily attainable) hondas take the same rotor. ronayres.com's fiche can help you confirm p/n interchangability, and then you can cruise ebay looking for used take-offs from a 600f4i or some such. if cheap is your key.
also, good reason to keep kids out of the garage: it can kill you when your brakes fail.
sortof like why i bark at people who touch my bike at the strip. anything they touch COULD kill me.
if you're really certain you didn't bend the rotor yourself while you were reefing on the tire irons...nah, go yell at the kids !
bucky is offline
post #18 of 18 Old 08-22-2008, 11:01 AM
Bucky... it's actually http://www.ronayers.com/
(those of us with dyslexia can't see the difference until actually trying the link)
Thanks for the tip! I'm going to use it for other swappables
omaha_919 is offline
